MediaWiki-API-Ergebnis
This is the HTML representation of the JSON format. HTML is good for debugging, but is unsuitable for application use.
Specify the format parameter to change the output format. To see the non-HTML representation of the JSON format, set format=json.
See the complete documentation, or the API help for more information.
"error": {
"code": "badvalue",
"info": "Unrecognized value for parameter \"interwikisource\": meta.",
"*": "See http://wiki.fhem.de/w/api.php for API usage. Subscribe to the mediawiki-api-announce mailing list at <https://lists.wikimedia.org/postorius/lists/mediawiki-api-announce.lists.wikimedia.org/> for notice of API deprecations and breaking changes."
