Waterkotte heat pump with Resümat CD4
WKRCD4
Control / Extract information from Waterkotte Heat pumps with Resümat CD4 controller
Typ Contrib
Dokumentation Thema
Support (Forum) Sonstiges
Modulname 98_WKRCD4.pm
Ersteller StefanStrobel (Forum / Wiki)
WKRCD4 allows to control / communicate with older heat pumps from Waterkotte that have a control unit called Resümat CD4 with an RS232 serial interface. Newer heat pumps from Waterkotte typically have a modbus interface that can be controlled with module ModbusAttr.
CD4 control units with software version 7000, 8000 or 8011 can be controlled with another version of the WKRCD4 module.
Availability
The module has been checked in to the contrib area.
Prerequisites
This module requires Device::SerialPort or Win32::SerialPort module. Make sure to set "Modem-Klingelzeichen" and "Fremdzugriff" to the lowest possible value.
define <name> WKRCD4 <devicename@speed> <Interval>
The module connects to the heat pump through a serial interface and actively requests data from the heat pump every <Interval> seconds
Example:
define WP WKRCD4 /dev/dualser0@9600 60
attr WP stateFormat Status
attr WP event-min-interval .*:3600
attr WP event-on-change-reading .*
Configuration of the module
Apart from the serial interface and the interval there is nothing that needs to be defined.
Get-Commands
There are only two parameters for which an explicit GET has been implemented. Most values are just readings that are automatically requested:
Hzg-TempBasisSoll
WW-Temp-Soll
Set-Commands
There is only one parameter that can be changed:
Hzg-TempBasisSoll
Supported readings
The module extracts the following readings from the heat pump:
Versions-Nummer
Temp-Aussen
Temp-Ruecklauf-Soll
Temp-Ruecklauf
Temp-Vorlauf
Temp-WW-Soll
Temp-WW
Temp-Raum
Temp-WQuelle-Ein
Temp-WQuelle-Aus
Temp-Verdampfer
Temp-Kondensator
Temp-Saugleitung
Druck-Verdampfer
Druck-Kondensator
Hzg-TempEinsatz
Hzg-TempBasisSoll
Hzg-KlSteilheit
Hzg-KlBegrenz
Hzg-TempRlSoll
Hzg-TempRlIst
Hzg-TmpRaumSoll
Hzg-RaumEinfluss
Hzg-ExtAnhebung
Hzg-Zeit-Ein
Hzg-Zeit-Aus
Hzg-AnhebungEin
Hzg-AnhebungAus
Hzg-St2Begrenz
Hzg-Hysterese
Hzg-PumpenNachl
Klg-Abschaltung
Klg-Temp-Einsatz
Klg-TeBasisSoll
Klg-KlSteilheit
Klg-KlBegrenz
Klg-KlSollwert
Klg-Temp-Rl
Ww-Abschaltung
Ww-Zeit-Ein
Ww-Zeit-Aus
Ww-Temp-Ist
Ww-Temp-Soll
Ww-Hysterese
Uhrzeit
Datum
BetrStundenKompressor
BetrStundenHzgPu
BetrStundenWwPu
BetrStundenSt2
Zeit
SetBetriebsMode
Display-Zeile-1
Display-Zeile-2
Status-Gesamt
Status-Heizung
Status-Kuehlung
Mode-Heizung
Mode-Kuehlung
Mode-Warmwasser
Heizung
Kuehlung
Warmwasser
Attributes
do_not_notify
readingFnAttributes
