First steps in FHEM
Hier entsteht die englische Fassung von Erste Schritte in FHEM...
  • Letzte Änderung der dt. Fassung: 17.05.2020
  • Letzte Änderung der engl. Fassung: 12.06.2017
  • Neuere Version ist: dt. Version
This a beginners course for those starting to work with FHEM. After you have installed FHEM on your server you may reproduce all steps without any additional smart home hardware.
This guide was primarily published by Ulrich Maass who permitted the use in FHEM wiki.
Note to editors: Everybody is called to improve orthography, grammar and style. Content changes and extentions should be discussed with the author (e. g. on associated discussion page).
First attempt
Creating device - define
Creating rooms
Creating switching commands
Event monitor
Operating devices - set
Event trigger - notify
Deleting or disabling devices – delete, disable
Save Config
Modifying existing – modify
Switching a couple of devices at once
Renaming devices
Scheduler - at
Event-driven timer start - notify und at
How do we go on?
