Benutzer:Marc76/.config für USBSerial Module
Version vom 4. September 2013, 07:52 Uhr von Marc76 (Diskussion | Beiträge) (Die Seite wurde neu angelegt: „# # Automatically generated make config: don't edit # Linux kernel version: 2.6.32.12 # Tue Sep 3 22:45:36 2013 # CONFIG_ARM=y CONFIG_SYS_SUPPORTS_APM_EMULATI…“)
  1. Automatically generated make config: don't edit
  2. Linux kernel version: 2.6.32.12
  3. Tue Sep 3 22:45:36 2013
CONFIG_ARM=y CONFIG_SYS_SUPPORTS_APM_EMULATION=y CONFIG_GENERIC_GPIO=y CONFIG_GENERIC_TIME=y CONFIG_GENERIC_CLOCKEVENTS=y CONFIG_GENERIC_HARDIRQS=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_HAVE_LATENCYTOP_SUPPORT=y CONFIG_LOCKDEP_SUPPORT=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_HARDIRQS_SW_RESEND=y CONFIG_GENERIC_IRQ_PROBE=y CONFIG_RWSEM_GENERIC_SPINLOCK=y CONFIG_ARCH_HAS_CPUFREQ=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_GENERIC_HARDIRQS_NO__DO_IRQ=y CONFIG_VECTORS_BASE=0xffff0000 CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config" CONFIG_CONSTRUCTORS=y
  1. General setup
CONFIG_EXPERIMENTAL=y CONFIG_BROKEN_ON_SMP=y CONFIG_INIT_ENV_ARG_LIMIT=32 CONFIG_LOCALVERSION=""
  1. CONFIG_LOCALVERSION_AUTO is not set
CONFIG_HAVE_KERNEL_GZIP=y CONFIG_HAVE_KERNEL_LZMA=y
  1. CONFIG_KERNEL_GZIP is not set
  2. CONFIG_KERNEL_BZIP2 is not set
CONFIG_KERNEL_LZMA=y CONFIG_SWAP=y CONFIG_SYSVIPC=y CONFIG_SYSVIPC_SYSCTL=y
  1. CONFIG_POSIX_MQUEUE is not set
  2. CONFIG_BSD_PROCESS_ACCT is not set
  3. CONFIG_TASKSTATS is not set
  4. CONFIG_AUDIT is not set
  1. RCU Subsystem
CONFIG_TREE_RCU=y
  1. CONFIG_TREE_PREEMPT_RCU is not set
  2. CONFIG_RCU_TRACE is not set
CONFIG_RCU_FANOUT=32
  1. CONFIG_RCU_FANOUT_EXACT is not set
  2. CONFIG_TREE_RCU_TRACE is not set
  3. CONFIG_IKCONFIG is not set
CONFIG_LOG_BUF_SHIFT=17
  1. CONFIG_GROUP_SCHED is not set
  2. CONFIG_CGROUPS is not set
CONFIG_SYSFS_DEPRECATED=y CONFIG_SYSFS_DEPRECATED_V2=y
  1. CONFIG_RELAY is not set
  2. CONFIG_NAMESPACES is not set
CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="" CONFIG_RD_GZIP=y
  1. CONFIG_RD_BZIP2 is not set
CONFIG_RD_LZMA=y CONFIG_CC_OPTIMIZE_FOR_SIZE=y CONFIG_SYSCTL=y CONFIG_ANON_INODES=y CONFIG_EMBEDDED=y CONFIG_UID16=y CONFIG_SYSCTL_SYSCALL=y CONFIG_KALLSYMS=y
  1. CONFIG_KALLSYMS_EXTRA_PASS is not set
CONFIG_HOTPLUG=y CONFIG_PRINTK=y CONFIG_BUG=y CONFIG_ELF_CORE=y CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_EPOLL=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EVENTFD=y CONFIG_SHMEM=y
  1. CONFIG_AIO is not set
  1. Kernel Performance Events And Counters
CONFIG_VM_EVENT_COUNTERS=y CONFIG_PCI_QUIRKS=y CONFIG_COMPAT_BRK=y CONFIG_SLAB=y
  1. CONFIG_SLUB is not set
  2. CONFIG_SLOB is not set
  3. CONFIG_PROFILING is not set
CONFIG_HAVE_OPROFILE=y
  1. CONFIG_KPROBES is not set
CONFIG_HAVE_KPROBES=y CONFIG_HAVE_KRETPROBES=y
  1. GCOV-based kernel profiling
CONFIG_SLOW_WORK=y CONFIG_SYNO_DISPLAY_CPUINFO=y CONFIG_HAVE_GENERIC_DMA_COHERENT=y CONFIG_SLABINFO=y CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y
  1. CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y CONFIG_MODULE_FORCE_UNLOAD=y
  1. CONFIG_MODVERSIONS is not set
  2. CONFIG_MODULE_SRCVERSION_ALL is not set
CONFIG_BLOCK=y CONFIG_LBDAF=y CONFIG_BLK_DEV_BSG=y
  1. CONFIG_BLK_DEV_INTEGRITY is not set
  1. IO Schedulers
CONFIG_IOSCHED_NOOP=y CONFIG_IOSCHED_AS=y
  1. CONFIG_IOSCHED_DEADLINE is not set
  2. CONFIG_IOSCHED_CFQ is not set
CONFIG_DEFAULT_AS=y
  1. CONFIG_DEFAULT_DEADLINE is not set
  2. CONFIG_DEFAULT_CFQ is not set
  3. CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED="anticipatory"
  1. CONFIG_FREEZER is not set
  1. System Type
CONFIG_MMU=y
  1. CONFIG_ARCH_AAEC2000 is not set
  2. CONFIG_ARCH_INTEGRATOR is not set
  3. CONFIG_ARCH_FEROCEON_ORION is not set
CONFIG_ARCH_FEROCEON_KW=y
  1. CONFIG_ARCH_FEROCEON_MV78XX0 is not set
  2. CONFIG_ARCH_REALVIEW is not set
  3. CONFIG_ARCH_VERSATILE is not set
  4. CONFIG_ARCH_AT91 is not set
  5. CONFIG_ARCH_CLPS711X is not set
  6. CONFIG_ARCH_GEMINI is not set
  7. CONFIG_ARCH_EBSA110 is not set
  8. CONFIG_ARCH_EP93XX is not set
  9. CONFIG_ARCH_FOOTBRIDGE is not set
  10. CONFIG_ARCH_MXC is not set
  11. CONFIG_ARCH_STMP3XXX is not set
  12. CONFIG_ARCH_NETX is not set
  13. CONFIG_ARCH_H720X is not set
  14. CONFIG_ARCH_NOMADIK is not set
  15. CONFIG_ARCH_IOP13XX is not set
  16. CONFIG_ARCH_IOP32X is not set
  17. CONFIG_ARCH_IOP33X is not set
  18. CONFIG_ARCH_IXP23XX is not set
  19. CONFIG_ARCH_IXP2000 is not set
  20. CONFIG_ARCH_IXP4XX is not set
  21. CONFIG_ARCH_L7200 is not set
  22. CONFIG_ARCH_KIRKWOOD is not set
  23. CONFIG_ARCH_LOKI is not set
  24. CONFIG_ARCH_MV78XX0 is not set
  25. CONFIG_ARCH_ORION5X is not set
  26. CONFIG_ARCH_MMP is not set
  27. CONFIG_ARCH_KS8695 is not set
  28. CONFIG_ARCH_NS9XXX is not set
  29. CONFIG_ARCH_W90X900 is not set
  30. CONFIG_ARCH_PNX4008 is not set
  31. CONFIG_ARCH_PXA is not set
  32. CONFIG_ARCH_MSM is not set
  33. CONFIG_ARCH_RPC is not set
  34. CONFIG_ARCH_SA1100 is not set
  35. CONFIG_ARCH_S3C2410 is not set
  36. CONFIG_ARCH_S3C64XX is not set
  37. CONFIG_ARCH_S5PC1XX is not set
  38. CONFIG_ARCH_SHARK is not set
  39. CONFIG_ARCH_LH7A40X is not set
  40. CONFIG_ARCH_U300 is not set
  41. CONFIG_ARCH_DAVINCI is not set
  42. CONFIG_ARCH_OMAP is not set
  43. CONFIG_ARCH_BCMRING is not set
  44. CONFIG_ARCH_OXNAS is not set
  45. CONFIG_ARCH_OX820 is not set
  1. Feroceon SoC options
CONFIG_MV88F6281=y CONFIG_SYNO_MV88F6281=y CONFIG_MACH_SYNOLOGY_6282=y
  1. CONFIG_SYNO_MV88F6281_USBSTATION is not set
  2. CONFIG_JTAG_DEBUG is not set
  1. Feroceon SoC Included Features
CONFIG_MV_INCLUDE_PEX=y
  1. CONFIG_MV_INCLUDE_USB is not set
CONFIG_MV_INCLUDE_XOR=y CONFIG_MV_INCLUDE_CESA=y
  1. CONFIG_MV_INCLUDE_NAND is not set
CONFIG_MV_INCLUDE_INTEG_SATA=y
  1. CONFIG_MV_INCLUDE_TDM is not set
CONFIG_MV_INCLUDE_GIG_ETH=y CONFIG_MV_INCLUDE_SPI=y
  1. CONFIG_MV_INCLUDE_SDIO is not set
  2. CONFIG_MV_INCLUDE_AUDIO is not set
  3. CONFIG_MV_INCLUDE_TS is not set
  4. CONFIG_MV_INCLUDE_LCD is not set
  5. CONFIG_MV_INCLUDE_SWITCH is not set
CONFIG_MV_GPP_MAX_PINS=64 CONFIG_MV_DCACHE_SIZE=0x4000 CONFIG_MV_ICACHE_SIZE=0x4000
  1. Feroceon SoC MTD support
CONFIG_MV_FLASH_CTRL=y CONFIG_MV_INCLUDE_SFLASH_MTD=y
  1. CONFIG_MV_SPI_BOOT is not set
CONFIG_ARCH_SUPPORTS_BIG_ENDIAN=y CONFIG_USE_DSP=y CONFIG_MV_SP_I_FTCH_DB_INV=y
  1. CONFIG_MV_SP_I_FTCH_LCK_L2_ICACHE is not set
  2. CONFIG_MV_SP_I_FTCH_NONE is not set
CONFIG_MV_INTERNAL_REGS_SELECTIVE_MAPPING=y CONFIG_FEROCEON_PROC=y CONFIG_UBOOT_STRUCT=y
  1. CONFIG_MV_DBG_TRACE is not set
  2. CONFIG_MV_REAL_TIME is not set
  3. CONFIG_MV_CPU_PERF_CNTRS is not set
  4. CONFIG_MV_CPU_L2_PERF_CNTRS is not set
  1. Soc DMA accelerations
CONFIG_MV_USE_XOR_ENGINE=y CONFIG_MV_XOR_MEMCOPY=y CONFIG_MV_XOR_MEMCOPY_THRESHOLD=128 CONFIG_MV_XOR_MEMXOR=y CONFIG_MV_XOR_MEMXOR_THRESHOLD=4096 CONFIG_MV_XOR_COPY_TO_USER=y CONFIG_MV_XOR_COPY_TO_USER_THRESHOLD=1260 CONFIG_MV_XOR_COPY_FROM_USER=y CONFIG_MV_XOR_COPY_FROM_USER_THRESHOLD=1260 CONFIG_MV_XOR_CHANNELS=4
  1. SoC Networking support
CONFIG_MV_ETHERNET=y CONFIG_MV_ETH_PORTS_NUM=2
  1. Network Interface Configuration
  2. CONFIG_OVERRIDE_ETH_CMDLINE is not set
CONFIG_MV_ETH_0_MTU=1500 CONFIG_MV_ETH_0_MACADDR="00:00:00:00:00:80" CONFIG_MV_ETH_1_MTU=1500 CONFIG_MV_ETH_1_MACADDR="00:00:00:00:00:81"
  1. Rx/Tx Queue Configuration
CONFIG_MV_ETH_RXQ=1 CONFIG_MV_ETH_TXQ=1 CONFIG_MV_ETH_NUM_OF_RX_DESCR=128 CONFIG_MV_ETH_NUM_OF_TX_DESCR=532
  1. TCP/UDP Offloading
CONFIG_MV_ETH_TSO=y
  1. CONFIG_MV_ETH_UFO is not set
  1. Control and Statistics
CONFIG_MV_ETH_TOOL=y
  1. CONFIG_MV_ETH_PROC is not set
  2. CONFIG_MV_ETH_STATS_ERROR is not set
  3. CONFIG_MV_ETH_STATS_INFO is not set
  4. CONFIG_MV_ETH_STATS_DEBUG is not set
  5. CONFIG_MV_LINUX_COUNTERS_DISABLE is not set
  1. Advanced Features
CONFIG_MV_ETH_TIMER_PERIOD=10
  1. CONFIG_MV_ETH_SKB_REUSE is not set
CONFIG_NET_SKB_HEADROOM=64 CONFIG_NET_SKB_RECYCLE=y CONFIG_NET_SKB_RECYCLE_DEF=1
  1. CONFIG_MV_ETH_NFP is not set
  1. cesa options
CONFIG_MV_CESA=y CONFIG_MV_CESA_OCF=m CONFIG_MV_CESA_TOOL=m
  1. CONFIG_MV_CESA_TEST is not set
  2. CONFIG_SCSI_MVSATA is not set
  3. CONFIG_PCIE_VIRTUAL_BRIDGE_SUPPORT is not set
CONFIG_SYNO_MV_COMMON=y CONFIG_FORCE_MAX_ZONEORDER=19 CONFIG_ARCH_FEROCEON=y
  1. Processor Type
CONFIG_CPU_32=y CONFIG_CPU_FEROCEON=y CONFIG_CPU_FEROCEON_OLD_ID=y CONFIG_CPU_32v5=y CONFIG_CPU_ABRT_EV5T=y CONFIG_CPU_PABRT_LEGACY=y CONFIG_CPU_CACHE_VIVT=y CONFIG_CPU_COPY_FEROCEON=y CONFIG_CPU_TLB_FEROCEON=y CONFIG_CPU_CP15=y CONFIG_CPU_CP15_MMU=y
  1. Processor Features
CONFIG_ARM_THUMB=y
  1. CONFIG_CPU_BIG_ENDIAN is not set
  2. CONFIG_CPU_ICACHE_DISABLE is not set
  3. CONFIG_CPU_DCACHE_DISABLE is not set
CONFIG_OUTER_CACHE=y CONFIG_CACHE_FEROCEON_L2=y
  1. CONFIG_ARM_ARMV5_L2_CACHE_COHERENCY_FIX is not set
  2. CONFIG_ARM_MARVELL_BSP_MM_ADD_API_FOR_DMA is not set
CONFIG_CACHE_FEROCEON_L2_WRITETHROUGH=y CONFIG_ARM_L1_CACHE_SHIFT=5
  1. Bus support
CONFIG_PCI=y CONFIG_PCI_SYSCALL=y
  1. CONFIG_ARCH_SUPPORTS_MSI is not set
CONFIG_PCI_LEGACY=y
  1. CONFIG_PCI_STUB is not set
  2. CONFIG_PCI_IOV is not set
  3. CONFIG_PCCARD is not set
  1. Kernel Features
  2. CONFIG_NO_HZ is not set
  3. CONFIG_HIGH_RES_TIMERS is not set
CONFIG_GENERIC_CLOCKEVENTS_BUILD=y CONFIG_VMSPLIT_3G=y
  1. CONFIG_VMSPLIT_2G is not set
  2. CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0xC0000000 CONFIG_PREEMPT_NONE=y
  1. CONFIG_PREEMPT_VOLUNTARY is not set
  2. CONFIG_PREEMPT is not set
CONFIG_HZ=100 CONFIG_AEABI=y CONFIG_OABI_COMPAT=y
  1. CONFIG_ARCH_HAS_HOLES_MEMORYMODEL is not set
CONFIG_REORDER=y
  1. CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
  2. CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
  3. CONFIG_HIGHMEM is not set
CONFIG_SELECT_MEMORY_MODEL=y CONFIG_FLATMEM_MANUAL=y
  1. CONFIG_DISCONTIGMEM_MANUAL is not set
  2. CONFIG_SPARSEMEM_MANUAL is not set
CONFIG_FLATMEM=y CONFIG_FLAT_NODE_MEM_MAP=y CONFIG_PAGEFLAGS_EXTENDED=y CONFIG_SPLIT_PTLOCK_CPUS=4096
  1. CONFIG_PHYS_ADDR_T_64BIT is not set
CONFIG_ZONE_DMA_FLAG=0 CONFIG_VIRT_TO_BUS=y CONFIG_HAVE_MLOCK=y CONFIG_HAVE_MLOCKED_PAGE_BIT=y
  1. CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
  1. CONFIG_LEDS is not set
CONFIG_ALIGNMENT_TRAP=y
  1. CONFIG_COPY_USER_MEMCPY is not set
CONFIG_UACCESS_WITH_MEMCPY=y
  1. Boot options
CONFIG_ZBOOT_ROM_TEXT=0x0 CONFIG_ZBOOT_ROM_BSS=0x0 CONFIG_CMDLINE=""
  1. CONFIG_XIP_KERNEL is not set
  2. CONFIG_KEXEC is not set
  1. CPU Power Management
CONFIG_CPU_FREQ=y CONFIG_CPU_FREQ_TABLE=m
  1. CONFIG_CPU_FREQ_DEBUG is not set
CONFIG_CPU_FREQ_STAT=m
  1. CONFIG_CPU_FREQ_STAT_DETAILS is not set
  2. CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
  3. CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE=y
  1. CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
  2. CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=m CONFIG_CPU_FREQ_GOV_POWERSAVE=m CONFIG_CPU_FREQ_GOV_USERSPACE=y
  1. CONFIG_CPU_FREQ_GOV_ONDEMAND is not set
  2. CONFIG_CPU_FREQ_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_FEROCEON_KW=m CONFIG_CPU_IDLE=y CONFIG_CPU_IDLE_GOV_LADDER=y
  1. Floating point emulation
  1. At least one emulation must be selected
  2. CONFIG_FPE_NWFPE is not set
  3. CONFIG_FPE_FASTFPE is not set
  4. CONFIG_VFP is not set
  1. Userspace binary formats
CONFIG_BINFMT_ELF=y
  1. CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
CONFIG_HAVE_AOUT=y
  1. CONFIG_BINFMT_AOUT is not set
  2. CONFIG_BINFMT_MISC is not set
  1. Power management options
  2. CONFIG_PM is not set
CONFIG_ARCH_SUSPEND_POSSIBLE=y CONFIG_NET=y
  1. Networking options
CONFIG_PACKET=y
  1. CONFIG_PACKET_MMAP is not set
CONFIG_UNIX=y CONFIG_XFRM=y CONFIG_XFRM_USER=m
  1. CONFIG_XFRM_SUB_POLICY is not set
  2. CONFIG_XFRM_MIGRATE is not set
  3. CONFIG_XFRM_STATISTICS is not set
CONFIG_XFRM_IPCOMP=m CONFIG_NET_KEY=y
  1. CONFIG_NET_KEY_MIGRATE is not set
CONFIG_INET=y CONFIG_IP_MULTICAST=y
  1. CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_FIB_HASH=y CONFIG_IP_PNP=y CONFIG_IP_PNP_DHCP=y
  1. CONFIG_IP_PNP_BOOTP is not set
  2. CONFIG_IP_PNP_RARP is not set
  3. CONFIG_NET_IPIP is not set
CONFIG_NET_IPGRE=m CONFIG_NET_IPGRE_BROADCAST=y
  1. CONFIG_IP_MROUTE is not set
  2. CONFIG_ARPD is not set
CONFIG_SYN_COOKIES=y CONFIG_INET_AH=m CONFIG_INET_ESP=m CONFIG_INET_IPCOMP=m CONFIG_INET_XFRM_TUNNEL=m CONFIG_INET_TUNNEL=m CONFIG_INET_XFRM_MODE_TRANSPORT=m CONFIG_INET_XFRM_MODE_TUNNEL=m CONFIG_INET_XFRM_MODE_BEET=m
  1. CONFIG_INET_LRO is not set
CONFIG_INET_DIAG=y CONFIG_INET_TCP_DIAG=y
  1. CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y CONFIG_DEFAULT_TCP_CONG="cubic"
  1. CONFIG_TCP_MD5SIG is not set
CONFIG_IPV6=m CONFIG_IPV6_PRIVACY=y CONFIG_IPV6_ROUTER_PREF=y
  1. CONFIG_IPV6_ROUTE_INFO is not set
CONFIG_IPV6_OPTIMISTIC_DAD=y CONFIG_INET6_AH=m CONFIG_INET6_ESP=m CONFIG_INET6_IPCOMP=m
  1. CONFIG_IPV6_MIP6 is not set
CONFIG_INET6_XFRM_TUNNEL=m CONFIG_INET6_TUNNEL=m CONFIG_INET6_XFRM_MODE_TRANSPORT=m CONFIG_INET6_XFRM_MODE_TUNNEL=m CONFIG_INET6_XFRM_MODE_BEET=m
  1. CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION is not set
  2. CONFIG_IPV6_SIT is not set
  3. CONFIG_IPV6_TUNNEL is not set
  4. CONFIG_IPV6_MULTIPLE_TABLES is not set
CONFIG_IPV6_MROUTE=y CONFIG_IPV6_PIMSM_V2=y
  1. CONFIG_NETWORK_SECMARK is not set
CONFIG_NETFILTER=y
  1. CONFIG_NETFILTER_DEBUG is not set
CONFIG_NETFILTER_ADVANCED=y CONFIG_BRIDGE_NETFILTER=y
  1. Core Netfilter Configuration
  2. CONFIG_NETFILTER_NETLINK_QUEUE is not set
  3. CONFIG_NETFILTER_NETLINK_LOG is not set
CONFIG_NF_CONNTRACK=m
  1. CONFIG_NF_CT_ACCT is not set
  2. CONFIG_NF_CONNTRACK_MARK is not set
  3. CONFIG_NF_CONNTRACK_EVENTS is not set
  4. CONFIG_NF_CT_PROTO_DCCP is not set
CONFIG_NF_CT_PROTO_GRE=m
  1. CONFIG_NF_CT_PROTO_SCTP is not set
  2. CONFIG_NF_CT_PROTO_UDPLITE is not set
  3. CONFIG_NF_CONNTRACK_AMANDA is not set
  4. CONFIG_NF_CONNTRACK_FTP is not set
  5. CONFIG_NF_CONNTRACK_H323 is not set
  6. CONFIG_NF_CONNTRACK_IRC is not set
  7. CONFIG_NF_CONNTRACK_NETBIOS_NS is not set
CONFIG_NF_CONNTRACK_PPTP=m
  1. CONFIG_NF_CONNTRACK_SANE is not set
  2. CONFIG_NF_CONNTRACK_SIP is not set
  3. CONFIG_NF_CONNTRACK_TFTP is not set
  4. CONFIG_NF_CT_NETLINK is not set
  5. CONFIG_NETFILTER_TPROXY is not set
CONFIG_NETFILTER_XTABLES=m
  1. CONFIG_NETFILTER_XT_TARGET_CLASSIFY is not set
  2. CONFIG_NETFILTER_XT_TARGET_CONNMARK is not set
  3. CONFIG_NETFILTER_XT_TARGET_DSCP is not set
  4. CONFIG_NETFILTER_XT_TARGET_HL is not set
  5. CONFIG_NETFILTER_XT_TARGET_LED is not set
CONFIG_NETFILTER_XT_TARGET_MARK=m
  1. CONFIG_NETFILTER_XT_TARGET_NFLOG is not set
  2. CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set
  3. CONFIG_NETFILTER_XT_TARGET_RATEEST is not set
  4. CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set
  5. CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP is not set
  6. CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set
  7. CONFIG_NETFILTER_XT_MATCH_COMMENT is not set
  8. CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set
  9. CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set
  10. CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set
  11. CONFIG_NETFILTER_XT_MATCH_CONNTRACK is not set
  12. CONFIG_NETFILTER_XT_MATCH_DCCP is not set
  13. CONFIG_NETFILTER_XT_MATCH_DSCP is not set
  14. CONFIG_NETFILTER_XT_MATCH_ESP is not set
  15. CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set
  16. CONFIG_NETFILTER_XT_MATCH_HELPER is not set
  17. CONFIG_NETFILTER_XT_MATCH_HL is not set
  18. CONFIG_NETFILTER_XT_MATCH_IPRANGE is not set
  19. CONFIG_NETFILTER_XT_MATCH_LENGTH is not set
CONFIG_NETFILTER_XT_MATCH_LIMIT=m CONFIG_NETFILTER_XT_MATCH_MAC=m
  1. CONFIG_NETFILTER_XT_MATCH_MARK is not set
CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
  1. CONFIG_NETFILTER_XT_MATCH_OWNER is not set
  2. CONFIG_NETFILTER_XT_MATCH_POLICY is not set
  3. CONFIG_NETFILTER_XT_MATCH_PHYSDEV is not set
  4. CONFIG_NETFILTER_XT_MATCH_PKTTYPE is not set
  5. CONFIG_NETFILTER_XT_MATCH_QUOTA is not set
  6. CONFIG_NETFILTER_XT_MATCH_RATEEST is not set
  7. CONFIG_NETFILTER_XT_MATCH_REALM is not set
  8. CONFIG_NETFILTER_XT_MATCH_RECENT is not set
  9. CONFIG_NETFILTER_XT_MATCH_SCTP is not set
CONFIG_NETFILTER_XT_MATCH_STATE=m
  1. CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set
  2. CONFIG_NETFILTER_XT_MATCH_STRING is not set
  3. CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set
  4. CONFIG_NETFILTER_XT_MATCH_TIME is not set
  5. CONFIG_NETFILTER_XT_MATCH_U32 is not set
  6. CONFIG_IP_VS is not set
  1. IP: Netfilter Configuration
CONFIG_NF_DEFRAG_IPV4=m CONFIG_NF_CONNTRACK_IPV4=m
  1. CONFIG_NF_CONNTRACK_PROC_COMPAT is not set
  2. CONFIG_IP_NF_QUEUE is not set
CONFIG_IP_NF_IPTABLES=m
  1. CONFIG_IP_NF_MATCH_ADDRTYPE is not set
  2. CONFIG_IP_NF_MATCH_AH is not set
  3. CONFIG_IP_NF_MATCH_ECN is not set
  4. CONFIG_IP_NF_MATCH_TTL is not set
CONFIG_IP_NF_FILTER=m
  1. CONFIG_IP_NF_TARGET_REJECT is not set
CONFIG_IP_NF_TARGET_LOG=m
  1. CONFIG_IP_NF_TARGET_ULOG is not set
CONFIG_NF_NAT=m CONFIG_NF_NAT_NEEDED=y CONFIG_IP_NF_TARGET_MASQUERADE=m
  1. CONFIG_IP_NF_TARGET_NETMAP is not set
CONFIG_IP_NF_TARGET_REDIRECT=m
  1. CONFIG_NF_NAT_SNMP_BASIC is not set
CONFIG_NF_NAT_PROTO_GRE=m
  1. CONFIG_NF_NAT_FTP is not set
  2. CONFIG_NF_NAT_IRC is not set
  3. CONFIG_NF_NAT_TFTP is not set
  4. CONFIG_NF_NAT_AMANDA is not set
CONFIG_NF_NAT_PPTP=m
  1. CONFIG_NF_NAT_H323 is not set
  2. CONFIG_NF_NAT_SIP is not set
CONFIG_IP_NF_MANGLE=m
  1. CONFIG_IP_NF_TARGET_CLUSTERIP is not set
  2. CONFIG_IP_NF_TARGET_ECN is not set
  3. CONFIG_IP_NF_TARGET_TTL is not set
  4. CONFIG_IP_NF_RAW is not set
  5. CONFIG_IP_NF_ARPTABLES is not set
  1. IPv6: Netfilter Configuration
CONFIG_NF_CONNTRACK_IPV6=m
  1. CONFIG_IP6_NF_QUEUE is not set
CONFIG_IP6_NF_IPTABLES=m
  1. CONFIG_IP6_NF_MATCH_AH is not set
  2. CONFIG_IP6_NF_MATCH_EUI64 is not set
  3. CONFIG_IP6_NF_MATCH_FRAG is not set
  4. CONFIG_IP6_NF_MATCH_OPTS is not set
  5. CONFIG_IP6_NF_MATCH_HL is not set
  6. CONFIG_IP6_NF_MATCH_IPV6HEADER is not set
  7. CONFIG_IP6_NF_MATCH_MH is not set
  8. CONFIG_IP6_NF_MATCH_RT is not set
  9. CONFIG_IP6_NF_TARGET_HL is not set
CONFIG_IP6_NF_TARGET_LOG=m CONFIG_IP6_NF_FILTER=m
  1. CONFIG_IP6_NF_TARGET_REJECT is not set
CONFIG_IP6_NF_MANGLE=m
  1. CONFIG_IP6_NF_RAW is not set
  2. CONFIG_BRIDGE_NF_EBTABLES is not set
  3. CONFIG_IP_DCCP is not set
  4. CONFIG_IP_SCTP is not set
  5. CONFIG_RDS is not set
  6. CONFIG_TIPC is not set
  7. CONFIG_ATM is not set
CONFIG_STP=m CONFIG_BRIDGE=m
  1. CONFIG_NET_DSA is not set
CONFIG_VLAN_8021Q=m
  1. CONFIG_VLAN_8021Q_GVRP is not set
  2. CONFIG_DECNET is not set
CONFIG_LLC=m
  1. CONFIG_LLC2 is not set
  2. CONFIG_IPX is not set
CONFIG_ATALK=m
  1. CONFIG_DEV_APPLETALK is not set
  2. CONFIG_X25 is not set
  3. CONFIG_LAPB is not set
  4. CONFIG_ECONET is not set
  5. CONFIG_WAN_ROUTER is not set
  6. CONFIG_PHONET is not set
  7. CONFIG_IEEE802154 is not set
CONFIG_NET_SCHED=y
  1. Queueing/Scheduling
  2. CONFIG_NET_SCH_CBQ is not set
CONFIG_NET_SCH_HTB=m
  1. CONFIG_NET_SCH_HFSC is not set
  2. CONFIG_NET_SCH_PRIO is not set
  3. CONFIG_NET_SCH_MULTIQ is not set
  4. CONFIG_NET_SCH_RED is not set
CONFIG_NET_SCH_SFQ=m
  1. CONFIG_NET_SCH_TEQL is not set
  2. CONFIG_NET_SCH_TBF is not set
  3. CONFIG_NET_SCH_GRED is not set
  4. CONFIG_NET_SCH_DSMARK is not set
  5. CONFIG_NET_SCH_NETEM is not set
  6. CONFIG_NET_SCH_DRR is not set
  1. Classification
CONFIG_NET_CLS=y
  1. CONFIG_NET_CLS_BASIC is not set
  2. CONFIG_NET_CLS_TCINDEX is not set
  3. CONFIG_NET_CLS_ROUTE4 is not set
CONFIG_NET_CLS_FW=m CONFIG_NET_CLS_U32=m
  1. CONFIG_CLS_U32_PERF is not set
  2. CONFIG_CLS_U32_MARK is not set
  3. CONFIG_NET_CLS_RSVP is not set
  4. CONFIG_NET_CLS_RSVP6 is not set
  5. CONFIG_NET_CLS_FLOW is not set
  6. CONFIG_NET_EMATCH is not set
  7. CONFIG_NET_CLS_ACT is not set
  8. CONFIG_NET_CLS_IND is not set
CONFIG_NET_SCH_FIFO=y
  1. CONFIG_DCB is not set
  1. Network testing
  2. CONFIG_NET_PKTGEN is not set
  3. CONFIG_HAMRADIO is not set
  4. CONFIG_CAN is not set
  5. CONFIG_IRDA is not set
  6. CONFIG_BT is not set
  7. CONFIG_AF_RXRPC is not set
CONFIG_WIRELESS=y
  1. CONFIG_CFG80211 is not set
CONFIG_CFG80211_DEFAULT_PS_VALUE=0
  1. CONFIG_WIRELESS_OLD_REGULATORY is not set
CONFIG_WIRELESS_EXT=y CONFIG_WIRELESS_EXT_SYSFS=y
  1. CONFIG_LIB80211 is not set
  1. CFG80211 needs to be enabled for MAC80211
  2. CONFIG_WIMAX is not set
CONFIG_RFKILL=m CONFIG_RFKILL_LEDS=y CONFIG_RFKILL_INPUT=y
  1. CONFIG_NET_9P is not set
  1. Device Drivers
  1. Generic Driver Options
CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
  1. CONFIG_DEVTMPFS is not set
CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y CONFIG_FW_LOADER=y CONFIG_FIRMWARE_IN_KERNEL=y CONFIG_EXTRA_FIRMWARE=""
  1. CONFIG_SYS_HYPERVISOR is not set
CONFIG_CONNECTOR=m CONFIG_MTD=y
  1. CONFIG_MTD_DEBUG is not set
  2. CONFIG_MTD_TESTS is not set
  3. CONFIG_MTD_CONCAT is not set
CONFIG_MTD_PARTITIONS=y CONFIG_MTD_REDBOOT_PARTS=y CONFIG_MTD_REDBOOT_DIRECTORY_BLOCK=-1
  1. CONFIG_MTD_REDBOOT_PARTS_UNALLOCATED is not set
  2. CONFIG_MTD_REDBOOT_PARTS_READONLY is not set
  3. CONFIG_MTD_CMDLINE_PARTS is not set
  4. CONFIG_MTD_AFS_PARTS is not set
  5. CONFIG_MTD_AR7_PARTS is not set
  1. User Modules And Translation Layers
CONFIG_MTD_CHAR=y CONFIG_MTD_BLKDEVS=y CONFIG_MTD_BLOCK=y
  1. CONFIG_FTL is not set
  2. CONFIG_NFTL is not set
  3. CONFIG_INFTL is not set
  4. CONFIG_RFD_FTL is not set
  5. CONFIG_SSFDC is not set
  6. CONFIG_MTD_OOPS is not set
  1. RAM/ROM/Flash chip drivers
CONFIG_MTD_CFI=y
  1. CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_GEN_PROBE=y
  1. CONFIG_MTD_CFI_ADV_OPTIONS is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y CONFIG_MTD_MAP_BANK_WIDTH_2=y CONFIG_MTD_MAP_BANK_WIDTH_4=y
  1. CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
  2. CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
  3. CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y CONFIG_MTD_CFI_I2=y
  1. CONFIG_MTD_CFI_I4 is not set
  2. CONFIG_MTD_CFI_I8 is not set
  3. CONFIG_MTD_CFI_INTELEXT is not set
  4. CONFIG_MTD_CFI_AMDSTD is not set
  5. CONFIG_MTD_CFI_STAA is not set
CONFIG_MTD_CFI_UTIL=y
  1. CONFIG_MTD_RAM is not set
  2. CONFIG_MTD_ROM is not set
  3. CONFIG_MTD_ABSENT is not set
  1. Mapping drivers for chip access
  2. CONFIG_MTD_COMPLEX_MAPPINGS is not set
CONFIG_MTD_PHYSMAP=y CONFIG_MTD_PHYSMAP_COMPAT=y CONFIG_MTD_PHYSMAP_START=0xf8000000 CONFIG_MTD_PHYSMAP_LEN=0x400000 CONFIG_MTD_PHYSMAP_BANKWIDTH=1
  1. CONFIG_MTD_ARM_INTEGRATOR is not set
  2. CONFIG_MTD_INTEL_VR_NOR is not set
  3. CONFIG_MTD_PLATRAM is not set
CONFIG_SYNO_MTD_PHYMAPS=y
  1. Self-contained MTD device drivers
  2. CONFIG_MTD_PMC551 is not set
  3. CONFIG_MTD_SLRAM is not set
  4. CONFIG_MTD_PHRAM is not set
  5. CONFIG_MTD_MTDRAM is not set
  6. CONFIG_MTD_BLOCK2MTD is not set
  1. Disk-On-Chip Device Drivers
  2. CONFIG_MTD_DOC2000 is not set
  3. CONFIG_MTD_DOC2001 is not set
  4. CONFIG_MTD_DOC2001PLUS is not set
  5. CONFIG_MTD_NAND is not set
  6. CONFIG_MTD_ONENAND is not set
  1. LPDDR flash memory drivers
  2. CONFIG_MTD_LPDDR is not set
  1. UBI - Unsorted block images
  2. CONFIG_MTD_UBI is not set
  3. CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
  1. CONFIG_BLK_CPQ_DA is not set
  2. CONFIG_BLK_CPQ_CISS_DA is not set
  3. CONFIG_BLK_DEV_DAC960 is not set
  4. CONFIG_BLK_DEV_UMEM is not set
  5. CONFIG_BLK_DEV_COW_COMMON is not set
CONFIG_BLK_DEV_LOOP=m
  1. CONFIG_BLK_DEV_CRYPTOLOOP is not set
  2. CONFIG_BLK_DEV_NBD is not set
  3. CONFIG_BLK_DEV_SX8 is not set
  4. CONFIG_BLK_DEV_UB is not set
CONFIG_BLK_DEV_RAM=y CONFIG_BLK_DEV_RAM_COUNT=16 CONFIG_BLK_DEV_RAM_SIZE=65536
  1. CONFIG_BLK_DEV_XIP is not set
  2. CONFIG_CDROM_PKTCDVD is not set
  3. CONFIG_ATA_OVER_ETH is not set
  4. CONFIG_MG_DISK is not set
  5. CONFIG_MISC_DEVICES is not set
CONFIG_HAVE_IDE=y
  1. CONFIG_IDE is not set
  1. SCSI device support
  2. CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=y CONFIG_SCSI_DMA=y
  1. CONFIG_SCSI_TGT is not set
  2. CONFIG_SCSI_NETLINK is not set
CONFIG_SCSI_PROC_FS=y
  1. SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
  1. CONFIG_CHR_DEV_ST is not set
  2. CONFIG_CHR_DEV_OSST is not set
  3. CONFIG_BLK_DEV_SR is not set
CONFIG_CHR_DEV_SG=m CONFIG_CHR_DEV_SCH=m CONFIG_SCSI_MULTI_LUN=y
  1. CONFIG_SCSI_CONSTANTS is not set
  2. CONFIG_SCSI_LOGGING is not set
  3. CONFIG_SCSI_SCAN_ASYNC is not set
CONFIG_SCSI_WAIT_SCAN=m
  1. CONFIG_MV_SCATTERED_SPINUP is not set
  1. SCSI Transports
  2. CONFIG_SCSI_SPI_ATTRS is not set
  3. CONFIG_SCSI_FC_ATTRS is not set
  4. CONFIG_SCSI_ISCSI_ATTRS is not set
  5. CONFIG_SCSI_SAS_ATTRS is not set
  6. CONFIG_SCSI_SAS_LIBSAS is not set
  7. CONFIG_SCSI_SRP_ATTRS is not set
  8. CONFIG_SCSI_LOWLEVEL is not set
  9. CONFIG_SCSI_DH is not set
  10. CONFIG_SCSI_OSD_INITIATOR is not set
CONFIG_ATA=y
  1. CONFIG_ATA_NONSTANDARD is not set
CONFIG_ATA_VERBOSE_ERROR=y CONFIG_SATA_PMP=y CONFIG_SATA_AHCI=y
  1. CONFIG_SATA_SIL24 is not set
  2. CONFIG_SATA_OX820_DIRECT_SINGLE is not set
  3. CONFIG_SATA_OX820_DIRECT_HWRAID is not set
CONFIG_ATA_SFF=y
  1. CONFIG_SATA_SVW is not set
  2. CONFIG_ATA_PIIX is not set
CONFIG_SATA_MV=y
  1. CONFIG_SCSI_MVSATA_BSP422 is not set
  2. CONFIG_SATA_NV is not set
  3. CONFIG_PDC_ADMA is not set
  4. CONFIG_SATA_QSTOR is not set
  5. CONFIG_SATA_PROMISE is not set
  6. CONFIG_SATA_SX4 is not set
  7. CONFIG_SATA_SIL is not set
  8. CONFIG_SATA_SIS is not set
  9. CONFIG_SATA_ULI is not set
  10. CONFIG_SATA_VIA is not set
  11. CONFIG_SATA_VITESSE is not set
  12. CONFIG_SATA_INIC162X is not set
  13. CONFIG_PATA_ALI is not set
  14. CONFIG_PATA_AMD is not set
  15. CONFIG_PATA_ARTOP is not set
  16. CONFIG_PATA_ATP867X is not set
  17. CONFIG_PATA_ATIIXP is not set
  18. CONFIG_PATA_CMD640_PCI is not set
  19. CONFIG_PATA_CMD64X is not set
  20. CONFIG_PATA_CS5520 is not set
  21. CONFIG_PATA_CS5530 is not set
  22. CONFIG_PATA_CYPRESS is not set
  23. CONFIG_PATA_EFAR is not set
  24. CONFIG_ATA_GENERIC is not set
  25. CONFIG_PATA_HPT366 is not set
  26. CONFIG_PATA_HPT37X is not set
  27. CONFIG_PATA_HPT3X2N is not set
  28. CONFIG_PATA_HPT3X3 is not set
  29. CONFIG_PATA_IT821X is not set
  30. CONFIG_PATA_IT8213 is not set
  31. CONFIG_PATA_JMICRON is not set
  32. CONFIG_PATA_TRIFLEX is not set
  33. CONFIG_PATA_MARVELL is not set
  34. CONFIG_PATA_MPIIX is not set
  35. CONFIG_PATA_OLDPIIX is not set
  36. CONFIG_PATA_NETCELL is not set
  37. CONFIG_PATA_NINJA32 is not set
  38. CONFIG_PATA_NS87410 is not set
  39. CONFIG_PATA_NS87415 is not set
  40. CONFIG_PATA_OPTI is not set
  41. CONFIG_PATA_OPTIDMA is not set
  42. CONFIG_PATA_PDC_OLD is not set
  43. CONFIG_PATA_RADISYS is not set
  44. CONFIG_PATA_RDC is not set
  45. CONFIG_PATA_RZ1000 is not set
  46. CONFIG_PATA_SC1200 is not set
  47. CONFIG_PATA_SERVERWORKS is not set
  48. CONFIG_PATA_PDC2027X is not set
  49. CONFIG_PATA_SIL680 is not set
  50. CONFIG_PATA_SIS is not set
  51. CONFIG_PATA_VIA is not set
  52. CONFIG_PATA_WINBOND is not set
  53. CONFIG_PATA_PLATFORM is not set
  54. CONFIG_PATA_SCH is not set
CONFIG_MD=y CONFIG_BLK_DEV_MD=y CONFIG_MD_AUTODETECT=y CONFIG_MD_LINEAR=y CONFIG_MD_RAID0=y CONFIG_MD_RAID1=y CONFIG_MD_RAID10=y CONFIG_MD_RAID456=y CONFIG_MD_RAID6_PQ=y
  1. CONFIG_ASYNC_RAID6_TEST is not set
  2. CONFIG_MD_MULTIPATH is not set
  3. CONFIG_MD_FAULTY is not set
CONFIG_BLK_DEV_DM=y
  1. CONFIG_DM_DEBUG is not set
  2. CONFIG_DM_CRYPT is not set
CONFIG_DM_SNAPSHOT=m
  1. CONFIG_DM_MIRROR is not set
  2. CONFIG_DM_ZERO is not set
  3. CONFIG_DM_MULTIPATH is not set
  4. CONFIG_DM_DELAY is not set
  5. CONFIG_DM_UEVENT is not set
CONFIG_TARGET_CORE=m CONFIG_SYNO_LIO=y CONFIG_TCM_IBLOCK=m
  1. CONFIG_TCM_PSCSI is not set
CONFIG_TCM_FILEIO=m CONFIG_TCM_RAMDISK=m
  1. CONFIG_TCM_STGT is not set
CONFIG_TCM_SNMP=m
  1. CONFIG_TCM_DEBUG_DEV is not set
  2. CONFIG_TCM_LOOP_FABRIC is not set
CONFIG_LIO_TARGET=m CONFIG_LIO_TARGET_SNMP=m
  1. CONFIG_LIO_TARGET_DEBUG is not set
  2. CONFIG_LIO_TARGET_DEBUG_ERL is not set
  3. CONFIG_FUSION is not set
  1. IEEE 1394 (FireWire) support
  1. You can enable one or both FireWire driver stacks.
  1. See the help texts for more information.
  2. CONFIG_FIREWIRE is not set
  3. CONFIG_IEEE1394 is not set
  4. CONFIG_I2O is not set
CONFIG_NETDEVICES=y
  1. CONFIG_DUMMY is not set
CONFIG_BONDING=m
  1. CONFIG_MACVLAN is not set
  2. CONFIG_EQUALIZER is not set
CONFIG_TUN=m
  1. CONFIG_VETH is not set
  2. CONFIG_ARCNET is not set
  3. CONFIG_NET_ETHERNET is not set
CONFIG_MII=m CONFIG_NETDEV_1000=y
  1. CONFIG_ACENIC is not set
  2. CONFIG_DL2K is not set
  3. CONFIG_E1000 is not set
  4. CONFIG_E1000E is not set
  5. CONFIG_IP1000 is not set
  6. CONFIG_IGB is not set
  7. CONFIG_IGB_2_6_34 is not set
  8. CONFIG_IGBVF is not set
  9. CONFIG_NS83820 is not set
  10. CONFIG_HAMACHI is not set
  11. CONFIG_YELLOWFIN is not set
  12. CONFIG_R8169 is not set
  13. CONFIG_SIS190 is not set
  14. CONFIG_SKGE is not set
CONFIG_SKY2=m
  1. CONFIG_VIA_VELOCITY is not set
  2. CONFIG_SK98LIN is not set
  3. CONFIG_TIGON3 is not set
  4. CONFIG_BNX2 is not set
  5. CONFIG_CNIC is not set
  6. CONFIG_QLA3XXX is not set
  7. CONFIG_ATL1 is not set
  8. CONFIG_ATL1E is not set
  9. CONFIG_ATL1C is not set
  10. CONFIG_JME is not set
  11. CONFIG_NETDEV_10000 is not set
  12. CONFIG_TR is not set
CONFIG_WLAN=y
  1. CONFIG_WLAN_PRE80211 is not set
  2. CONFIG_WLAN_80211 is not set
  1. Enable WiMAX (Networking options) to see the WiMAX drivers
  1. USB Network Adapters
  2. CONFIG_USB_CATC is not set
  3. CONFIG_USB_KAWETH is not set
  4. CONFIG_USB_PEGASUS is not set
  5. CONFIG_USB_RTL8150 is not set
CONFIG_USB_USBNET=m
  1. CONFIG_USB_NET_AX8817X is not set
CONFIG_USB_NET_CDCETHER=m
  1. CONFIG_USB_NET_CDC_EEM is not set
  2. CONFIG_USB_NET_DM9601 is not set
  3. CONFIG_USB_NET_SMSC95XX is not set
  4. CONFIG_USB_NET_GL620A is not set
  5. CONFIG_USB_NET_NET1080 is not set
  6. CONFIG_USB_NET_PLUSB is not set
  7. CONFIG_USB_NET_MCS7830 is not set
  8. CONFIG_USB_NET_RNDIS_HOST is not set
  9. CONFIG_USB_NET_CDC_SUBSET is not set
  10. CONFIG_USB_NET_ZAURUS is not set
CONFIG_USB_NET_QMI_WWAN=m
  1. CONFIG_USB_HSO is not set
  2. CONFIG_USB_NET_INT51X1 is not set
  3. CONFIG_WAN is not set
  4. CONFIG_FDDI is not set
  5. CONFIG_HIPPI is not set
CONFIG_PPP=m
  1. CONFIG_PPP_MULTILINK is not set
  2. CONFIG_PPP_FILTER is not set
CONFIG_PPP_ASYNC=m
  1. CONFIG_PPP_SYNC_TTY is not set
CONFIG_PPP_DEFLATE=m CONFIG_PPP_BSDCOMP=m CONFIG_PPP_MPPE=m
  1. CONFIG_PPPOE is not set
  2. CONFIG_PPPOL2TP is not set
  3. CONFIG_SLIP is not set
CONFIG_SLHC=m
  1. CONFIG_NET_FC is not set
  2. CONFIG_NETCONSOLE is not set
  3. CONFIG_NETPOLL is not set
  4. CONFIG_NET_POLL_CONTROLLER is not set
  5. CONFIG_ISDN is not set
  6. CONFIG_PHONE is not set
  1. Input device support
CONFIG_INPUT=y
  1. CONFIG_INPUT_FF_MEMLESS is not set
  2. CONFIG_INPUT_POLLDEV is not set
  1. Userland interfaces
  2. CONFIG_INPUT_MOUSEDEV is not set
  3. CONFIG_INPUT_JOYDEV is not set
  4. CONFIG_INPUT_EVDEV is not set
  5. CONFIG_INPUT_EVBUG is not set
  1. Input Device Drivers
  2. CONFIG_INPUT_KEYBOARD is not set
  3. CONFIG_INPUT_MOUSE is not set
  4. CONFIG_INPUT_JOYSTICK is not set
  5. CONFIG_INPUT_TABLET is not set
  6. CONFIG_INPUT_TOUCHSCREEN is not set
  7. CONFIG_INPUT_MISC is not set
  1. Hardware I/O ports
  2. CONFIG_SERIO is not set
  3. CONFIG_GAMEPORT is not set
  1. Character devices
CONFIG_VT=y CONFIG_CONSOLE_TRANSLATIONS=y CONFIG_VT_CONSOLE=y CONFIG_HW_CONSOLE=y
  1. CONFIG_VT_HW_CONSOLE_BINDING is not set
CONFIG_DEVKMEM=y
  1. CONFIG_SERIAL_NONSTANDARD is not set
  2. CONFIG_NOZOMI is not set
  1. Serial drivers
CONFIG_SERIAL_8250=y CONFIG_SERIAL_8250_CONSOLE=y CONFIG_SERIAL_8250_PCI=y CONFIG_SERIAL_8250_NR_UARTS=4 CONFIG_SERIAL_8250_RUNTIME_UARTS=4
  1. CONFIG_SERIAL_8250_EXTENDED is not set
  1. Non-8250 serial port support
CONFIG_SERIAL_CORE=y CONFIG_SERIAL_CORE_CONSOLE=y
  1. CONFIG_SERIAL_JSM is not set
CONFIG_UNIX98_PTYS=y
  1. CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
CONFIG_LEGACY_PTYS=y CONFIG_LEGACY_PTY_COUNT=16
  1. CONFIG_IPMI_HANDLER is not set
CONFIG_HW_RANDOM=m
  1. CONFIG_HW_RANDOM_TIMERIOMEM is not set
  2. CONFIG_R3964 is not set
  3. CONFIG_APPLICOM is not set
  4. CONFIG_RAW_DRIVER is not set
  5. CONFIG_TCG_TPM is not set
CONFIG_DEVPORT=y CONFIG_I2C=m CONFIG_I2C_BOARDINFO=y CONFIG_I2C_COMPAT=y
  1. CONFIG_I2C_CHARDEV is not set
CONFIG_I2C_HELPER_AUTO=y
  1. I2C Hardware Bus support
  1. PC SMBus host controller drivers
  2. CONFIG_I2C_ALI1535 is not set
  3. CONFIG_I2C_ALI1563 is not set
  4. CONFIG_I2C_ALI15X3 is not set
  5. CONFIG_I2C_AMD756 is not set
  6. CONFIG_I2C_AMD8111 is not set
  7. CONFIG_I2C_I801 is not set
  8. CONFIG_I2C_ISCH is not set
  9. CONFIG_I2C_PIIX4 is not set
  10. CONFIG_I2C_NFORCE2 is not set
  11. CONFIG_I2C_SIS5595 is not set
  12. CONFIG_I2C_SIS630 is not set
  13. CONFIG_I2C_SIS96X is not set
  14. CONFIG_I2C_VIA is not set
  15. CONFIG_I2C_VIAPRO is not set
  1. I2C system bus drivers (mostly embedded / system-on-chip)
  2. CONFIG_I2C_GPIO is not set
  3. CONFIG_I2C_MV64XXX is not set
  4. CONFIG_I2C_OCORES is not set
  5. CONFIG_I2C_SIMTEC is not set
  1. External I2C/SMBus adapter drivers
  2. CONFIG_I2C_PARPORT_LIGHT is not set
  3. CONFIG_I2C_TAOS_EVM is not set
  4. CONFIG_I2C_TINY_USB is not set
  1. Graphics adapter I2C/DDC channel drivers
  2. CONFIG_I2C_VOODOO3 is not set
  1. Other I2C/SMBus bus drivers
  2. CONFIG_I2C_PCA_PLATFORM is not set
  3. CONFIG_I2C_STUB is not set
  1. Miscellaneous I2C Chip support
  2. CONFIG_DS1682 is not set
  3. CONFIG_SENSORS_TSL2550 is not set
  4. CONFIG_I2C_DEBUG_CORE is not set
  5. CONFIG_I2C_DEBUG_ALGO is not set
  6. CONFIG_I2C_DEBUG_BUS is not set
  7. CONFIG_I2C_DEBUG_CHIP is not set
  8. CONFIG_SPI is not set
  1. PPS support
  2. CONFIG_PPS is not set
CONFIG_ARCH_REQUIRE_GPIOLIB=y CONFIG_GPIOLIB=y CONFIG_GPIO_SYSFS=y
  1. Memory mapped GPIO expanders:
  1. I2C GPIO expanders:
  2. CONFIG_GPIO_MAX732X is not set
  3. CONFIG_GPIO_PCA953X is not set
  4. CONFIG_GPIO_PCF857X is not set
  1. PCI GPIO expanders:
  2. CONFIG_GPIO_BT8XX is not set
  3. CONFIG_GPIO_LANGWELL is not set
  1. SPI GPIO expanders:
  1. AC97 GPIO expanders:
  2. CONFIG_W1 is not set
  3. CONFIG_POWER_SUPPLY is not set
  4. CONFIG_HWMON is not set
  5. CONFIG_THERMAL is not set
  6. CONFIG_WATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
  1. Sonics Silicon Backplane
CONFIG_SSB=m CONFIG_SSB_SPROM=y CONFIG_SSB_PCIHOST_POSSIBLE=y CONFIG_SSB_PCIHOST=y
  1. CONFIG_SSB_B43_PCI_BRIDGE is not set
  2. CONFIG_SSB_SILENT is not set
  3. CONFIG_SSB_DEBUG is not set
CONFIG_SSB_DRIVER_PCICORE_POSSIBLE=y
  1. CONFIG_SSB_DRIVER_PCICORE is not set
  1. Multifunction device drivers
  2. CONFIG_MFD_CORE is not set
  3. CONFIG_MFD_SM501 is not set
  4. CONFIG_MFD_ASIC3 is not set
  5. CONFIG_HTC_EGPIO is not set
  6. CONFIG_HTC_PASIC3 is not set
  7. CONFIG_TPS65010 is not set
  8. CONFIG_MFD_TMIO is not set
  9. CONFIG_MFD_TC6393XB is not set
  10. CONFIG_MFD_WM8400 is not set
  11. CONFIG_MFD_WM831X is not set
  12. CONFIG_MFD_WM8350_I2C is not set
  13. CONFIG_MFD_PCF50633 is not set
  14. CONFIG_AB3100_CORE is not set
  15. CONFIG_REGULATOR is not set
  16. CONFIG_MEDIA_SUPPORT is not set
  1. Graphics support
CONFIG_VGA_ARB=y
  1. CONFIG_DRM is not set
  2. CONFIG_VGASTATE is not set
  3. CONFIG_VIDEO_OUTPUT_CONTROL is not set
  4. CONFIG_FB is not set
  5. CONFIG_BACKLIGHT_LCD_SUPPORT is not set
  1. Display device support
  2. CONFIG_DISPLAY_SUPPORT is not set
  3. CONFIG_ADI9889 is not set
  4. CONFIG_THS8200 is not set
  1. Console display driver support
  2. CONFIG_VGA_CONSOLE is not set
CONFIG_DUMMY_CONSOLE=y CONFIG_SOUND=m CONFIG_SOUND_OSS_CORE=y CONFIG_SOUND_OSS_CORE_PRECLAIM=y
  1. CONFIG_SND is not set
CONFIG_SOUND_PRIME=m CONFIG_HID_SUPPORT=y CONFIG_HID=m
  1. CONFIG_HIDRAW is not set
  1. USB Input Devices
CONFIG_USB_HID=m
  1. CONFIG_HID_PID is not set
CONFIG_USB_HIDDEV=y
  1. USB HID Boot Protocol drivers
  2. CONFIG_USB_KBD is not set
  3. CONFIG_USB_MOUSE is not set
  1. Special HID drivers
  2. CONFIG_HID_A4TECH is not set
  3. CONFIG_HID_APPLE is not set
  4. CONFIG_HID_BELKIN is not set
  5. CONFIG_HID_CHERRY is not set
  6. CONFIG_HID_CHICONY is not set
  7. CONFIG_HID_CYPRESS is not set
  8. CONFIG_HID_DRAGONRISE is not set
  9. CONFIG_HID_EZKEY is not set
  10. CONFIG_HID_KYE is not set
  11. CONFIG_HID_GYRATION is not set
  12. CONFIG_HID_TWINHAN is not set
  13. CONFIG_HID_KENSINGTON is not set
  14. CONFIG_HID_LOGITECH is not set
  15. CONFIG_HID_MICROSOFT is not set
  16. CONFIG_HID_MONTEREY is not set
  17. CONFIG_HID_NTRIG is not set
  18. CONFIG_HID_PANTHERLORD is not set
  19. CONFIG_HID_PETALYNX is not set
  20. CONFIG_HID_SAMSUNG is not set
  21. CONFIG_HID_SONY is not set
  22. CONFIG_HID_SUNPLUS is not set
  23. CONFIG_HID_GREENASIA is not set
  24. CONFIG_HID_SMARTJOYPLUS is not set
  25. CONFIG_HID_TOPSEED is not set
  26. CONFIG_HID_THRUSTMASTER is not set
  27. CONFIG_HID_ZEROPLUS is not set
CONFIG_USB_SUPPORT=y CONFIG_USB_ARCH_HAS_HCD=y CONFIG_USB_ARCH_HAS_OHCI=y CONFIG_USB_ARCH_HAS_EHCI=y CONFIG_USB=m
  1. CONFIG_USB_DEBUG is not set
  2. CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
  1. Miscellaneous USB options
CONFIG_USB_DEVICEFS=y CONFIG_USB_DEVICE_CLASS=y
  1. CONFIG_USB_DYNAMIC_MINORS is not set
  2. CONFIG_USB_OTG is not set
  3. CONFIG_USB_OTG_WHITELIST is not set
  4. CONFIG_USB_OTG_BLACKLIST_HUB is not set
CONFIG_USB_MON=m CONFIG_USB_WUSB=m CONFIG_USB_WUSB_CBAF=m
  1. CONFIG_USB_WUSB_CBAF_DEBUG is not set
  1. USB Host Controller Drivers
CONFIG_USB_ETRON_HCD=m CONFIG_USB_ETRON_HCD_DEBUGGING=y CONFIG_USB_ETRON_HUB=y CONFIG_USB_C67X00_HCD=m
  1. CONFIG_USB_XHCI_HCD is not set
  2. CONFIG_USB_EHCI_HCD is not set
CONFIG_USB_OXU210HP_HCD=m CONFIG_USB_ISP116X_HCD=m CONFIG_USB_ISP1760_HCD=m
  1. CONFIG_USB_ISP1362_HCD is not set
  2. CONFIG_USB_OHCI_HCD is not set
  3. CONFIG_USB_UHCI_HCD is not set
CONFIG_USB_SL811_HCD=m CONFIG_USB_R8A66597_HCD=m CONFIG_USB_WHCI_HCD=m CONFIG_USB_HWA_HCD=m
  1. CONFIG_SYNO_XHCI_RING_EXPANSION is not set
  1. Enable Host or Gadget support to see Inventra options
CONFIG_USB_MUSB_HDRC=m CONFIG_USB_TUSB6010=y CONFIG_USB_MUSB_HOST=y
  1. CONFIG_USB_MUSB_PERIPHERAL is not set
  2. CONFIG_USB_MUSB_OTG is not set
CONFIG_USB_MUSB_HDRC_HCD=y CONFIG_MUSB_PIO_ONLY=y
  1. CONFIG_USB_MUSB_DEBUG is not set
  1. USB Device Class drivers
CONFIG_USB_ACM=m
  1. CONFIG_USB_PRINTER is not set
CONFIG_USB_WDM=m
  1. CONFIG_USB_TMC is not set
  1. NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
  1. also be needed; see USB_STORAGE Help for more info
  2. CONFIG_USB_STORAGE is not set
  3. CONFIG_USB_LIBUSUAL is not set
  1. USB Imaging devices
CONFIG_USB_MDC800=m CONFIG_USB_MICROTEK=m
  1. USB port drivers
CONFIG_USB_SERIAL=m
  1. CONFIG_USB_EZUSB is not set
CONFIG_USB_SERIAL_GENERIC=y
  1. CONFIG_USB_SERIAL_AIRCABLE is not set
  2. CONFIG_USB_SERIAL_ARK3116 is not set
  3. CONFIG_USB_SERIAL_BELKIN is not set
  4. CONFIG_USB_SERIAL_CH341 is not set
  5. CONFIG_USB_SERIAL_WHITEHEAT is not set
  6. CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set
  7. CONFIG_USB_SERIAL_CP210X is not set
  8. CONFIG_USB_SERIAL_CYPRESS_M8 is not set
  9. CONFIG_USB_SERIAL_EMPEG is not set
CONFIG_USB_SERIAL_FTDI_SIO=m
  1. CONFIG_USB_SERIAL_FUNSOFT is not set
  2. CONFIG_USB_SERIAL_VISOR is not set
  3. CONFIG_USB_SERIAL_IPAQ is not set
  4. CONFIG_USB_SERIAL_IR is not set
  5. CONFIG_USB_SERIAL_EDGEPORT is not set
  6. CONFIG_USB_SERIAL_EDGEPORT_TI is not set
  7. CONFIG_USB_SERIAL_GARMIN is not set
  8. CONFIG_USB_SERIAL_IPW is not set
  9. CONFIG_USB_SERIAL_IUU is not set
  10. CONFIG_USB_SERIAL_KEYSPAN_PDA is not set
  11. CONFIG_USB_SERIAL_KEYSPAN is not set
  12. CONFIG_USB_SERIAL_KLSI is not set
  13. CONFIG_USB_SERIAL_KOBIL_SCT is not set
  14. CONFIG_USB_SERIAL_MCT_U232 is not set
  15. CONFIG_USB_SERIAL_MOS7720 is not set
  16. CONFIG_USB_SERIAL_MOS7840 is not set
  17. CONFIG_USB_SERIAL_MOTOROLA is not set
  18. CONFIG_USB_SERIAL_NAVMAN is not set
CONFIG_USB_SERIAL_PL2303=m
  1. CONFIG_USB_SERIAL_OTI6858 is not set
CONFIG_USB_SERIAL_QUALCOMM=m
  1. CONFIG_USB_SERIAL_SPCP8X5 is not set
  2. CONFIG_USB_SERIAL_HP4X is not set
  3. CONFIG_USB_SERIAL_SAFE is not set
  4. CONFIG_USB_SERIAL_SIEMENS_MPI is not set
  5. CONFIG_USB_SERIAL_SIERRAWIRELESS is not set
  6. CONFIG_USB_SERIAL_SYMBOL is not set
  7. CONFIG_USB_SERIAL_TI is not set
  8. CONFIG_USB_SERIAL_CYBERJACK is not set
  9. CONFIG_USB_SERIAL_XIRCOM is not set
CONFIG_USB_SERIAL_WWAN=m CONFIG_USB_SERIAL_OPTION=m
  1. CONFIG_USB_SERIAL_OMNINET is not set
  2. CONFIG_USB_SERIAL_OPTICON is not set
  3. CONFIG_USB_SERIAL_DEBUG is not set
  1. USB Miscellaneous drivers
CONFIG_USB_EMI62=m
  1. CONFIG_USB_EMI26 is not set
  2. CONFIG_USB_ADUTUX is not set
  3. CONFIG_USB_SEVSEG is not set
  4. CONFIG_USB_RIO500 is not set
  5. CONFIG_USB_LEGOTOWER is not set
  6. CONFIG_USB_LCD is not set
  7. CONFIG_USB_BERRY_CHARGE is not set
  8. CONFIG_USB_LED is not set
  9. CONFIG_USB_CYPRESS_CY7C63 is not set
  10. CONFIG_USB_CYTHERM is not set
  11. CONFIG_USB_IDMOUSE is not set
  12. CONFIG_USB_FTDI_ELAN is not set
  13. CONFIG_USB_APPLEDISPLAY is not set
  14. CONFIG_USB_SISUSBVGA is not set
  15. CONFIG_USB_LD is not set
  16. CONFIG_USB_TRANCEVIBRATOR is not set
  17. CONFIG_USB_IOWARRIOR is not set
  18. CONFIG_USB_TEST is not set
  19. CONFIG_USB_ISIGHTFW is not set
  20. CONFIG_USB_VST is not set
  21. CONFIG_USB_GADGET is not set
  1. OTG and related infrastructure
CONFIG_USB_OTG_UTILS=y
  1. CONFIG_USB_GPIO_VBUS is not set
CONFIG_NOP_USB_XCEIV=m CONFIG_UWB=m CONFIG_UWB_HWA=m CONFIG_UWB_WHCI=m
  1. CONFIG_UWB_WLP is not set
  2. CONFIG_UWB_I1480U is not set
  3. CONFIG_MMC is not set
  4. CONFIG_MEMSTICK is not set
CONFIG_NEW_LEDS=y CONFIG_LEDS_CLASS=m
  1. LED drivers
  2. CONFIG_LEDS_PCA9532 is not set
  3. CONFIG_LEDS_GPIO is not set
  4. CONFIG_LEDS_LP3944 is not set
  5. CONFIG_LEDS_PCA955X is not set
  6. CONFIG_LEDS_BD2802 is not set
  1. LED Triggers
CONFIG_LEDS_TRIGGERS=y
  1. CONFIG_LEDS_TRIGGER_TIMER is not set
  2. CONFIG_LEDS_TRIGGER_HEARTBEAT is not set
  3. CONFIG_LEDS_TRIGGER_BACKLIGHT is not set
  4. CONFIG_LEDS_TRIGGER_GPIO is not set
  5. CONFIG_LEDS_TRIGGER_DEFAULT_ON is not set
  1. iptables trigger is under Netfilter config (LED target)
  2. CONFIG_ACCESSIBILITY is not set
  3. CONFIG_INFINIBAND is not set
CONFIG_RTC_LIB=y
  1. CONFIG_RTC_CLASS is not set
  2. CONFIG_DMADEVICES is not set
  3. CONFIG_AUXDISPLAY is not set
  4. CONFIG_UIO is not set
  1. TI VLYNQ
CONFIG_STAGING=y
  1. CONFIG_STAGING_EXCLUDE_BUILD is not set
  2. CONFIG_ET131X is not set
CONFIG_USB_IP_COMMON=m CONFIG_USB_IP_VHCI_HCD=m CONFIG_USB_IP_HOST=m
  1. CONFIG_PRISM2_USB is not set
  2. CONFIG_ECHO is not set
  3. CONFIG_COMEDI is not set
  4. CONFIG_ASUS_OLED is not set
  5. CONFIG_ALTERA_PCIE_CHDMA is not set
  6. CONFIG_RTL8187SE is not set
  7. CONFIG_RTL8192SU is not set
  8. CONFIG_RTL8192E is not set
  9. CONFIG_TRANZPORT is not set
  1. Android
  1. Qualcomm MSM Camera And Video
  1. Camera Sensor Selection
  2. CONFIG_INPUT_GPIO is not set
  3. CONFIG_DST is not set
  4. CONFIG_POHMELFS is not set
  5. CONFIG_B3DFG is not set
  6. CONFIG_IDE_PHISON is not set
  7. CONFIG_PLAN9AUTH is not set
  8. CONFIG_USB_SERIAL_QUATECH2 is not set
  9. CONFIG_USB_SERIAL_QUATECH_USB2 is not set
  10. CONFIG_VT6655 is not set
  11. CONFIG_VT6656 is not set
  12. CONFIG_VME_BUS is not set
  1. RAR Register Driver
  2. CONFIG_RAR_REGISTER is not set
  3. CONFIG_IIO is not set
  1. File systems
CONFIG_EXT2_FS=y CONFIG_EXT2_FS_XATTR=y
  1. CONFIG_EXT2_FS_POSIX_ACL is not set
  2. CONFIG_EXT2_FS_SECURITY is not set
  3. CONFIG_EXT2_FS_XIP is not set
CONFIG_EXT3_FS=y CONFIG_EXT3_DEFAULTS_TO_ORDERED=y CONFIG_EXT3_FS_XATTR=y
  1. CONFIG_EXT3_FS_POSIX_ACL is not set
  2. CONFIG_EXT3_FS_SECURITY is not set
CONFIG_EXT4_FS=y CONFIG_EXT4_FS_XATTR=y CONFIG_EXT4_FS_SYNO_ACL=y
  1. CONFIG_EXT4_FS_POSIX_ACL is not set
  2. CONFIG_EXT4_FS_SECURITY is not set
  3. CONFIG_EXT4_DEBUG is not set
CONFIG_JBD=y CONFIG_JBD2=y CONFIG_FS_MBCACHE=y
  1. CONFIG_REISERFS_FS is not set
  2. CONFIG_JFS_FS is not set
CONFIG_FS_SYNO_ACL=y CONFIG_FS_POSIX_ACL=y
  1. CONFIG_XFS_FS is not set
  2. CONFIG_GFS2_FS is not set
  3. CONFIG_OCFS2_FS is not set
  4. CONFIG_BTRFS_FS is not set
  5. CONFIG_NILFS2_FS is not set
CONFIG_FILE_LOCKING=y
  1. CONFIG_OPTIMIZE_SD_PERFORMANCE is not set
  2. CONFIG_DELAY_ASYNC_READAHEAD is not set
  3. CONFIG_SEND_PAGES is not set
CONFIG_FSNOTIFY=y CONFIG_DNOTIFY=y CONFIG_INOTIFY=y CONFIG_INOTIFY_USER=y CONFIG_QUOTA=y
  1. CONFIG_QUOTA_NETLINK_INTERFACE is not set
  2. CONFIG_PRINT_QUOTA_WARNING is not set
CONFIG_QUOTA_TREE=m
  1. CONFIG_QFMT_V1 is not set
CONFIG_QFMT_V2=m CONFIG_QUOTACTL=y
  1. CONFIG_AUTOFS_FS is not set
  2. CONFIG_AUTOFS4_FS is not set
CONFIG_FUSE_FS=m
  1. CONFIG_CUSE is not set
  1. Caches
  2. CONFIG_FSCACHE is not set
  1. CD-ROM/DVD Filesystems
CONFIG_ISO9660_FS=m CONFIG_JOLIET=y CONFIG_ZISOFS=y CONFIG_UDF_FS=m CONFIG_UDF_NLS=y
  1. DOS/FAT/NT Filesystems
CONFIG_FAT_FS=m
  1. CONFIG_MSDOS_FS is not set
CONFIG_VFAT_FS=m CONFIG_FAT_DEFAULT_CODEPAGE=437 CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
  1. CONFIG_NTFS_FS is not set
  1. Pseudo filesystems
CONFIG_PROC_FS=y CONFIG_PROC_SYSCTL=y CONFIG_PROC_PAGE_MONITOR=y CONFIG_SYSFS=y CONFIG_TMPFS=y
  1. CONFIG_TMPFS_POSIX_ACL is not set
  2. CONFIG_HUGETLB_PAGE is not set
CONFIG_CONFIGFS_FS=m CONFIG_MISC_FILESYSTEMS=y
  1. CONFIG_ADFS_FS is not set
  2. CONFIG_AFFS_FS is not set
CONFIG_ECRYPT_FS=m
  1. CONFIG_HFS_FS is not set
CONFIG_HFSPLUS_FS=m
  1. CONFIG_BEFS_FS is not set
  2. CONFIG_BFS_FS is not set
  3. CONFIG_EFS_FS is not set
  4. CONFIG_JFFS2_FS is not set
  5. CONFIG_CRAMFS is not set
  6. CONFIG_SQUASHFS is not set
  7. CONFIG_VXFS_FS is not set
  8. CONFIG_MINIX_FS is not set
  9. CONFIG_OMFS_FS is not set
  10. CONFIG_HPFS_FS is not set
  11. CONFIG_QNX4FS_FS is not set
  12. CONFIG_ROMFS_FS is not set
  13. CONFIG_SYSV_FS is not set
  14. CONFIG_UFS_FS is not set
  15. CONFIG_AUFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y CONFIG_NFS_FS=y CONFIG_NFS_V3=y
  1. CONFIG_NFS_V3_ACL is not set
CONFIG_NFS_V4=y
  1. CONFIG_NFS_V4_1 is not set
  2. CONFIG_ROOT_NFS is not set
CONFIG_NFSD=m CONFIG_NFSD_V3=y
  1. CONFIG_NFSD_V3_ACL is not set
CONFIG_NFSD_V4=y CONFIG_LOCKD=y CONFIG_LOCKD_V4=y CONFIG_EXPORTFS=m CONFIG_NFS_COMMON=y CONFIG_SUNRPC=y CONFIG_SUNRPC_GSS=y CONFIG_RPCSEC_GSS_KRB5=y
  1. CONFIG_RPCSEC_GSS_SPKM3 is not set
  2. CONFIG_SMB_FS is not set
CONFIG_CIFS=m
  1. CONFIG_CIFS_STATS is not set
  2. CONFIG_CIFS_WEAK_PW_HASH is not set
  3. CONFIG_CIFS_UPCALL is not set
  4. CONFIG_CIFS_XATTR is not set
  5. CONFIG_CIFS_DEBUG2 is not set
  6. CONFIG_CIFS_DFS_UPCALL is not set
  7. CONFIG_CIFS_EXPERIMENTAL is not set
  8. CONFIG_NCP_FS is not set
  9. CONFIG_CODA_FS is not set
  10. CONFIG_AFS_FS is not set
  1. Partition Types
CONFIG_PARTITION_ADVANCED=y
  1. CONFIG_ACORN_PARTITION is not set
  2. CONFIG_OSF_PARTITION is not set
  3. CONFIG_AMIGA_PARTITION is not set
  4. CONFIG_ATARI_PARTITION is not set
CONFIG_MAC_PARTITION=y CONFIG_MSDOS_PARTITION=y
  1. CONFIG_BSD_DISKLABEL is not set
  2. CONFIG_MINIX_SUBPARTITION is not set
  3. CONFIG_SOLARIS_X86_PARTITION is not set
  4. CONFIG_UNIXWARE_DISKLABEL is not set
  5. CONFIG_LDM_PARTITION is not set
  6. CONFIG_SGI_PARTITION is not set
  7. CONFIG_ULTRIX_PARTITION is not set
  8. CONFIG_SUN_PARTITION is not set
  9. CONFIG_KARMA_PARTITION is not set
CONFIG_EFI_PARTITION=y
  1. CONFIG_SYSV68_PARTITION is not set
CONFIG_NLS=y CONFIG_NLS_DEFAULT="iso8859-1"
  1. CONFIG_NLS_CODEPAGE_437 is not set
  2. CONFIG_NLS_CODEPAGE_737 is not set
  3. CONFIG_NLS_CODEPAGE_775 is not set
  4. CONFIG_NLS_CODEPAGE_850 is not set
  5. CONFIG_NLS_CODEPAGE_852 is not set
  6. CONFIG_NLS_CODEPAGE_855 is not set
  7. CONFIG_NLS_CODEPAGE_857 is not set
  8. CONFIG_NLS_CODEPAGE_860 is not set
  9. CONFIG_NLS_CODEPAGE_861 is not set
  10. CONFIG_NLS_CODEPAGE_862 is not set
  11. CONFIG_NLS_CODEPAGE_863 is not set
  12. CONFIG_NLS_CODEPAGE_864 is not set
  13. CONFIG_NLS_CODEPAGE_865 is not set
  14. CONFIG_NLS_CODEPAGE_866 is not set
  15. CONFIG_NLS_CODEPAGE_869 is not set
  16. CONFIG_NLS_CODEPAGE_936 is not set
  17. CONFIG_NLS_CODEPAGE_950 is not set
  18. CONFIG_NLS_CODEPAGE_932 is not set
  19. CONFIG_NLS_CODEPAGE_949 is not set
  20. CONFIG_NLS_CODEPAGE_874 is not set
  21. CONFIG_NLS_ISO8859_8 is not set
  22. CONFIG_NLS_CODEPAGE_1250 is not set
  23. CONFIG_NLS_CODEPAGE_1251 is not set
  24. CONFIG_NLS_ASCII is not set
  25. CONFIG_NLS_ISO8859_1 is not set
  26. CONFIG_NLS_ISO8859_2 is not set
  27. CONFIG_NLS_ISO8859_3 is not set
  28. CONFIG_NLS_ISO8859_4 is not set
  29. CONFIG_NLS_ISO8859_5 is not set
  30. CONFIG_NLS_ISO8859_6 is not set
  31. CONFIG_NLS_ISO8859_7 is not set
  32. CONFIG_NLS_ISO8859_9 is not set
  33. CONFIG_NLS_ISO8859_13 is not set
  34. CONFIG_NLS_ISO8859_14 is not set
  35. CONFIG_NLS_ISO8859_15 is not set
  36. CONFIG_NLS_KOI8_R is not set
  37. CONFIG_NLS_KOI8_U is not set
CONFIG_NLS_UTF8=y
  1. CONFIG_DLM is not set
  1. Kernel hacking
CONFIG_PRINTK_TIME=y CONFIG_ENABLE_WARN_DEPRECATED=y CONFIG_ENABLE_MUST_CHECK=y CONFIG_FRAME_WARN=1024 CONFIG_MAGIC_SYSRQ=y
  1. CONFIG_STRIP_ASM_SYMS is not set
  2. CONFIG_UNUSED_SYMBOLS is not set
  3. CONFIG_DEBUG_FS is not set
  4. CONFIG_HEADERS_CHECK is not set
  5. CONFIG_DEBUG_KERNEL is not set
  6. CONFIG_DEBUG_BUGVERBOSE is not set
  7. CONFIG_DEBUG_MEMORY_INIT is not set
  8. CONFIG_FRAME_POINTER is not set
  9. CONFIG_RCU_CPU_STALL_DETECTOR is not set
  10. CONFIG_LATENCYTOP is not set
  11. CONFIG_SYSCTL_SYSCALL_CHECK is not set
CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_TRACING_SUPPORT=y
  1. CONFIG_FTRACE is not set
  2. CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y CONFIG_ARM_UNWIND=y
  1. CONFIG_DEBUG_USER is not set
  1. Security options
CONFIG_KEYS=y CONFIG_KEYS_DEBUG_PROC_KEYS=y
  1. CONFIG_SECURITY is not set
  2. CONFIG_SECURITYFS is not set
  3. CONFIG_SECURITY_FILE_CAPABILITIES is not set
CONFIG_XOR_BLOCKS=y CONFIG_ASYNC_CORE=y CONFIG_ASYNC_MEMCPY=y CONFIG_ASYNC_XOR=y CONFIG_ASYNC_PQ=y CONFIG_ASYNC_RAID6_RECOV=y CONFIG_CRYPTO=y
  1. Crypto core or helper
  2. CONFIG_CRYPTO_FIPS is not set
CONFIG_CRYPTO_ALGAPI=y CONFIG_CRYPTO_ALGAPI2=y CONFIG_CRYPTO_AEAD=m CONFIG_CRYPTO_AEAD2=y CONFIG_CRYPTO_BLKCIPHER=y CONFIG_CRYPTO_BLKCIPHER2=y CONFIG_CRYPTO_HASH=y CONFIG_CRYPTO_HASH2=y CONFIG_CRYPTO_RNG=m CONFIG_CRYPTO_RNG2=y CONFIG_CRYPTO_PCOMP=y CONFIG_CRYPTO_MANAGER=y CONFIG_CRYPTO_MANAGER2=y
  1. CONFIG_CRYPTO_GF128MUL is not set
  2. CONFIG_CRYPTO_NULL is not set
CONFIG_CRYPTO_WORKQUEUE=y
  1. CONFIG_CRYPTO_CRYPTD is not set
CONFIG_CRYPTO_AUTHENC=m
  1. CONFIG_CRYPTO_TEST is not set
  1. Authenticated Encryption with Associated Data
  2. CONFIG_CRYPTO_CCM is not set
  3. CONFIG_CRYPTO_GCM is not set
  4. CONFIG_CRYPTO_SEQIV is not set
  1. Block modes
CONFIG_CRYPTO_CBC=y
  1. CONFIG_CRYPTO_CTR is not set
  2. CONFIG_CRYPTO_CTS is not set
CONFIG_CRYPTO_ECB=m
  1. CONFIG_CRYPTO_LRW is not set
  2. CONFIG_CRYPTO_PCBC is not set
  3. CONFIG_CRYPTO_XTS is not set
  1. Hash modes
CONFIG_CRYPTO_HMAC=m
  1. CONFIG_CRYPTO_XCBC is not set
  2. CONFIG_CRYPTO_VMAC is not set
  1. Digest
CONFIG_CRYPTO_CRC32C=m
  1. CONFIG_CRYPTO_GHASH is not set
  2. CONFIG_CRYPTO_MD4 is not set
CONFIG_CRYPTO_MD5=y
  1. CONFIG_CRYPTO_MICHAEL_MIC is not set
  2. CONFIG_CRYPTO_RMD128 is not set
  3. CONFIG_CRYPTO_RMD160 is not set
  4. CONFIG_CRYPTO_RMD256 is not set
  5. CONFIG_CRYPTO_RMD320 is not set
CONFIG_CRYPTO_SHA1=m CONFIG_CRYPTO_SHA256=m CONFIG_CRYPTO_SHA512=m
  1. CONFIG_CRYPTO_TGR192 is not set
  2. CONFIG_CRYPTO_WP512 is not set
  1. Ciphers
CONFIG_CRYPTO_AES=m
  1. CONFIG_CRYPTO_ANUBIS is not set
CONFIG_CRYPTO_ARC4=m
  1. CONFIG_CRYPTO_BLOWFISH is not set
  2. CONFIG_CRYPTO_CAMELLIA is not set
  3. CONFIG_CRYPTO_CAST5 is not set
  4. CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=y
  1. CONFIG_CRYPTO_FCRYPT is not set
  2. CONFIG_CRYPTO_KHAZAD is not set
  3. CONFIG_CRYPTO_SALSA20 is not set
  4. CONFIG_CRYPTO_SEED is not set
  5. CONFIG_CRYPTO_SERPENT is not set
  6. CONFIG_CRYPTO_TEA is not set
  7. CONFIG_CRYPTO_TWOFISH is not set
  1. Compression
CONFIG_CRYPTO_DEFLATE=m
  1. CONFIG_CRYPTO_ZLIB is not set
  2. CONFIG_CRYPTO_LZO is not set
  1. Random Number Generation
CONFIG_CRYPTO_ANSI_CPRNG=m
  1. CONFIG_CRYPTO_HW is not set
  1. OCF Configuration
CONFIG_OCF_OCF=m CONFIG_SYNO_USE_OCF_LINUX=y
  1. CONFIG_OCF_RANDOMHARVEST is not set
CONFIG_OCF_CRYPTODEV=m CONFIG_OCF_CRYPTOSOFT=m
  1. CONFIG_OCF_SAFE is not set
  2. CONFIG_OCF_IXP4XX is not set
  3. CONFIG_OCF_HIFN is not set
  4. CONFIG_OCF_HIFNHIPP is not set
  5. CONFIG_OCF_TALITOS is not set
  6. CONFIG_OCF_EP80579 is not set
  7. CONFIG_OCF_CRYPTOCTEON is not set
  8. CONFIG_OCF_KIRKWOOD is not set
  9. CONFIG_OCF_C7108 is not set
  10. CONFIG_OCF_OCFNULL is not set
  11. CONFIG_OCF_BENCH is not set
  12. CONFIG_BINARY_PRINTF is not set
  1. Library routines
CONFIG_BITREVERSE=y CONFIG_GENERIC_FIND_LAST_BIT=y CONFIG_CRC_CCITT=m CONFIG_CRC16=y
  1. CONFIG_CRC_T10DIF is not set
CONFIG_CRC_ITU_T=m CONFIG_CRC32=y
  1. CONFIG_CRC7 is not set
CONFIG_LIBCRC32C=m CONFIG_ZLIB_INFLATE=y CONFIG_ZLIB_DEFLATE=m CONFIG_DECOMPRESS_GZIP=y CONFIG_DECOMPRESS_LZMA=y CONFIG_HAS_IOMEM=y CONFIG_HAS_IOPORT=y CONFIG_HAS_DMA=y CONFIG_NLATTR=y CONFIG_GENERIC_ATOMIC64=y
  1. CONFIG_SYNO_CROND is not set
