BEKEN iLedBlub
These are LED lamps E27 ~7W with Bluetooth BLE, in variants of RGB color, and without.
Manufacturer/distributor Hama/Xavax.
Product number 00111973 (case marking: 001119730001).
Currently (2018-01-09) sold at http://pollin.de for 4,95 Euro ([1] , [2]).
And, since these are called iLedBlub (sic!), I chose to use the same name for this page.
http://www.instructables.com/id/Reading-Values-From-a-BLE-Device-Using-CSR1010-and/
LabNotes: Reverse Engineering Sex Toys (ermm ;))
# hcitool lescan
[MAC] LED
[MAC] (unknown)
# gattool -I
connnect [MAC]
characteristics
char-read-hnd 0x3
Characteristic value/descriptor: 69 4c 65 64 42 6c 75 62 --> iLedBlub (https://rainerpeffm.wordpress.com/2016/01/18/installation-mit-i-eurolamp-und-brille-%C2%B7-im-eiscafe/)
char-read-hnd 0x5
Characteristic value/descriptor: 03
Characteristic value/descriptor: 00
char-read-hnd 0x7
Characteristic value/descriptor: 64 00 c8 00 00 d0 07
char-read-hnd 0x9
char-read-hnd 0xb
Characteristic value/descriptor: 00 00 00 00 00 00
char-read-hnd 0x12
Characteristic value/descriptor: 42 45 4b 45 4e 00 00 00 00 00 --> BEKEN
(BEKEN likely is http://www.bekencorp.com/en/index.Asp - that page contains text "BK326X is qualified by SIG by Bluetooth", so......)
char-read-hnd 0x14
Characteristic value/descriptor: 42 54 20 34 2e 30 --> BE 4.0
char-read-hnd 0x16
Characteristic value/descriptor: 31 32 78 30 37 78 32 30 31 32 --> 12x07x2012
char-read-hnd 0x18
Characteristic value/descriptor: 53 4d 2d 31 --> SM-1
char-read-hnd 0x1a
Characteristic value/descriptor: 30 31 2e 31 --> 01.1
char-read-hnd 0x1c
char-read-hnd 0x1e
Characteristic value/descriptor: de bc 9a fe ff 56 34 12
char-read-hnd 0x20
Characteristic value/descriptor: 89 ab cd ef
char-read-hnd 0x22
Characteristic value/descriptor: 01 0e 00 12 34 01 67
char-read-hnd 0x25
Characteristic value/descriptor: 01 f9 01 00 01 ff 01 f3 01 ff
Characteristic value/descriptor: 01 00 01 00 01 00 01 63 01 00
Characteristic value/descriptor: 00 00 00 00 00 00 00 00 00 00 (possibly happens directly at char-write-req 0x2a 0x0???)
char-read-hnd 0x2c
Characteristic value/descriptor: 8e 03 f8 a2 b1 00
char-write-req 0x28 e3105811111111 --> max. 7 bytes value allowed
char-write-req 0x2a 112233445566778899aa --> max. 10 bytes value allowed
char-write-req 0x2a
01f9010001ff01f301ff --> IMMEDIATELY WHITE!! (woohoo!!)
00000000000000000000 --> OFF!!
00000000000f01ff0030 --> RED!
0000017001ff01000030 --> BLUE!
data word format
agGG????abBBarRRalLL
a = activate sub component
R = red
G = green
B = blue
LL = Brightness
? = unknown
https://developer.android.com/reference/android/bluetooth/BluetoothGattCharacteristic.html
characteristics
handle: 0x0002, char properties: 0x08, char value handle: 0x0003, uuid: 00002a00-0000-1000-8000-00805f9b34fb 0x2a00 org.bluetooth.characteristic.gap.device_name
handle: 0x0004, char properties: 0x02, char value handle: 0x0005, uuid: 00002a01-0000-1000-8000-00805f9b34fb 0x2a01 org.bluetooth.characteristic.gap.appearance
handle: 0x0006, char properties: 0x02, char value handle: 0x0007, uuid: 00002a04-0000-1000-8000-00805f9b34fb 0x2a04 org.bluetooth.characteristic.gap.peripheral_preferred_connection_parameters
handle: 0x0008, char properties: 0x02, char value handle: 0x0009, uuid: 00002a02-0000-1000-8000-00805f9b34fb 0x2a02 org.bluetooth.characteristic.gap.peripheral_privacy_flag
handle: 0x000a, char properties: 0x02, char value handle: 0x000b, uuid: 00002a03-0000-1000-8000-00805f9b34fb 0x2a03 org.bluetooth.characteristic.gap.reconnection_address
handle: 0x000d, char properties: 0x22, char value handle: 0x000e, uuid: 00002a05-0000-1000-8000-00805f9b34fb 0x2a05 org.bluetooth.characteristic.gatt.service_changed
handle: 0x0011, char properties: 0x02, char value handle: 0x0012, uuid: 00002a29-0000-1000-8000-00805f9b34fb 0x2a29 org.bluetooth.characteristic.manufacturer_name_string
handle: 0x0013, char properties: 0x02, char value handle: 0x0014, uuid: 00002a24-0000-1000-8000-00805f9b34fb 0x2a24 org.bluetooth.characteristic.model_number_string
handle: 0x0015, char properties: 0x02, char value handle: 0x0016, uuid: 00002a25-0000-1000-8000-00805f9b34fb 0x2a25 org.bluetooth.characteristic.serial_number_string
handle: 0x0017, char properties: 0x02, char value handle: 0x0018, uuid: 00002a27-0000-1000-8000-00805f9b34fb 0x2a27 org.bluetooth.characteristic.hardware_revision_string
handle: 0x0019, char properties: 0x02, char value handle: 0x001a, uuid: 00002a26-0000-1000-8000-00805f9b34fb 0x2a26 org.bluetooth.characteristic.firmware_revision_string
handle: 0x001b, char properties: 0x02, char value handle: 0x001c, uuid: 00002a28-0000-1000-8000-00805f9b34fb 0x2a28 org.bluetooth.characteristic.software_revision_string
handle: 0x001d, char properties: 0x02, char value handle: 0x001e, uuid: 00002a23-0000-1000-8000-00805f9b34fb 0x2a23 org.bluetooth.characteristic.system_id
handle: 0x001f, char properties: 0x02, char value handle: 0x0020, uuid: 00002a2a-0000-1000-8000-00805f9b34fb 0x2a2a org.bluetooth.characteristic.ieee_11073-20601_regulatory_certification_data_list
handle: 0x0021, char properties: 0x02, char value handle: 0x0022, uuid: 00002a50-0000-1000-8000-00805f9b34fb 0x2a50 org.bluetooth.characteristic.pnp_id
handle: 0x0024, char properties: 0x10, char value handle: 0x0025, uuid: 0000ee01-0000-1000-8000-00805f9b34fb
handle: 0x0027, char properties: 0x0c, char value handle: 0x0028, uuid: 0000ee02-0000-1000-8000-00805f9b34fb
handle: 0x0029, char properties: 0x0c, char value handle: 0x002a, uuid: 0000ee03-0000-1000-8000-00805f9b34fb
handle: 0x002b, char properties: 0x10, char value handle: 0x002c, uuid: 0000ee04-0000-1000-8000-00805f9b34fb
https://www.bluetooth.com/specifications/gatt/characteristics
I managed to figure these access details out relatively easily, without actually doing Bluetooth sniffing.
If someone has a Bluetooth sniffing environment easily available, then it would be useful to gather potentially remaining additional commands sent by the XAVAX II app.
I'm currently working on a FHEM module, taking 74_XiaomiFlowerSens.pm
as a reference. I will thus possibly use gattool interfacing (or perhaps interfacing to MQTT, but this would require an extra MQTT provider component), and Color.pm (FHEM's color picker wheel).
Legal disclaimer: no warranties - "if it breaks, then you get to keep both pieces." etc.pp.
