DevelopmentDirectoryStructure
Todo: Überprüfung und ggfs. Aktualisierung des Seiteninhalts
This is currently under development as at 2012-07-17
General directory structure
The base directory of fhem is $modpath (this is where fhem.pl is). All active modules are in $modpath/FHEM.
Inner workings of the FHEMWEB server
FHEMWEB directory structure
The base URL of the FHEMWEB server is http://hostname:port/<webname>. The path <webname> is taken from the webname attribute of the FHEMWEB device. It defaults to "fhem".
The directory layout on the file system from which fhem serves files is either (new version)
$modpath/
     www/
	  images/
		default/         (contains standard images and floorplans)
           weather/      (contains weather icons)
		dark/          (contains overrides for icons in dark style)
        smallscreen/       (contains overrides for icons in smallscreen style)
  	  docs/			 (non-existant in standard installation)
	  gplot/            (contains gplot files)
	  pgm2/             (contains javascript, css and svg files)
or (old version)
$modpath/
     FHEM
or (interim version)
$modpath/
     www/
      pgm2/
