Wakeuplight
Set up a wakeup light which will slowly dim-up a lamp, e.g. at your bedside, and will switch it off again after a certain time. The solution requires a dimmer hardware device, e.g. FS20-di. In the example below the dimmer is named Lamp1.
Code
define wakeup at *07:00:00 {\
  if (!$we) {\
   {fhem("set Lamp1 dim100% 1280") }\
   {fhem("define wakeupOff at +00:40:00 set Lamp1 off") }\
Explanation:
The time indicated for wakeup (here: 7am) is the starting-time of the dim-procedure. The asterisk indicates this procedure shall be executed every day.
The program uses the variable $we (weekend), so your wakeuplight will only turn on on weekdays. If you implement holiday2we, the wakeuplight will also remain off on holidays.
The set-command 'dim100% 1280' will dim the lamp to 100% over a timespan of 1280 seconds, i.e. 21 minutes.
Finally, the off-command is scheduled for 40 minutes from wakeuptime.
Change of wakeuptime
To change the wakeuptime to e.g. 8am, type the following into the input-field on the fhem-frontend:
modify wakeup *08:00:00
Change of wakeuptime using sliders
Setting the wakeuptime using the "modify wakeup" command is inconvenient. Especially forgetting to set the asterisk (*) is a pain, as the wakeup-definition will disappear after next execution. To avoid this pitfall, there is an option to add an additional pseudo-device which offers sliders to set the wakeup time:
define wakeupChange dummy
attr wakeupChange setList state:time
attr wakeupChange webCmd state
define n_wakeupChange notify wakeupChange {fhem("modify wakeup *%");;}
Explanation: A dummy device wakeupChange is defined. It carries sliders to select the wakeuptime. Subsequently, a notify is defined, which gets triggered whenever a time is selected using the sliders. This chosen time is then used to execute the 'modify wakeup'-command for the actual wakeup-device.
Save the time even after a restart or rereadcfg
Because you don't want (to remember) to adjust the modified time after even restart or rereadcfg it is also possible to reread it from the ReadingsVal:
define n_wakeupChange notify (wakeupChange|global:INITIALIZED|global:REREADCFG).* \
   modify wakeup *{ReadingsVal("wakeupChange","state","05:30")}
Explanation: We modify the previousley created dummy device wakeupChange so the notify is not just triggered when calling wakeupChange but also when we restart (global:INITIALIZED) or reread the configuration (global:REREADCFG). At last you should enter an fallback value in the modify, in case the given value isn't valid.
