Kostal Plenticore 10 Plus
Kostal Plenticore 10 Plus | |
Protokoll | IP und RS485 |
Typ | Hybrid Wechselrichter |
Kategorie | Wechselrichter |
Technische Details | |
Kommunikation | n/a |
Kanäle | n/a |
Betriebsspannung | 400 V |
Leistungsaufnahme | |
Versorgung | 3P AC |
Sonstiges | |
Modulname | HTTPMOD, Modbus, Perl |
Geräte-Registrierung
Hersteller Dokumentation
Einbindung in das Netzwerk
Namensgebung
Voraussetzungen FHEM Umfeld
Verwendete Module
- Modbus
- HTTPMOD
- expandJSON
- DbLog
- DbRep
- DUMMY
- DOIF
- Shelly
- SMAEM
- HourCounter
- DWD_OpenData
- readingsGroup
- WeekdayTimer
- SVG
Verwendetes Umfeld
- Raspberry Pi 4
- Debian
- Docker
- fhem/fhem:latest
- hypriot/rpi-mysql
- grafana/grafana:latest
- Perl
Einbindung in FHEM: Überblick
Plenticore Modbus Definition
Ein zweiter Wechselrichter
Modbus Timeing
RAW Definition WR_1_config
defmod WR_1_config dummy
Korrekturkurven:\
Steilheit Parallel\
verschiebung\
tempk -0.39 25\
cloudk -0.65 0\
raink -0.30 0\
attr WR_1_config sortby 113
attr WR_1_config verbose 0
attr WR_1 DbLogExclude .*
attr WR_1 alias WR_1
attr WR_1 alignTime 00:00
attr WR_1 comment Version 2022.03.29 09:00\
attr WR_1 dev-h-combine 8
attr WR_1 dev-h-defLen 2
attr WR_1 dev-h-defPoll 1
attr WR_1 dev-h-defRevRegs 1
attr WR_1 dev-h-defUnpack f>
attr WR_1 dev-type-STR-len 8
attr WR_1 disable 0
attr WR_1 event-on-change-reading Act_state_of_charge,Actual_Battery_charge_-minus_or_discharge_-plus_I,Actual_Battery_charge_-minus_or_discharge_-plus_P,Actual_Battery_charge_usable_P,Battery_Total.*,Battery_charge.*,Battery_gross.*,Battery_temperature,Battery_MaxChargePowerLimitAbs,Battery_.*SOC,Home_own_consumption.*,P_DC1,P_DC2,Solar_.*,Total_.*,SW_.*,.*_yield,Inverter_state.*,Inverter_Generation_P_Actual.*,P_limit_from_EVU.*,Solar_Calculation_fc.*_day
attr WR_1 icon sani_solar
attr WR_1 obj-h1024-len 1
attr WR_1 obj-h1024-set 1
attr WR_1 obj-h1025-len 1
attr WR_1 obj-h1026-set 1
attr WR_1 obj-h1028-set 1
attr WR_1 obj-h1030-set 1
attr WR_1 obj-h1032-set 1
attr WR_1 obj-h1034-set 1
attr WR_1 obj-h1036-set 1
attr WR_1 obj-h1038-set 1
attr WR_1 obj-h104-format %s
attr WR_1 obj-h104-map 0:Normal,8:Ruhe1,16:Ruhe2,32:Ausgleichsladung,64:Tiefentladeschutz
attr WR_1 obj-h104-revRegs 0
attr WR_1 obj-h104-unpack N
attr WR_1 obj-h1040-set 1
attr WR_1 obj-h1042-set 1
attr WR_1 obj-h1044-set 1
attr WR_1 obj-h1080-set 1
attr WR_1 obj-h14-type STR
attr WR_1 obj-h38-type STR
attr WR_1 obj-h384-len 16
attr WR_1 obj-h384-type STR
attr WR_1 obj-h420-type STR
attr WR_1 obj-h428-type STR
attr WR_1 obj-h436-type STR
attr WR_1 obj-h446-type STR
attr WR_1 obj-h454-type STR
attr WR_1 obj-h46-type STR
attr WR_1 obj-h512-format %s
attr WR_1 obj-h512-unpack N
attr WR_1 obj-h514-len 1
attr WR_1 obj-h515-format %s
attr WR_1 obj-h515-unpack N
attr WR_1 obj-h517-type STR
attr WR_1 obj-h525-format %s
attr WR_1 obj-h525-unpack N
attr WR_1 obj-h527-format %s
attr WR_1 obj-h527-unpack N
attr WR_1 obj-h529-len 4
attr WR_1 obj-h529-unpack N
attr WR_1 obj-h531-unpack N
attr WR_1 obj-h56-format %.0f
attr WR_1 obj-h56-unpack N
attr WR_1 obj-h575-unpack N
attr WR_1 obj-h577-unpack N
attr WR_1 obj-h586-format %s
attr WR_1 obj-h586-unpack N
attr WR_1 obj-h6-type STR
attr WR_1 obj-h768-len 32
attr WR_1 obj-h768-type STR
attr WR_1 obj-h800-len 32
attr WR_1 obj-h800-type STR
attr WR_1 sortby 111
attr WR_1 stateFormat {\
my $DUMMY = "";;\
my $Power = ReadingsVal($name,"Actual_Battery_charge_-minus_or_discharge_-plus_P",0);;\
my $StatusSpeicher = ($Power < -10) ? "<span style='color:#00FF00'>Laden</span>" : ($Power > 15)? "<span style='color:#FF0000'>Entladen</span>" : "<span style='color:orange'>Standby</span>";;\
$Power = $Power." W";;\
my $Battery_temperature = sprintf("%.1f °C",ReadingsVal($name,"Battery_temperature",0));;\
my $Actual_Battery_charge_usable_P = sprintf("%d W",ReadingsVal($name,"Actual_Battery_charge_usable_P",0));;\
my $Act_state_of_charge = sprintf("%d %%",ReadingsVal($name,"Act_state_of_charge","0"));;\
my $SW_Total_DC_P_sumOfAllPVInputs = sprintf("%d W",ReadingsVal($name,"SW_Total_DC_P_sumOfAllPVInputs","0"));;\
my $SW_Total_PV_P_reserve = sprintf("%d W",ReadingsVal($name,"SW_Total_PV_P_reserve","0"));;\
my $SW_Home_own_consumption_from_PV = sprintf("%d",ReadingsVal($name,"SW_Home_own_consumption_from_PV",0));;\
my $SW_Home_own_consumption_from_grid = sprintf("%d W",ReadingsVal($name,"SW_Home_own_consumption_from_grid",0));;\
my $SW_Home_own_consumption = sprintf("%d W",ReadingsVal($name,"SW_Home_own_consumption",0));;\
my $Total_Active_P_EM = sprintf("%d",ReadingsVal($name,"Total_Active_P_EM",0));;\
my $StatusNetz = ($Total_Active_P_EM < -10) ? "<span style='color:#00FF00'>Einspeisen</span>" : ($Total_Active_P_EM > 15)? "<span style='color:#FF0000'>Netzbezug</span>" : "<span style='color:orange'>Standby</span>";;\
$Total_Active_P_EM = $Total_Active_P_EM." W";;\
my $SW_Yield_Daily = sprintf("%d kWh",round(ReadingsVal($name,"SW_Yield_Daily",0)/1000 ,0));;\
my $SW_Yield_Yearly = sprintf("%d kWh",round(ReadingsVal($name,"SW_Yield_Yearly",0)/1000 ,0));;\
my $SW_Yield_Total = sprintf("%d kWh",round(ReadingsVal($name,"SW_Yield_Total",0)/1000 ,0));;\
my $Solar_Calculation_fc0_4h = sprintf("%d kWh",round(ReadingsVal($name,"Solar_Calculation_fc0_4h",0)/1000 ,0));;\
my $Solar_Calculation_fc0_day = sprintf("%d kWh",round(ReadingsVal($name,"Solar_Calculation_fc0_day",0)/1000 ,0));;\
<colgroup>\
</colgroup>\
<tr><td style='padding-right:5px;;padding-left:5px;;text-align:left;;font-weight:bold'>Speicher<dd>Temperatur / nutzbare Ladung / Status / Leistung / akt. SOC</dd></td><td style='padding-right:5px;;padding-left:5px;;text-align:center'><br>".$Battery_temperature."</td><td style='padding-right:5px;;padding-left:5px;;text-align:center'><br>".$Actual_Battery_charge_usable_P."</td><td style='padding-right:5px;;padding-left:5px;;text-align:center'>".$StatusSpeicher."<br></td><td style='padding-right:5px;;padding-left:5px;;text-align:center'>".$Power."<br>".$Act_state_of_charge."</td></tr>\
</table>\
</html>"\
attr WR_1 userReadings Total_PV_P_reserve:Total_DC_P.* {my $reserve = ReadingsVal($NAME,"Total_DC_P_sumOfAllPVInputs",0) * 0.90 - ReadingsVal($NAME,"Home_own_consumption_from_PV",0);;;; ($reserve lt 0)? 0 : round($reserve,0) },\
Total_DC_P_Max:[Total_DC_P_sumOfAllPVInputs|Actual_Battery_charge_-minus_or_discharge_-plus_P].* { my $Bat_P = ReadingsVal($NAME,"Actual_Battery_charge_-minus_or_discharge_-plus_P",0);;;; ($Bat_P gt 0)? round(ReadingsVal($NAME,"Total_DC_P_sumOfAllPVInputs",0) + $Bat_P,0) : round(ReadingsVal($NAME,"Total_DC_P_sumOfAllPVInputs",0),0) },\
SW_Total_PV_P_reserve:SW_Total_DC_P_sumOfAllPVInputs.* {my $reserve = ReadingsVal($NAME,"SW_Total_DC_P_sumOfAllPVInputs",0) * 0.90 - ReadingsVal($NAME,"SW_Home_own_consumption",0);;;; ($reserve lt 0)? 0 : round($reserve,0) },\
SW_Total_DC_P_Max:SW_Total_DC_P_sumOfAllPVInputs.* { my $Bat_out = (ReadingsVal($NAME,"Actual_Battery_charge_-minus_or_discharge_-plus_I",0)*ReadingsVal($NAME,"Battery_voltage",0));;;; ($Bat_out gt 0)? round(ReadingsVal($NAME,"SW_Total_DC_P_sumOfAllPVInputs",0) + $Bat_out,0) : round(ReadingsVal($NAME,"SW_Total_DC_P_sumOfAllPVInputs",0),0) },\
attr WR_1 verbose 0
userReadings
Total_PV_Power_reserve
Total_DC_Power_Max
SW_*
attr WR_2 DbLogExclude .*
attr WR_2 alias WR_2
attr WR_2 alignTime 00:00
Kostal Plenticore Plus 7
attr WR_2 dev-h-combine 8
attr WR_2 dev-h-defLen 2
attr WR_2 dev-h-defPoll 1
attr WR_2 dev-h-defRevRegs 1
attr WR_2 dev-h-defUnpack f>
attr WR_2 dev-type-STR-len 8
attr WR_2 disable 0
attr WR_2 icon sani_solar
attr WR_2 obj-h14-type STR
attr WR_2 obj-h38-type STR
attr WR_2 obj-h384-len 16
attr WR_2 obj-h384-type STR
attr WR_2 obj-h420-type STR
attr WR_2 obj-h428-type STR
attr WR_2 obj-h436-type STR
attr WR_2 obj-h446-type STR
attr WR_2 obj-h454-type STR
attr WR_2 obj-h46-type STR
attr WR_2 obj-h529-len 4
attr WR_2 obj-h529-unpack N
attr WR_2 obj-h531-unpack N
attr WR_2 obj-h535-revRegs 0
attr WR_2 obj-h535-unpack n
attr WR_2 obj-h551-revRegs 0
attr WR_2 obj-h559-revRegs 0
attr WR_2 obj-h56-format %.0f
attr WR_2 obj-h56-unpack N
attr WR_2 obj-h575-unpack N
attr WR_2 obj-h577-len 2
attr WR_2 obj-h577-unpack N
attr WR_2 obj-h6-type STR
attr WR_2 obj-h768-len 32
attr WR_2 obj-h768-type STR
attr WR_2 obj-h800-len 32
attr WR_2 obj-h800-type STR
attr WR_2 sortby 211
attr WR_2 verbose 0
Plenticore API
Plenticore Testablauf
attr global verbose 3
attr <device> verbose 5
- use Crypt::AuthEnc::GCM;
KeyValue()
sub KeyValue {
my $e_value = "";
my $error;
if ($step eq "read") {
if ( defined($error) ) {
return undef;
if ( defined($value) ) {
my $dec_value = '';
my $decode = chop($key);
$key = $decode.$key;
return $dec_value;
else {
return undef;
if ($step eq "store") {
my $encode = chop($key);
$key = $encode.$key;
KeyValue() Test
plenticore_auth() Erläuterung
plenticore_auth()
sub plenticore_auth {
if ($verbose >= 3) {
if($step eq "start")
my $len = 12;
my $string;
$u =~ s/\n$//g;
return $message;
my $s = hmac_sha256($ck, $r);
my $underscore = sha256($s);
if($step eq "finish")
my $c = hmac_sha256($sk, $r);
my $pd = encode('UTF-8', $d);
my $p = hmac_sha256($pd, $c);
my $gd = encode('UTF-8', $d);
my $f = "";
my $g1 = "";
my $s1 = "";
my $f1 = "";
my $j = 0;
$g1 = substr($g,$j,1);
$s1 = substr($s,$j,1);
$f1 = $s1 ^ $g1 ;
$f = $f.$f1;
my $pe = encode_base64($f);
return $message;
if($step eq "session")
my $dd = encode('UTF-8', $d);
$tt = encode_base64($t);
return $message;
plenticore_auth() Test
Test 1)
Test 2)
Test 3)
Ablaufbeschreibung WR_1_API
1. get WR_1_API 20_Statistic_EnergyFlow 2. Sollte noch keine Session aufgebaut sein erfolgt der Aufruf von sid01 3. Das Replacement %START% führt plenticore_auth("start","user","WR_1_API") aus 4. Die Rückmeldung vom Plenticore wird gelesen 5. Das Replacement %FINISH% führt plenticore_auth("finish","user","WR_1_API",...) aus 6. Die Rückmeldung vom Plenticore wird gelesen 7. Das Replacement %SESSION% führt plenticore_auth("session","user","WR_1_API",...,...) aus 8. Die Rückmeldung vom Plenticore wird gelesen und es sollte eine SessionId bestehen, mit der nun alle weiteren Abfragen laufen 9. Der eigentliche Aufruf wird ausgeführt und die readings bereit gestellt
Implementierte Abfragen
get:
Für die Korrektur der Statistiken werden die Stromzähler Stände des KSEM benötigt, die als reading mit Active_energy[+|-] bezeichnet sind. Bisher war es nicht erforderlich den KSEM im FHEM per ModBus abzufragen, was jedoch nun notwendig ist. In dieser Integration wurde der KSEM wegen des Schwarms auf WR_0_KSEM benannt. Im Device PV_Schedule wurde ein cmd_5 eingefügt, dass die Zählerstände zum Beginn einer Statistikperiode, Day/Month/Year in das Device WR_1_API überträgt. Initial müssen diese manuell korrekt gesetzt werden, damit die Berechnungen in den userReadings stimmen!
SW_Statistic_Yield_Month:Statistic_Yield_Month.* { round(ReadingsVal("$NAME","Statistic_Yield_Month",0)+ReadingsVal("WR_2_API","Statistic_Yield_Month",0),0) + 195000}, SW_Statistic_Yield_Year:Statistic_Yield_Year.* { round(ReadingsVal("$NAME","Statistic_Yield_Year",0)+ReadingsVal("WR_2_API","Statistic_Yield_Year",0),0) + 772000}, SW_Statistic_EnergyHomePv_Month:SW_Statistic_EnergyHomeFeedInGrid_Month.* { round(ReadingsVal("$NAME","SW_Statistic_Yield_Month",0) - ReadingsVal("$NAME","SW_Statistic_EnergyHomeFeedInGrid_Month",0) - ReadingsVal("$NAME","Statistic_EnergyHomeBat_Month",0),0) - 42000 }, SW_Statistic_EnergyHomePv_Year:SW_Statistic_EnergyHomeFeedInGrid_Year.* { round(ReadingsVal("$NAME","SW_Statistic_Yield_Year",0) - ReadingsVal("$NAME","SW_Statistic_EnergyHomeFeedInGrid_Year",0) - ReadingsVal("$NAME","Statistic_EnergyHomeBat_Year",0),0) - 158000 }, SW_Statistic_TotalConsumption_Month:SW_Statistic_EnergyHomePv_Month.* { round( (ReadingsVal("$NAME","SW_Statistic_EnergyHomePv_Month",0)+ReadingsVal("$NAME","Statistic_EnergyHomeBat_Month",0) +ReadingsVal("$NAME","SW_Statistic_EnergyHomeGrid_Month",0) ),0) + 42000}, SW_Statistic_TotalConsumption_Year:SW_Statistic_EnergyHomePv_Year.* { round( (ReadingsVal("$NAME","SW_Statistic_EnergyHomePv_Year",0)+ReadingsVal("$NAME","Statistic_EnergyHomeBat_Year",0) +ReadingsVal("$NAME","SW_Statistic_EnergyHomeGrid_Year",0) ),0) + 158000},
attr WR_1_API DbLogExclude .*
attr WR_1_API authRetries 1
attr WR_1_API disable 0
attr WR_1_API enableCookies 1
attr WR_1_API get04JSON .
attr WR_1_API get05JSON .
attr WR_1_API icon sani_solar
attr WR_1_API set06NoArg 1
attr WR_1_API set2201Hint 0,1
attr WR_1_API set2205Hint 0,1
attr WR_1_API set2206Hint 1,2
attr WR_1_API set2207Hint 0,4
attr WR_1_API set2311Hint 0,1
attr WR_1_API set50JSON .
attr WR_1_API set50TextArg 1
attr WR_1_API set6001NoArg 1
attr WR_1_API showBody 1
attr WR_1_API showError 1
attr WR_1_API sortby 112
attr WR_1_API stateFormat {\
my $calcVal = 0;;\
my $WR = "WR_1";;\
my $YearBefore = "LogDBRep_Statistic_previous_Year";;\
my $YearPrevious = POSIX::strftime("%Y",localtime(time_str2num(ReadingsTimestamp("$YearBefore","SW_Statistic_Yield_Year","null"))));;\
my $QuarterBefore = "LogDBRep_Statistic_previous_Quarter";;\
my $pvtd = sprintf("%04d",ReadingsVal("$name","SW_Statistic_Yield_Day",0)/1000 );;\
my $pvtm = sprintf("%04d",ReadingsVal("$name","SW_Statistic_Yield_Month",0)/1000 );;\
$pvtm .= ($QuarterPrevious ne "null") ? sprintf(" / %04d", ReadingsVal("$QuarterBefore",$QuarterPrevious."_SW_Statistic_Yield",0) ) : "";;\
my $pvty = sprintf("%05d",ReadingsVal("$name","SW_Statistic_Yield_Year",0)/1000 );;\
$pvty .= ($YearPrevious ne "0") ? sprintf(" / %05d", ReadingsVal("$YearBefore","SW_Statistic_Yield_Year",0) ) : "";;\
my $pvd = sprintf("%04d",ReadingsVal("$name","SW_Statistic_EnergyHomePv_Day",0)/1000 );;\
my $pvm = sprintf("%04d",ReadingsVal("$name","SW_Statistic_EnergyHomePv_Month",0)/1000 );;\
$pvm .= ($QuarterPrevious ne "null") ? sprintf(" / %04d", ReadingsVal("$QuarterBefore",$QuarterPrevious."_SW_Statistic_EnergyHomePv",0) ) : "";;\
my $pvy = sprintf("%05d",ReadingsVal("$name","SW_Statistic_EnergyHomePv_Year",0)/1000 );;\
$pvy .= ($YearPrevious ne "0") ? sprintf(" / %05d", ReadingsVal("$YearBefore","SW_Statistic_EnergyHomePv_Year",0) ) : "";;\
my $gfid = sprintf("%04d",ReadingsVal("$name","SW_Statistic_EnergyHomeFeedInGrid_Day",0)/1000 );;\
my $gfim = sprintf("%04d",ReadingsVal("$name","SW_Statistic_EnergyHomeFeedInGrid_Month",0)/1000 );;\
$gfim .= ($QuarterPrevious ne "null") ? sprintf(" / %04d", ReadingsVal("$QuarterBefore",$QuarterPrevious."_SW_Statistic_EnergyHomeFeedInGrid",0) ) : "";;\
my $gfiy = sprintf("%05d",ReadingsVal("$name","SW_Statistic_EnergyHomeFeedInGrid_Year",0)/1000 );;\
$gfiy .= ($YearPrevious ne "0") ? sprintf(" / %05d", ReadingsVal("$YearBefore","SW_Statistic_EnergyHomeFeedInGrid_Year",0) ) : "";;\
my $ebd = sprintf("%04d",ReadingsVal("$name","SW_Statistic_EnergyHomeGrid_Day",0)/1000 );;\
my $ebm = sprintf("%04d",ReadingsVal("$name","SW_Statistic_EnergyHomeGrid_Month",0)/1000 );;\
$ebm .= ($QuarterPrevious ne "null") ? sprintf(" / %04d", ReadingsVal("$QuarterBefore",$QuarterPrevious."_SW_Statistic_EnergyHomeGrid",0) ) : "";;\
my $eby = sprintf("%05d",ReadingsVal("$name","SW_Statistic_EnergyHomeGrid_Year",0)/1000 );;\
$eby .= ($YearPrevious ne "0") ? sprintf(" / %05d", ReadingsVal("$YearBefore","SW_Statistic_EnergyHomeGrid_Year",0) ) : "";;\
my $pvbd = sprintf("%04d",ReadingsVal("$name","Statistic_EnergyHomeBat_Day",0)/1000 );;\
my $pvbm = sprintf("%04d",ReadingsVal("$name","Statistic_EnergyHomeBat_Month",0)/1000 );;\
$pvbm .= ($QuarterPrevious ne "null") ? sprintf(" / %04d", ReadingsVal("$QuarterBefore",$QuarterPrevious."_Statistic_EnergyHomeBat",0) ) : "";;\
my $pvby = sprintf("%05d",ReadingsVal("$name","Statistic_EnergyHomeBat_Year",0)/1000 );;\
$pvby .= ($YearPrevious ne "0") ? sprintf(" / %05d", ReadingsVal("$YearBefore","Statistic_EnergyHomeBat_Year",0) ) : "";;\
my $etd = sprintf("%04d",ReadingsVal("$name","SW_Statistic_TotalConsumption_Day",0)/1000 );;\
my $etm = sprintf("%04d",ReadingsVal("$name","SW_Statistic_TotalConsumption_Month",0)/1000 );;\
$etm .= ($QuarterPrevious ne "null") ? sprintf(" / %04d", ReadingsVal("$QuarterBefore",$QuarterPrevious."_SW_Statistic_TotalConsumption",0) ) : "";;\
my $ety = sprintf("%05d",ReadingsVal("$name","SW_Statistic_TotalConsumption_Year",0)/1000 );;\
$ety .= ($YearPrevious ne "0") ? sprintf(" / %05d", ReadingsVal("$YearBefore","SW_Statistic_TotalConsumption_Year",0) ) : "";;\
my $aq = sprintf("%4d %%",(($calcVal > 100) ? 100 : $calcVal) );;\
my $aqd = sprintf("%3d %%",ReadingsVal("$name","SW_Statistic_Autarky_Day",0) );;\
my $aqm = sprintf("%3d %%",ReadingsVal("$name","SW_Statistic_Autarky_Month",0) );;\
my $aqy = sprintf("%3d %%",ReadingsVal("$name","SW_Statistic_Autarky_Year",0) );;\
$aqy .= ($YearPrevious ne "0") ? sprintf(" / %3d %%", ReadingsVal("$YearBefore","SW_Statistic_Autarky_Year",0) ) : "";;\
my $sq = sprintf("%4d %%",(($calcVal > 100) ? 100 : $calcVal) );;\
my $sqd = sprintf("%4d %%",ReadingsVal("$name","SW_Statistic_OwnConsumptionRate_Day",0) );;\
my $sqm = sprintf("%4d %%",ReadingsVal("$name","SW_Statistic_OwnConsumptionRate_Month",0) );;\
my $sqy = sprintf("%4d %%",ReadingsVal("$name","SW_Statistic_OwnConsumptionRate_Year",0) );;\
$sqy .= ($YearPrevious ne "0") ? sprintf(" / %3d %%", ReadingsVal("$YearBefore","SW_Statistic_OwnConsumptionRate_Year",0) ) : "";;\
my $date = POSIX::strftime("%Y-%m-%d",localtime(time_str2num(ReadingsTimestamp($name, "auth_me_authenticated",0))));;\
my $md = POSIX::strftime("%H:%M",localtime(time_str2num(ReadingsTimestamp($name, "auth_me_authenticated",0))));;\
my $cd = POSIX::strftime("%H:%M",localtime(time_str2num(ReadingsTimestamp($name, "SW_Statistic_Autarky_Day",0))));;\
my $cm = POSIX::strftime("%H:%M",localtime(time_str2num(ReadingsTimestamp($name, "SW_Statistic_Autarky_Month",0))));;\
$cm .= ($QuarterPrevious ne "null") ? " / ".POSIX::strftime("%d.%m",localtime(time_str2num(ReadingsTimestamp("$QuarterBefore","$QuarterPrevious",0) ))) : "";;\
my $cy = POSIX::strftime("%H:%M",localtime(time_str2num(ReadingsTimestamp($name, "SW_Statistic_Autarky_Year",0))));;\
$cy .= ($YearPrevious ne "0") ? " / ".$YearPrevious : "";;\
<colgroup>\
</colgroup>\
</table></html>"\
attr WR_1_API timeout 7
SW_Statistic_EnergyHomePv_Day:SW_Statistic_EnergyHomeFeedInGrid_Day.* { round(ReadingsVal("$NAME","SW_Statistic_Yield_Day" ,0) - ReadingsVal("$NAME","SW_Statistic_EnergyHomeFeedInGrid_Day" ,0) - ReadingsVal("$NAME","Statistic_EnergyHomeBat_Day" ,0),0) },\
SW_Statistic_EnergyHomePv_Month:SW_Statistic_EnergyHomeFeedInGrid_Month.* { round(ReadingsVal("$NAME","SW_Statistic_Yield_Month",0) - ReadingsVal("$NAME","SW_Statistic_EnergyHomeFeedInGrid_Month",0) - ReadingsVal("$NAME","Statistic_EnergyHomeBat_Month",0) - 42000 ,0) },\
SW_Statistic_EnergyHomePv_Year:SW_Statistic_EnergyHomeFeedInGrid_Year.* { round(ReadingsVal("$NAME","SW_Statistic_Yield_Year" ,0) - ReadingsVal("$NAME","SW_Statistic_EnergyHomeFeedInGrid_Year" ,0) - ReadingsVal("$NAME","Statistic_EnergyHomeBat_Year" ,0) - 158000 ,0) },\
SW_Statistic_EnergyHomePvSum_Day:SW_Statistic_EnergyHomeFeedInGrid_Day.* { round(ReadingsVal("$NAME","SW_Statistic_Yield_Day" ,0) - ReadingsVal("$NAME","SW_Statistic_EnergyHomeFeedInGrid_Day" ,0),0) },\
SW_Statistic_EnergyHome_Day:SW_Statistic_EnergyHomeFeedInGrid_Day.* {ReadingsVal("$NAME","SW_Statistic_Yield_Day" ,0) + ReadingsVal("$NAME","SW_Statistic_EnergyHomeGrid_Day" ,0) - ReadingsVal("$NAME","SW_Statistic_EnergyHomeFeedInGrid_Day" ,0) },\
SW_Statistic_TotalConsumption_Month:SW_Statistic_EnergyHomePv_Month.* {round( (ReadingsVal("$NAME","SW_Statistic_EnergyHomePv_Month",0)+ReadingsVal("$NAME","Statistic_EnergyHomeBat_Month",0) + ReadingsVal("$NAME","SW_Statistic_EnergyHomeGrid_Month",0) ),0)},\
SW_Statistic_TotalConsumption_Year:SW_Statistic_EnergyHomePv_Year.* {round( (ReadingsVal("$NAME","SW_Statistic_EnergyHomePv_Year",0)+ReadingsVal("$NAME","Statistic_EnergyHomeBat_Year",0) + ReadingsVal("$NAME","SW_Statistic_EnergyHomeGrid_Year",0) ),0)},\
SW_Statistic_OwnConsumptionRate_Day:SW_Statistic_EnergyHomePvSum_Day.* {my $SW_Statistic_Yield_Day = ReadingsVal("$NAME","SW_Statistic_Yield_Day",0) ;;;; ($SW_Statistic_Yield_Day eq 0)? 0 : round(ReadingsVal("$NAME","SW_Statistic_EnergyHomePvSum_Day" ,0) / $SW_Statistic_Yield_Day*100,0) },\
SW_Statistic_OwnConsumptionRate_Month:SW_Statistic_EnergyHomePvSum_Month.* {my $SW_Statistic_Yield_Month = ReadingsVal("$NAME","SW_Statistic_Yield_Month",0) ;;;; ($SW_Statistic_Yield_Month eq 0)? 0 : round(ReadingsVal("$NAME","SW_Statistic_EnergyHomePvSum_Month" ,0) / $SW_Statistic_Yield_Month*100,0) },\
SW_Statistic_OwnConsumptionRate_Year:SW_Statistic_EnergyHomePvSum_Year.* {my $SW_Statistic_Yield_Year = ReadingsVal("$NAME","SW_Statistic_Yield_Year",0) ;;;; ($SW_Statistic_Yield_Year eq 0)? 0 : round(ReadingsVal("$NAME","SW_Statistic_EnergyHomePvSum_Year" ,0) / $SW_Statistic_Yield_Year*100,0) },\
SW_Statistic_OwnConsumptionRate_Total:SW_Statistic_EnergyHomePv_Total.* {my $SW_Statistic_Yield_Total = ReadingsVal("$NAME","SW_Statistic_Yield_Total",0) ;;;; ($SW_Statistic_Yield_Total eq 0)? 0 : round(ReadingsVal("$NAME","SW_Statistic_EnergyHomePv_Total" ,0) / $SW_Statistic_Yield_Total*100,0) }
attr WR_1_API verbose 0
DOELSEIF\
([00:01])\
({if ($mday eq 1)\
if ($yday eq 1)\
attr WR_2_API DbLogExclude .*
attr WR_2_API authRetries 1
attr WR_2_API disable 0
attr WR_2_API enableCookies 1
attr WR_2_API get04JSON .
attr WR_2_API get05JSON .
attr WR_2_API icon sani_solar
attr WR_2_API set06NoArg 1
attr WR_2_API set50JSON .
attr WR_2_API set50TextArg 1
attr WR_2_API showBody 1
attr WR_2_API showError 1
attr WR_2_API sortby 212
attr WR_2_API timeout 7
attr WR_2_API verbose 0
Speicher Basissteuerung
smart_laden und laden_beendet
Umsetzung:
Nebeneffekte:
([07:00|8])
DOELSEIF
([00:00|7])
DOELSEIF
MaxSOC Kontrolle
Aktivierung: SpeicherMaxSOCControlActive An Aktivität : SpeicherMaxSOCControlRunning Aus = momentan keine Steuerung SpeicherMaxSOC_Actual 100 <<< wird berechnet, kann jedoch für diesen Tag anschließend überschrieben werden SpeicherMaxSOC_DayBefore 100 <<< wird berechnet und dient als Merker Konfiguration: Dieser Wert muss auf die Anlage angepasst werden und dient als Schwellwert. Die Leistungsangabe soll so hoch sein, dass der Speicher, bei diesem Forecast, auf jeden Fall mit einer Überschussleistung von 3* MinSOC aus der Nacht kommt. Im Frühjahr ist dies besonders gut abzuschätzen, sobald eine Wärmepumpe nachts nicht mehr heizt und nur noch die Grundversorgung in der Nacht aus dem Speicher gedeckt werden muss. Durch die Abfrage des Forecasts von morgen ist hierbei berücksichtigt, dass bei einer schlechten Prognose die Speicherladung nicht limitiert wird, was auch im Sommer mal der Fall sein kann. SpeicherMaxSOC_fc1_Limit 30000
Middayhigh Kontrolle
Aktivierung: SpeicherMiddayControlActive An Aktivität : SpeicherMiddayControlRunning Aus = momentan keine Steuerung WR_1:Solar_middayhigh_fc0 0 = Es gibt kein Mittags Hoch. Wird aus Solar_forecast() gesetzt WR_1:Solar_middayhigh_fc0_start 00:00 <<<< wird aus dem Forecast berechnet WR_1:Solar_middayhigh_fc0_stop 00:00 <<<< wird aus dem Forecast berechnet Konfiguration: Der Wert von SpeicherMidday_MaxChargePowerAbs sollte so gewählt werden, dass der Speicher am Vormittag langsam und gleichmäßig bis auf SpeicherMidday_MaxSOC geladen wird. Ab der PV_1:Solar_middayhigh_fc0_start wird dann unlimitiert bis zur PV_1:Solar_middayhigh_fc0_stop in der Mittagszeit weiter geladen. Wenn SpeicherMaxSOCControlActive auf 1 ist, wird hierbei weiterhin das Laden limitiert. SpeicherMidday_Inverter_Max_Power 8500 <<<< hier kann man manuell einen Wert festlegen, wenn es keine 70% Regelung gibt SpeicherMidday_MaxChargePowerAbs_midday 1000 <<<< hängt vom Speicher ab; Wird der wert auf 0 gesetzt, so erfolgt eine dynamische Berechnung zur Laufzeit SpeicherMidday_MaxChargePowerAbs_morning 450 <<<< hängt vom Speicher ab SpeicherMidday_MaxSOC 30 <<<< Es soll nur bis dahin geladen werden, damit Mittags genug Platz ist
- Block 2_smart_Laden_start_WB_1 - Block 3_smart_Laden_beenden_WB_1 - Im Block 3_smart_Laden_beenden_Automatik ist eine zusätzliche Bedingung and\ [$SELF:WB_1_smart_laden_before] eq "---" ## Es wird gerade kein Fahrzeug geladen\ - setstate WR_1_Speicher_1_ExternControl WB_1_smart_laden_before ---
openWB: [WB_1:lp_1_ChargeStat] eq "loading" go-eCharger: [WB_1:car_state] eq "2" ## Ladevorgang läuft
1_Status_WR_1_Speicher_1\
and\
( [:52] ## jede Stunde\
or [$SELF:ui_command_1] eq "Status_Speicher" ## Hier wird das uiTable select ausgewertet\
if( [$SELF:ui_command_1] eq "Status_Speicher" ) { ## Hier wurde manuell eingeschaltet\
Log 3, "$SELF cmd_1 : Speicher Status abfrage"\
and\
[$SELF:SpeicherEntladung] eq "Automatik" ## Nur für den Automatik Modus\
and\
( [WR_1:Solar_Calculation_fc0_day] < [$SELF:SpeicherMinSOC_fc1_Limit] ## Im Herbst/Winter ist wenig zu erwarten\
and [WR_1:Act_state_of_charge] <= [WR_1_API:Battery_InternControl_MinSoc] ## Achtung der Speicherstand wird zu niedrig\
and [WR_1_API:Battery_InternControl_MinHomeConsumption] <= 100 ## Der Speicher steht auf Entladen\
or [$SELF:ui_command_1] eq "smart_Laden_start" ## Hier wird das uiTable select ausgewertet\
if( [$SELF:ui_command_1] eq "smart_Laden_start" ) { ## Hier wurde manuell eingeschaltet\
set_Reading("SpeicherExternTrigger","gesperrt");; ## Externe Trigger verriegeln \
2_smart_Laden_start_WB_1\
and [WB_1:lp_1_ChargeStat] eq "loading" ## Ein Fahrzeug wird gerade geladen\
and [$SELF:SpeicherWB_1_buffer] eq "Aus" ## Der Speicher darf nicht zum Laden verwendet werden\
or\
[$SELF:ui_command_1] eq "smart_Laden_starten_WB_1" ## Hier wird das uiTable select ausgewertet\
if( [$SELF:ui_command_1] eq "smart_Laden_starten_WB_1" ) { ## Hier wurde manuell eingeschaltet\
fhem("setreading $SELF WB_1_smart_laden_before aktiv");; ## Den vorherigen Zustand merken\
fhem("setreading $SELF WB_1_smart_laden_before inaktiv");; ## Den vorherigen Zustand merken\
{Log 3, "$SELF cmd_2.2: WallBox es wird gerade geladen"};; ## Der vorherige Zustand war schon bekannt\
and\
and\
and\
[WR_1_API:Battery_InternControl_MinHomeConsumption] > 100 ## Das Speicher Entladen ist geperrt\
and\
[WR_1:Act_state_of_charge] >= 90 ## Der Speicher ist bereits 90% voll oder vor dem\
or [$SELF:ui_command_1] eq "smart_Laden_beenden" ## Hier wird das uiTable select ausgewertet\
if( [$SELF:ui_command_1] eq "smart_Laden_beenden" ) { ## Hier wurde manuell aktiviert\
{Log 3, "$SELF cmd_3.1: Batterie wird mit Automatik gesteuert";;\
Log 3, "$SELF cmd_3.1: Batterie auf ".[WR_1:Act_state_of_charge]." %, Entlademodus freigegeben"};;\
set_Reading("SpeicherExternTrigger","none");; ## den externen Trigger wieder freigeben\
3_smart_Laden_beenden_WB_1\
and\
[WB_1:lp_1_ChargeStat] ne "loading" ## Es wird gerade kein Fahrzeug geladen\
and\
[$SELF:WB_1_smart_laden_before] eq "inaktiv" ## Vorher war es nicht aktiv\
or [$SELF:ui_command_1] eq "smart_Laden_beenden_WB_1" ## Hier wird das uiTable select ausgewertet\
if( [$SELF:ui_command_1] eq "smart_Laden_beenden_WB_1" ) { ## Hier wurde manuell eingeschaltet\
set_Reading("WB_1_smart_laden_before","---");; ## den Merker wieder zurück setzen\
{Log 3, "$SELF cmd_3.2: Batterie wird mit Automatik gesteuert";;\
Log 3, "$SELF cmd_3.2: Batterie auf ".[WR_1:Act_state_of_charge]." %, Entlademodus freigegeben"};;\
3_smart_Laden_beenden_Zeit\
and\
[$SELF:SpeicherEntladung] eq "Zeit" and ## Nur für den Zeit Modus\
and\
[WR_1:Act_state_of_charge] >= 40 ## und einem Stand von Soc 40%\
and\
([WR_1:Solar_Calculation_fc0_day] > [$SELF:SpeicherMinSOC_fc1_Limit] ## wenn es heute oder \
or [WR_1:Solar_Calculation_fc1_day] > [$SELF:SpeicherMinSOC_fc1_Limit]) ## morgen viel Leistung gibt\
if( [$SELF:ui_command_1] eq "smart_Laden_beenden" ) { ## Hier wurde manuell eingeschaltet\
{Log 3, "$SELF cmd_3.3: Batterie wird mit Zeitsteuerung gesteuert";;\
Log 3, "$SELF cmd_3.3: Batterie auf ".[WR_1:Act_state_of_charge]." %, SpeicherExternTrigger, freigegeben"};;\
set_Reading("SpeicherExternTrigger","frei");; ## Trigger freigeben\
set_Reading("SpeicherTrigger","entladen");; ## Signalisiere entladen im stateFormat\
## z.B. ([07:00-16:00]\
4_Trigger\
and\
( [$SELF:SpeicherExternTrigger] eq "frei" ## Verriegelung, wenn zwangsgeladen werden muss\
and\
( [$SELF:SpeicherEntladung] eq "Trigger" ## Triggersteuerung\
and [$SELF:SpeicherTrigger] eq "entladen" ## also Speicherentladung freigeben\
or \
[$SELF:SpeicherEntladung] eq "Zeit" ## oder bei Zeitsteuerung wenn das\
and [[$SELF:SpeicherZeitStart]-[$SELF:SpeicherZeitEnde]] ## Zeitfenster aktiv ist\
and [$SELF:ui_command_1] ne "smart_Laden_beenden"\
or [$SELF:ui_command_1] eq "Trigger" ## Hier wird das uiTable select ausgewertet\
if( [$SELF:ui_command_1] eq "Trigger" ) { ## Hier wurde manuell eingeschaltet\
::CommandSet(undef, "WR_1_API 22_03_Battery_MinHomeConsumption 50");; ## Speicher für Entladung freigeben\
## z.B. [16:00-07:00]\
5_Trigger_sperren\
and\
and\
or \
and [[$SELF:SpeicherZeitEnde]-[$SELF:SpeicherZeitStart]] ## Zeitfenster verlassen wurde\
or [$SELF:ui_command_1] eq "Trigger_sperren" ## Hier wird das uiTable select ausgewertet\
set_Reading("SpeicherTrigger","gesperrt");; ## Signalisiere gesperrt im stateFormat\
6_Kommando_Wiederholung\
and\
[$SELF:SpeicherCmdRepeatActive] eq "An" and ## Wenn die ExternControl Aktiviert ist\
[$SELF:SpeicherCmdRepeatRunning] eq "An" and ## Wenn es ExternControl Kommandos zum Senden gibt\
[ {sunrise_abs("HORIZON=+5.0",0,"6:00","08:35")} ## Innerhalb der Photovoltaik Zeit\
[+[WR_1_API:Battery_ComMonitor_Time]] ## alle 3 Minuten den Befehl wiederholen\
or [$SELF:ui_command_1] eq "Kommando_Wiederholung" ## Hier wird das uiTable select ausgewertet\
if( [$SELF:ui_command_1] eq "Kommando_Wiederholung" ) { ## Hier wurde manuell eingeschaltet\
my $MaxChargePowerTime = 0;;\
if ([$SELF:SpeicherMiddayControlRunning] eq "An" ) { ## Wurde ein Mittagshoch ermittelt und aktiviert?\
::CommandSet(undef, "WR_1_API 23_07_Battery_ExternControl_MaxChargePowerAbs 0");; ## nicht vor z.B. 09:00 Uhr starten. Ladung auf 0 Watt setzen\
Log 3, "$SELF cmd_6 : SpeicherMiddayControl vor ".[$SELF:SpeicherMidday_NotBefore]." Uhr noch nicht laden";;\
} else { ## Ist noch Vormittag?\
if ( time < ::time_str2num(POSIX::strftime("%Y-%m-%d",localtime(time))." ".[WR_1:Solar_middayhigh_fc0_start].":00") ) {\
::CommandSet(undef, "WR_1_API 23_09_Battery_ExternControl_MaxSocRel ".[$SELF:SpeicherMidday_MaxSOC]);;\
Log 3, "$SELF cmd_6 : SpeicherMiddayControl vor ".[WR_1:Solar_middayhigh_fc0_start]." limitieren";;\
Log 3, "$SELF cmd_6 : Battery_ExternControl_MaxChargePowerAbs auf ".[$SELF:SpeicherMidday_MaxChargePowerAbs_morning]." limitiert";;\
Log 3, "$SELF cmd_6 : Battery_ExternControl_MaxSOC auf ".[$SELF:SpeicherMidday_MaxSOC]." % limitiert";;\
Log 3, "$SELF cmd_6 : Battery_InternControl_MinSoc auf ".([WR_1_API:Battery_InternControl_MinSoc] *3)." % laden";;\
if (::time_str2num(POSIX::strftime("%Y-%m-%d",localtime(time))." ".[WR_1:Solar_middayhigh_fc0_start].":00") <= time and ## Es ist Mittag\
time <= ::time_str2num(POSIX::strftime("%Y-%m-%d",localtime(time))." ".[WR_1:Solar_middayhigh_fc0_stop].":00") ) {\
if ([$SELF:SpeicherMaxSOCControlRunning] eq "An" and ## Somit bleibt weniger Platz im Speicher und es ist\
time < ::time_str2num(POSIX::strftime("%Y-%m-%d",localtime(time))." 12:00:00") ) { ## besser nicht vor 12:00 Uhr zu beginnen.\
::CommandSet(undef, "WR_1_API 23_07_Battery_ExternControl_MaxChargePowerAbs 0");;\
{Log 3, "$SELF cmd_6 : SpeicherMiddayControlActive laden wegen MaxSoc von ".[WR_1:Solar_middayhigh_fc0_start]." auf 12:00 Uhr verschoben"};;\
$MaxChargePowerTime = ::round((::time_str2num(POSIX::strftime("%Y-%m-%d",localtime(time))." ".[WR_1:Solar_middayhigh_fc0_stop].":00") - time) / 3600 , 2);; ## Mittags Ladezeit bestimmen\
$MaxChargePowerAbs_midday = ::round( [WR_1:Battery_work_capacity] * ([$SELF:SpeicherMaxSOC_Actual] - [WR_1:Act_state_of_charge]) / 100 / $MaxChargePowerTime, 0);;\
if ($MaxChargePowerAbs_midday < 0) { $MaxChargePowerAbs_midday = 0 };;## Nicht unter 0\
Log 3, "$SELF cmd_6 : Mittags $MaxChargePowerTime h mit $MaxChargePowerAbs_midday W laden";;\
Log 3, "$SELF cmd_6 : SpeicherMiddayControlActive laden von ".[WR_1:Solar_middayhigh_fc0_start]." bis ".[WR_1:Solar_middayhigh_fc0_stop]." freigegeben";;\
Log 3, "$SELF cmd_6 : Battery_ExternControl_MaxSocRel ".[$SELF:SpeicherMaxSOC_Actual]." % halten"\
if (time > ::time_str2num(POSIX::strftime("%Y-%m-%d",localtime(time))." ".[WR_1:Solar_middayhigh_fc0_stop].":00") ) { ## Es ist Nachmittag und die\
set_Reading("SpeicherMiddayControlRunning","Aus");; ## Mittagssteuerung wird abgeschaltet\
Log 3, "$SELF cmd_6 : Battery_ExternControl_MaxSocRel ".[$SELF:SpeicherMaxSOC_Actual]." % halten";;\
Log 3, "$SELF cmd_6 : SpeicherMiddayControl nach ".[WR_1:Solar_middayhigh_fc0_stop]." beendet";;\
ReadingsVal("$SELF","SpeicherMiddayControlRunning","") eq "Aus") { ## sobald die Mittagssteuerung fertig ist\
{Log 3, "$SELF cmd_6 : Battery_ExternControl_MaxSocRel ".[$SELF:SpeicherMaxSOC_Actual]." % halten"};;\
{Log 3, "$SELF cmd_6 : ExternControl Kommando Wiederholung erledigt"};;\
7_SOC_Calculation\
and\
([$SELF:SpeicherMaxSOCControlActive] eq "An" or ## Ist MaxSOC Limit konfiguriert\
[$SELF:SpeicherMiddayControlActive] eq "An" ) and ## Ist Midday Kontrolle konfiguriert\
[$SELF:SpeicherMaxSOC_MinSOC_Time] eq "NULL" and ## Wurde ein minimum SOC bereits ermittelt\
or [$SELF:ui_command_1] eq "SOC_Calculation" ## Hier wird das uiTable select ausgewertet\
if( [$SELF:ui_command_1] eq "SOC_Calculation" ) { ## Hier wurde manuell eingeschaltet\
my $MinSOC_MinSOC = ::round([WR_1:Act_state_of_charge],0);; ## Festgestellter MinSOC am Morgen Magic ???\
my $SpeicherSOCDayBefore = ::round(ReadingsVal("$SELF","SpeicherMaxSOC_DayBefore", 100),0);; ## wie voll war er gestern noch?\
my $SpeicherSOCNew = 0;;\
my $SpeicherSOCDelta = 0;;\
Log 3, "$SELF cmd_7 : Leistung Prognose ".[WR_1:Solar_Calculation_fc1_day]." wh > Schwellwert ".[$SELF:SpeicherMaxSOC_fc1_Limit]." wh";;\
$SpeicherSOCNew = ::round(($SpeicherSOCDayBefore+$SpeicherSOCDayBefore-$SpeicherSOCDelta)/2 ,0);; ## um den Durchschnitt verringern\
set_Reading("SpeicherMaxSOC_Actual",$SpeicherSOCNew);; ## Das soll heute in den Speicher\
set_Reading("SpeicherMaxSOCControlRunning","An");; ## Senden starten\
set_Reading("SpeicherCmdRepeatRunning","An");; ## Wiederholung starten\
$SpeicherSOCNew = ::round($SpeicherSOCDayBefore+$SpeicherSOCMinimum-$MinSOC_MinSOC ,0);;\
if ([$SELF:SpeicherMiddayControlActive] eq "An" and ## Soll für mittags noch Platz gehalten werden?\
[WR_1:Solar_middayhigh_fc0] == 1 ) { \
set_Reading("SpeicherMiddayControlRunning","An");; ## Die Mittagskontrolle aktivieren\
Log 3, "$SELF cmd_7 : Batterie Solar_middayhigh_fc0_start ".ReadingsVal("WR_1","Solar_middayhigh_fc0_start", "00:00")." gesetzt";;\
Log 3, "$SELF cmd_7 : Batterie Solar_middayhigh_fc0_stop ".ReadingsVal("WR_1","Solar_middayhigh_fc0_stop", "00:00")." gesetzt";;\
} else { ## Kein Mittagshoch\
8_Reset\
and\
[{sunset_abs("HORIZON=+8.0",0,"16:00","21:00")}] ## hier sollte das Ende der PV-Zeit sein\
or [$SELF:ui_command_1] eq "Reset" ## Hier wird das uiTable select ausgewertet\
if( [$SELF:ui_command_1] eq "Reset" ) { ## Hier wurde manuell eingeschaltet\
set_Reading("SpeicherCmdRepeatRunning","Aus");; ## Stop das regelmäßige senden der Kommandos\
set_Reading("SpeicherMaxSOCControlRunning","Aus");; ## Max SOC Steuerung zurücksetzen\
set_Reading("SpeicherMaxSOC_Actual","100");; ## SpeicherMaxSOC_Actual auf Default\
set_Reading("SpeicherMaxSOC_DayBefore",[WR_1:Act_state_of_charge]);; ## Den vor Tages Wert merken\
set_Reading("SpeicherMaxSOC_MinSOC_Time","NULL");; ## Die MinSOC Time löschen\
set_Reading("SpeicherMiddayControlRunning","Aus");; ## Midday Steuerung zurücksetzen\
fhem("setreading WR_1 Solar_middayhigh_fc0 0");;\
fhem("setreading WR_1 Solar_middayhigh_fc0_start 00:00");;\
fhem("setreading WR_1 Solar_middayhigh_fc0_stop 00:00");;\
fhem("setreading WR_1 Solar_middayhigh_fc1 0");;\
fhem("setreading WR_1 Solar_middayhigh_fc1_start 00:00");;\
fhem("setreading WR_1 Solar_middayhigh_fc1_stop 00:00");;\
9_MinSOC_Winter\
and\
([WR_1:Solar_Calculation_fc1_day] < [$SELF:SpeicherMinSOC_fc1_Limit] and ## Wenn morgen das Minimum an Leistung nicht erreicht wird\
[$SELF:SpeicherMaxSOC_MinSOC_Time] eq "gefunden" \
or [$SELF:ui_command_1] eq "Winter" ## Hier wird das uiTable select ausgewertet\
if( [$SELF:ui_command_1] eq "Winter" ) { ## Hier wurde manuell eingeschaltet\
::CommandSet(undef, "WR_1_API 22_04_Battery_MinSoc ".[$SELF:SpeicherMinSOC_Winter]);; ## Den MinSOC anheben, um eine eventuelle\
set_Reading("SpeicherMaxSOCControlRunning","Aus");; ## Im Winter Betrieb keine MaxSOC Begrenzung\
set_Reading("SpeicherMiddayControlRunning","Aus");; ## und keine Midday Steuerung\
10_MinSOC_Sommer\
and\
([WR_1:Solar_Calculation_fc1_day] > [$SELF:SpeicherMinSOC_fc1_Limit] and ## sobald viel Ladung erwartet wird und der MinSoc noch\
[10:09] \
or [$SELF:ui_command_1] eq "Sommer" ## Hier wird das uiTable select ausgewertet\
if( [$SELF:ui_command_1] eq "Sommer" ) { ## Hier wurde manuell eingeschaltet\
::CommandSet(undef, "WR_1_API 22_04_Battery_MinSoc ".[$SELF:SpeicherMinSOC_Sommer]);; ## den MinSOC auf Sommerbetrieb herabsetzen, es kann\
11_Speicher_voll\
and\
( [WR_1:Solar_Calculation_fc0_day] > [$SELF:SpeicherMaxSOC_fc1_Limit] and ## 1) sobald viel Leistung erwartet wird und der Speicher voll ist\
[WR_1:Act_state_of_charge] == 100 ## den MaxSOC wieder reduzieren, damit nicht immer nachgeladen wird\
or\
[WR_1:Act_state_of_charge] <= 98 and ## und der SOC unte 98 % gefallen ist\
[{sunset_abs("HORIZON=+8.0",-7200,"15:00","21:00")}]) ## zwei Stunden vor Sonnenuntergang eventuell wieder nachladen\
or [$SELF:ui_command_1] eq "Speicher_voll" ## Hier wird das uiTable select ausgewertet\
if( [$SELF:ui_command_1] eq "Speicher_voll" ) { ## Hier wurde manuell eingeschaltet\
if ([WR_1:Act_state_of_charge] <= 97) {\
set_Reading("SpeicherMaxSOC_Actual","100");; ## Eventuell noch mal nachladen\
set_Reading("SpeicherCmdRepeatRunning","An");; ## Start regelmäßiges senden der Kommandos\
set_Reading("SpeicherMaxSOCControlRunning","An");; ## MaxSOC Begrenzung weil Speicher bereits 100 % hat\
12_DC_Power_Abs \
and\
[$SELF:ui_command_1] eq "DC_Power_Abs" ## Hier wird das uiTable select ausgewertet\
if( [$SELF:ui_command_1] eq "DC_Power_Abs" ) { ## Hier wurde manuell eingeschaltet\
Log 3, "$SELF cmd_12 : Battery_ExternControl_DcPowerAbs auf ".[$SELF:SpeicherDcPowerAbs]." gesetzt";;\
## Wer keinen BYD HV Speicher hat kann das löschen\
and\
or\
[$SELF:ui_command_1] eq "Status_WR_1_Speicher_1_BYD" ## Hier wird das uiTable select ausgewertet\
if( [$SELF:ui_command_1] eq "Status_WR_1_Speicher_1_BYD" ) { ## Hier wurde manuell eingeschaltet\
## return undef;; ## Das verhindert die Log Meldung vom letzten CommandGet()\
Log 3, "$SELF cmd_13 : Speicher Status abfrage, BYD HV direkt"\
attr WR_1_Speicher_1_ExternControl comment Version 2022.03.10 13:00\
ExternTrigger\
Speicher*ControlActive\
SpeicherCmdRepeatActive\
SpeicherMiddayControl\
SpeicherMaxSOCControl\
SpeicherMinSOC\
attr WR_1_Speicher_1_ExternControl setList SpeicherExternTrigger:frei,gesperrt SpeicherCmdRepeatActive:0,1 SpeicherZeitStart:time SpeicherZeitEnde:time SpeicherEntladung:Automatik,Zeit,Trigger SpeicherTrigger:entladen,gesperrt,none SpeicherMiddayControlActive:0,1 SpeicherMidday_Inverter_Max_Power:slider,3000,500,20000 SpeicherMidday_MaxChargePowerAbs_morning:slider,0,50,1000 SpeicherMidday_MaxChargePowerAbs_midday:slider,0,100,4700 SpeicherMidday_MaxSOC:slider,20,5,50 SpeicherMidday_NotBefore:time SpeicherMinSOC_Sommer:slider,5,1,20 SpeicherMinSOC_Winter:slider,5,1,20 SpeicherMinSOC_fc1_Limit:slider,7000,500,17000 SpeicherMaxSOCControlActive:0,1 SpeicherMaxSOC_Actual:slider,60,5,100 SpeicherMaxSOC_DayBefore:slider,15,5,100 SpeicherMaxSOC_fc1_Limit:slider,10000,2000,50000
## $TR{0} = "style='color:yellow;;text-align:left;;font-weight:bold;;font-size:18px'";; ## Reihe 0 für Überschrift\
sub FUNC_batt {\
my($val)=@_;;\
return $ret;;\
sub FUNC_Status {\
return $ret;;\
"$SELF"|"Kommando<dd>Auswahl / DcPowerAbs / Status</dd>" | widget([$SELF:ui_command_1],"uzsuDropDown,---,Status_Speicher,smart_Laden_start,smart_Laden_beenden,smart_Laden_starten_WB_1,smart_Laden_beenden_WB_1,Kommando_Wiederholung,SOC_Calculation,Reset,DC_Power_Abs,Sommer,Winter,Speicher_voll,Status_WR_1_Speicher_1_BYD") | widget([$SELF:SpeicherDcPowerAbs],"selectnumbers,-4500,250,4500,0,lin")."W" |[WR_1_API:Battery_EM_State]|([$SELF:SpeicherExternTrigger] eq "gesperrt" and [WR_1_API:Battery_InternControl_MinHomeConsumption] == 30000)?'<span style="color:red">smart_Laden aktiv</span>':""\
FUNC_Status([WR_1:Solar_Calculation_fc1_day],[$SELF:SpeicherMaxSOC_fc1_Limit],"red","<",0,0,([$SELF:SpeicherMaxSOC_fc1_Limit]-1),"#00FF00",">="). widget([$SELF:SpeicherMaxSOC_fc1_Limit],"selectnumbers,2000,1000,40000,0,lin") | widget([$SELF:SpeicherMaxSOC_MinSOC_Time],"time"). widget([$SELF:SpeicherMaxSOC_MinSOC_MinSOC],"selectnumbers,5,1,100,0,lin") |\
|"Mittags Limits<dd>Inverter_Max_Power / Laden nicht vor / Start /Stop<br>MaxSOC morgens / Power morgens / Power mittags</dd>" | widget([$SELF:SpeicherMidday_Inverter_Max_Power],"selectnumbers,1000,250,15000,0,lin")."W<br>".widget([$SELF:SpeicherMidday_MaxSOC],"selectnumbers,5,1,100,0,lin")."%" | widget([$SELF:SpeicherMidday_NotBefore],"time").widget([$SELF:SpeicherMidday_MaxChargePowerAbs_morning],"selectnumbers,0,50,1000,0,lin")."W" | widget([WR_1:Solar_middayhigh_fc0_start],"time").widget([$SELF:SpeicherMidday_MaxChargePowerAbs_midday],"selectnumbers,0,100,4700,0,lin")."W" | widget([WR_1:Solar_middayhigh_fc0_stop],"time").([$SELF:SpeicherMidday_MaxChargePowerAbs_midday] == 0)?"dynamisch":""\
FUNC_Status([WR_1:Solar_Calculation_fc1_day],[$SELF:SpeicherMinSOC_fc1_Limit],"red","<",0,0,([$SELF:SpeicherMinSOC_fc1_Limit]-1),"#00FF00",">=").widget([$SELF:SpeicherMinSOC_fc1_Limit],"selectnumbers,2000,1000,40000,0,lin")."wh" |\
widget([$SELF:SpeicherMinSOC_Winter],"selectnumbers,10,1,30,0,lin").widget([$SELF:SpeicherMinSOC_Sommer],"selectnumbers,5,1,10,0,lin")."%" |""|[WR_1_API:Battery_InternControl_MinSoc]." %"
setstate WR_1_Speicher_1_ExternControl 2022-03-29 14:33:58 SpeicherMaxSOC_Actual 95
setstate WR_1_Speicher_1_ExternControl 2022-03-28 18:54:06 SpeicherMaxSOC_DayBefore 99.00
setstate WR_1_Speicher_1_ExternControl 2022-03-29 08:10:03 SpeicherMaxSOC_MinSOC_MinSOC 11
setstate WR_1_Speicher_1_ExternControl 2021-12-03 10:39:12 SpeicherMidday_Inverter_Max_Power 8500
RAW Definition des KSEM
attr WR_0_KSEM disable 0
attr WR_0_KSEM sortby 140
attr WR_0_KSEM verbose 0
BYD HV Speicher (mit HTTPMOD)
Implementiert sind derzeit:
userreading:
KeyValue() speichern
Device über Device Hardware Protokoll Netzwerk Informationen WR_0_KSEM WR_1 KSEM MODBUS LAN Messwerte vom Netzanschlusspunkt WR_1 rs485 4 Draht zum WR Notwendig, wenn ein Speicher am Plenticore betrieben wird WR_1 Plenticore MODBUS LAN Messwerte und berechnete Werte, teilweise Speicher Informationen WR_1_API HTTPMOD LAN Statistiken, Speichersteuerung und Informationen WR_1_Speicher_1 BYD HV HTTPMOD LAN/WLAN Speicher Details, auch über einzelne Zellen WR_1 rs485 4 Draht zum WR Verwendet von Plenticore zur Steuerung des Speichers WR_2 Plenticore MODBUS LAN Messwerte und berechnete Werte, teilweise Speicher Informationen WR_2_API HTTPMOD LAN Statistiken, Speichersteuerung und Informationen FHEM Steuerung MODBUS LAN Laufende Informationen im Minuten Takt HTTPMOD LAN Abfragen und Steuerung einzelner Devices PV_Schedule DOIF Startet regelmäßige Aktionen 1 Stündlich 1.1 WR_2_API 20_Statistic_EnergyFlow Statistiken vom Plenticore abholen; die Reihenfolge ist auch wichtig! 1.2 WR_1_API 20_Statistic_EnergyFlow Statistiken vom Plenticore abholen 2 Stündlich von 07:00 bis 20:00 2.1 WR_1_config module_1_covered Schnee auf den Modulen (noch in der Entwicklungsphase) 2.2 Solar_forecast() für fc0 Aktualisieren der fc0 Prognose 3 zweimal am Tag 3.1 Solar_forecast() für fc1 Aktualisieren der fc1 Prognose 4 alle 5 Minuten 4.1 WR_2_API 04_auth_me Aktualisieren der Bilanz (es wird ein Event erzeugt) 4.2 WR_1_API 04_auth_me Der Master Wechselrichter kommt zum Schluss, damit die SW_* readings auch von anderen Wechselrichtern die richtigen Werte haben. WR_*_config DUMMY Konfiguration für Strings,Ausrichtung,Nennleistung,IP-Adressen,Forecast WR_1_Speicher_1_ExternControl DOIF Externe Speichersteuerung 1 Stündlich 1.1 WR_1_API 21_Battery_Information Allgemeine Informationen Battery_Info_SoC, Battery_Info_WorkCapacity 1.2 WR_1_API 22_Battery_InternControl Speicher Information der Internen Steuerung Battery_InternControl_MinSoc, Battery_InternControl_MinHomeConsumption 1.3 WR_1_API 23_Battery_ExternControl Speicher Information der Externen Steuerung 1.4 WR_1_API 25_Battery_EM_State Speicher Status z.B. "Normal" 2 Unterschreitung des MinSOC im Winter 2.1 smart_laden PV Überschuss wird in Batterie geladen. Keine Entladung 2.2 WR_1_Speicher_1_ExternControl ExternTrigger gesperrt Batterie ExternTrigger, Entlademodus gesperrt . Die Zeit Steuerung wird verriegelt 3 Freigabe zur Entladung im Winter 3.1 bei überschreiten von SOC 90% Sobald der Speicher gut gefüllt ist oder WR_1_API:Battery_Info_SoC 3.2 Bei Zeitsteuerung und guter Prognose mit SOC 40% bereits vorher, weil der Tarif teuer ist 4 Speicher Freigabe bei Trigger oder Zeit Steuerung Dieses cmd_ löst die Abhängigkeiten von Zeit und Trigger auf 5 Speicher sperren bei Trigger oder Zeit Steuerung Dieses cmd_ löst die Abhängigkeiten von Zeit und Trigger auf 6 Wiederhole alle 180s die Kommandos der ExternControl Steuerung Wenn keine Wiederholung erfolgt geht der Plenticore wieder auf die interne Steuerung 6.1 WR_1_Speicher_1_ExternControl:SpeicherMiddayControlActive wird durchlaufen, wenn der Forecast eine z.B. 70% Überschreitung erkannt hat und WR_1_Speicher_1_ExternControl:SpeicherMidday_MaxSOC begrenzt dann morgens den MaxSOC WR_1_Speicher_1_ExternControl:SpeicherMidday_MaxChargePowerAbs_midday und den MaxChargePowerAbs WR_1_Speicher_1_ExternControl:SpeicherMidday_MaxChargePowerAbs_morning für morgens und mittags 6.2 WR_1_Speicher_1_ExternControl:SpeicherMaxSOC Wenn morgens der Speicher zu voll war, wird der MaxSOC bis abends begrenzt 6.3 WR_1:Solar_middayhigh_fc0_start <> WR_1:Solar_middayhigh_fc0_stop Das Laden wird mit voller Leistung freigegeben 6.4 nach Ablauf von WR_1:Solar_middayhigh_fc0_stop Die Midday Steuerung wird abgeschaltet, es wird normal weiter geladen, bis MaxSOC erreicht ist 6.5 WR_1_Speicher_1_ExternControl:SpeicherMaxSOC Batterie MaxSOC halten, der Default ist 100% 7 Initialisierung der externen Speichersteuerung 7.1 Ist morgens der Speicher zu voll Wenn der Speicher morgens voller als 3x MinSOC ist wird MaxSOC gesetzt 7.2 Wenn eine Überschreitung der 70% erwartet wird Aktivierung der Midday Steuerung 8 Zurücksetzen der externen Speichersteuerung 9 Umschaltung des MinSOC wenn zu wenig Leistung erwartet wird Schaltet im Herbst/Winter den MinSOC auf 20% 10 Umschaltung des MinSoc wenn viel Leistung erwartet wir Setzt den MinSOC wieder im Frühling/Sommer auf 5% 11 WR_1_Speicher_1 Status aktualisieren Nur beim BYD HV, Abfrage der Speicher Detailinformationen. Kann einfach entfernt werden WR_1_Speicher_1_ExternControl readings Konfiguration für die externe Speichersteuerung ExternTrigger none Wird automatisch gesetzt und dient der Verriegelung im WR_1_Speicher_1_ExternControl Zustände: frei/gesperrt/none SpeicherCmdRepeatActive [An|Aus] An/Aus Trigger für WR_1_Speicher_1_ExternControl, aktiviert die Kommandowiederholung SpeicherMaxSOCControlRunning [An|Aus] Das reading signalisiert den aktuellen Laufzeitstatus SpeicherEntladung Steuert den Modus der externen Speichersteuerung Zustände: Automatik - MinSOC Steuerung Sommer/Winter Zeit - z.B. bei Tarifsteuerung. Zeiten werden über zusätzliche DOIF oder WeekdayTimer gesetzt Trigger - Ein beliebiger Mechanismus z.B. DOIF steuert den Speicher SpeicherMaxSOCControlActive [An|Aus] Wird von Solar_forecast() gesetzt, wenn der fc0 über WR_1:Inverter_Max_Power (70% Regel) liegt SpeicherMaxSOCControlRunning [An|Aus] Das reading signalisiert den aktuellen Laufzeitstatus SpeicherMaxSOC_Actual 100 Wird im WR_1_Speicher_1_ExternControl cmd_7 berechnet, wenn der Speicher morgens zuviel Ladung hat SpeicherMaxSOC_DayBefore xx Das ist der letzte berechnete Wert, damit sich die Berechnung langsam einem Optimum nähern kann SpeicherMaxSOC_fc1_Limit 30000 Hier einen Wert setzen, bei dem der Speicher über Nacht bis morgens gereicht hat. Damit wird dann der Übergang vom Winter zum Frühjahr erkannt. SpeicherMiddayControlActive [An|Aus] Wird von Solar_forecast() gesetzt, wenn der fc0 über WR_1:Inverter_Max_Power (70% Regel) liegt SpeicherMiddayControlRunning [An|Aus] Das reading signalisiert den aktuellen Laufzeitstatus SpeicherMidday_Inverter_Max_Power 8500 Manuelles überschreiben für WR_1:Inverter_Max_Power, wenn man kontrollierter den Tag über laden möchte SpeicherMidday_MaxChargePowerAbs_midday 1000 Begrenzung der Ladeleistung am Mittag, damit nicht zu schnell geladen wird. Steht der Wert auf 0 wird dynamisch während der Laufzeit ein Wert berechnet. SpeicherMidday_MaxChargePowerAbs_morning 450 Begrenzung der Ladeleistung am Vormittag, damit Mittags genug Platz im Speicher ist SpeicherMidday_MaxSOC 30 Limitierung des Speichers um Mittags genug Platz zu haben SpeicherMinSOC_Sommer 5 Sommer MinSOC von Kostal vorgegeben SpeicherMinSOC_Winter 20 Winter MinSOC von Kostal vorgegeben SpeicherMinSOC_fc1_Limit 14000 Wenn im Herbst/Winter der Forecast zu schlecht wird muss dieser Wert auf die Anlage angepasst werden. Das signalisiert die Winter Zeit SpeicherTrigger none entladen/gesperrt/none wird über WR_1_Speicher_1_ExternControl gesetzt SpeicherZeitEnde 16:00 Die Zeiten geben das Entlade Fenster an und werden durch weitere DOIF oder WeekdayTimer gesetzt SpeicherZeitStart 07:00 Dies kann zur Tarifsteuerung verwendet werden, oder um ein Entladung zeitlich zu verschieben Das Zeitfenster kann durch den MinSOC Schutz im Winter veriegelt sein. Beispiele: 1 SpeicherEntladung Automatik Nur grundlegende Steuerungen erfolgen automatisch. - Sommer/Winter Umschaltung des MinSOC Schützt den Speicher vor einer Notladung im Winter - smart_laden Sorgt dafür, das der Speicher im Winter nicht ständig geladen und wieder entladen wird - laden_beendet Gibt den Speicher nach dem smart_laden wieder frei 2 SpeicherEntladung Zeit Zeitsteuerung für laden/entladen - WR_1_Speicher_1_ExternControl:SpeicherZeitEnde/SpeicherZeitStart Die Start/Ende Zeiten müssen gesetzt werden, dies muss über weitere DOIF oder WeekdayTimer erfolgen. - Sommer/Winter Umschaltung des MinSOC - smart_laden - laden_beendet
Allgemeine Hilfestellungen
Ein Device umbenennen
Ein reading umbenennen
DbLog aufräumen
An der Datenbank anmelden
SELECT DEVICE FROM history
GROUP BY DEVICE;
SET @device = 'WR_1';
FROM history t1
INNER JOIN
FROM history
WHERE DEVICE = @device AND
GROUP BY READING) x
x.DEVICE = t1.DEVICE AND
x.READING = t1.READING;
UPDATE history
SET
TIMESTAMP = TIMESTAMP,
DEVICE = 'PV_1'
WHERE
DEVICE = 'WR_1'
UPDATE history
SET
WHERE
DEVICE = 'WR_1'
Alles auf einmal
Grafiken korrigieren
SVG
Grafana
Fhem Log
([:57])\
DOELSEIF\
([05:00-21:00] and [:00])\
DOELSEIF\
([06:55] or [19:11])\
DOELSEIF\
([+:05] and ![:00])\
(get WR_2_API 04_auth_me)\
(get WR_1_API 04_auth_me)\
DOELSEIF\
([00:01])\
({if ($mday eq 1)\
if ($yday eq 0)\
attr PV_Schedule do always
attr PV_Schedule sortby 11
attr PV_Schedule verbose 0
Energie Bilanz
([01:13] and ($mday==1))\
## Wöchentliche Einträge\
DOELSEIF\
([01:17] and ($wday==1))\
DOELSEIF\
([02:17] and ($wday==1))\
Wetter-/Leistungs-Prognose
Wetter Forecast Grundlagen
1.) Astro Device mit dem Namen Astro und der Konfiguration für den Standort (in der fhem.cfg eingetragen) 2.) DbLog / DbRep 2.1) DbLog Device, um die Daten in die Datenbank zu schreiben 2.2) DbRep Device um auch wieder alte Forecasts zu löschen 3.) Es kann auch ohne DbLog / DbRep gearbeitet werden 4.) Die Solar_* Funktionen in der 99_myUtils 5.) Das DWD Device nit dem Namen DWD_Forecast 6.) Das Wetter Device für wunderground wird nicht für den Forecast benötigt
Deutscher Wetter Dienst (DWD)
RAW Definition DWD_Forecast
Erfordert ggf.
attr DWD_Forecast sortby 07
attr DWD_Forecast verbose 0
Astro Device
RAW Definition Astro
defmod Astro Astro
attr Astro DbLogExclude .*
attr Astro alias Astro
attr Astro icon telescope
attr Astro interval 600
attr Astro sortby 08
attr global altitude 110
attr global latitude 47.85750
attr global longitude 9.49420
99_myUtils.pm Funktionen
Solar_forecast()
sub Solar_forecast($$$$$$) {
# 2021.06.14 15:20
# Mit "attr global verbose 3" erscheinen Logmeldungen
$logdevice = $_[2] ;
if ( $logdbrep ne "none" ) {
my $middayhigh_tmp = 0;
my $middayhigh_start_tmp = 0;
my $middayhigh_stop_tmp = 0;
my $Inverter_Max_Power = ReadingsVal($logdevice."_Speicher_1_ExternControl","SpeicherMidday_Inverter_Max_Power","unused"); # Überschreiben des middayhigh
INSERT INTO history
SELECT
FROM (
SELECT
t2.DEVICE,
\@readingname AS READING,
FROM (
SELECT * FROM (
SELECT
t1.TIMESTAMP,
t1.HOUR,
t1.DEVICE,
t1.READING,
t1.VALUE,
if(\@diff = 0,0, \@temp:=cast((t1.VALUE-\@diff) AS DECIMAL(8,2))) AS DIFF,
\@diff:=t1.VALUE AS curr_V
FROM (
SELECT
h.TIMESTAMP,
date(h.TIMESTAMP) AS DATE,
hour(h.TIMESTAMP) AS HOUR,
h.DEVICE,
h.READING,
h.VALUE
FROM history AS h
WHERE h.DEVICE = \@device
AND (h.READING = \@reading1 OR h.READING = \@reading2)
AND h.TIMESTAMP <= CURDATE()
AND MINUTE(h.TIMESTAMP) = 0
AND h.VALUE >= 50
)t1
)tx
WHERE READING != \@reading2
AND HOUR > 6
)t2
GROUP BY t2.HOUR,t2.DEVICE
)t3
WHERE
t3.VALUE != 0
ORDER BY TIMESTAMP
ON DUPLICATE KEY UPDATE
VALUE=t3.VALUE;
") # Ende sprintf()
); # Ende CommandGet()
$Solar_Rain = 0;
if ($cloudk ne 0) {
if ($raink ne 0) {
if ($tempk ne 0) {
if ($autocorrection ne 0) {
for(my $j=1;$j<=5;$j++){
# lesen der Modul Anzahl
if ($module_count[$j] ne 0) {
# Runden auf volle Watt Werte
$logentry4h += $Solar_[$j] ;
if ( $logdb ne "none" ) {
$middayhigh = 1;
$middayhigh_start_tmp = $i-1;
$middayhigh_stop_tmp = $i;
if ( $middayhigh == 1 and $logentry1h > $Inverter_Max_Power and $middayhigh_stop ne "00:00" ) {
if ($middayhigh == 1 and
$middayhigh_stop_tmp != 0 and
if ($fc == 0) {
return (0);
Solar_plain()
sub Solar_plain($$$) {
# 2021.02.28 17:00
my $rad = 57.296;
my $factor = 0.001;
# read parameter
my $angle = $_[0];
my $orienta = $_[1];
my $time = $_[2];
# get Astro information
# convert in radiant
$angle = $angle / $rad;
if ($elevation <= 0.1798) {
return($factor);
$factor = sin($angle) /
cos($orientation) +
cos($angle);
# avoid too big values
$factor = 0.05
return ($factor);
DbLog/DbRep Device
attr LogDB DbLogExclude .*
attr LogDB DbLogType History
attr LogDB asyncMode 1
attr LogDB bulkInsert 1
attr LogDB disable 0
attr LogDB room System
attr LogDB showproctime 1
attr LogDB verbose 0
Solar Forcast Tests
Grundlagen hierfür sind:
Astro Device Test
Solar_plain() Test
In der fhem comandline:
Im Log kommt dann Folgendes
Solar_forecast() Test
Forecast Basiseinstellung
module_1_count 13
module_1_direction -90
module_1_name East
module_1_plain 40
module_1_power 310
Temperatur
Wolken und Regen
wunderground
Dieser Dienst wird nicht für die Prognose genutzt, jedoch kann man dort private Wetterstationen in seinem näheren Umfeld finden, die die Sonneneinstrahlung und den UV Index messen. Das ist dann als aktueller Wert in den Diagrammen zu sehen und lässt aktuelle Beschattung durch Wolken erkennen. Hier kann man dann auch mehrere Stationen definieren und eventuell mit einem Durchschnitt arbeiten, wenn nicht gerade der Nachbar eine Station hat. Für diese Abfrage ist keine Registrierung notwendig und man muss auch nicht selber mir einer Station Daten liefern. Aber bitte, die Abfrage nicht in einem zu kurzen Abstand, also mit hoher Frequenz stellen! Hier wird alle 15 Minuten (900 Sekunden) abgefragt.
Diagramme mit Grafana
Beispiel Diagramme
"annotations": {
"list": [
"builtIn": 1,
"enable": true,
"hide": true,
"type": "dashboard"
"editable": true,
"gnetId": null,
"graphTooltip": 0,
"id": 5,
"links": [],
"panels": [
"aliasColors": {
"Actual_Battery_charge_usable_P": "dark-yellow",
"Actual_Battery_charge_usable_P value": "dark-yellow",
"bars": false,
"dashLength": 10,
"dashes": false,
"datasource": null,
"decimals": null,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 12,
"w": 23,
"x": 0,
"y": 0
"hiddenSeries": false,
"id": 2,
"legend": {
"alignAsTable": true,
"avg": false,
"current": false,
"max": false,
"min": false,
"rightSide": true,
"show": true,
"sideWidth": 250,
"sort": "current",
"sortDesc": false,
"total": false,
"values": false
"lines": true,
"linewidth": 1,
"nullPointMode": "null",
"options": {
"alertThreshold": true
"percentage": false,
"pluginVersion": "7.5.5",
"pointradius": 2,
"points": false,
"renderer": "flot",
"seriesOverrides": [
"$$hashKey": "object:78",
"alias": "SW_Total_DC_P_Max",
"fill": 0,
"linewidth": 1
"$$hashKey": "object:79",
"alias": "Actual_Battery_charge_usable_P",
"fill": 0,
"linewidth": 2
"$$hashKey": "object:80",
"fill": 10,
"stack": true
"$$hashKey": "object:81",
"fill": 3,
"stack": true
"$$hashKey": "object:82",
"alias": "SW_Total_DC_P",
"fill": 0
"$$hashKey": "object:83",
"fill": 5,
"stack": true
"spaceLength": 10,
"stack": false,
"steppedLine": false,
"targets": [
"datasource": "FHEM MySQL",
"format": "table",
"group": [],
"hide": true,
"metricColumn": "none",
"rawQuery": true,
"refId": "SW_Total_DC_P",
"select": [
"params": [
"VALUE"
"type": "column"
"params": [
"SW_Total_DC_P'"
"type": "alias"
"table": "history",
"timeColumn": "TIMESTAMP",
"where": [
"name": "$__timeFilter",
"params": [],
"type": "macro"
"datatype": "varchar",
"name": "",
"params": [
"DEVICE",
"'WR_1'"
"type": "expression"
"name": "",
"params": [
"READING",
"'SW_Total_DC_P'"
"format": "table",
"group": [],
"rawQuery": true,
"select": [
"params": [
"value"
"type": "column"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'WR_1'"
"format": "table",
"group": [],
"rawQuery": true,
"select": [
"params": [
"value"
"type": "column"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'WR_1'"
"format": "table",
"group": [],
"rawQuery": true,
"select": [
"params": [
"value"
"type": "column"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'WR_1'"
"format": "table",
"group": [],
"rawQuery": true,
"rawSql": "SELECT\n $__timeGroupAlias(TIMESTAMP,$__interval,previous),\n avg(value) AS \"Actual_Battery_charge_usable_P\"\nFROM history\nWHERE\n $__timeFilter(TIMESTAMP) AND\n DEVICE = 'WR_1' AND\n READING = 'Actual_Battery_charge_usable_P'\nGROUP BY 1\nORDER BY $__timeGroup(TIMESTAMP,$__interval,previous)",
"refId": "Actual_Battery_charge_usable_P",
"select": [
"params": [
"value"
"type": "column"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'WR_1'"
"format": "table",
"group": [],
"rawQuery": true,
"refId": "SW_Total_DC_P_Max",
"select": [
"params": [
"value"
"type": "column"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'WR_1'"
"format": "table",
"group": [],
"rawQuery": true,
"refId": "A",
"select": [
"params": [
"value"
"type": "column"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'WR_1'"
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "Leistungsbezug",
"tooltip": {
"shared": true,
"sort": 0,
"value_type": "individual"
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"decimals": 0,
"format": "short",
"label": "Watt",
"logBase": 1,
"max": "14000",
"min": "0",
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"yaxis": {
"align": false,
"alignLevel": null
"aliasColors": {
"Heizung": "dark-red",
"Heizung value": "dark-red",
"Pool": "dark-yellow",
"Shaun": "dark-green",
"Shaun value": "dark-green",
"Waschmaschine": "light-red"
"bars": false,
"dashLength": 10,
"dashes": false,
"datasource": null,
"decimals": null,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 12,
"w": 23,
"x": 0,
"y": 12
"id": 3,
"legend": {
"avg": false,
"current": true,
"hideEmpty": false,
"hideZero": false,
"max": false,
"min": false,
"rightSide": true,
"show": true,
"sideWidth": 250,
"sort": "current",
"sortDesc": true,
"total": false,
"values": true
"lines": true,
"linewidth": 1,
"nullPointMode": "connected",
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"fill": 0
"alias": "Pool",
"fill": 3,
"stack": true
"alias": "Heizung",
"fill": 3,
"stack": true
"alias": "Waschmaschine",
"fill": 3,
"stack": true,
"steppedLine": true
"spaceLength": 10,
"stack": false,
"targets": [
"format": "table",
"group": [
"params": [
"$__interval",
"previous"
"type": "time"
"rawQuery": true,
"select": [
"params": [
"value"
"type": "column"
"params": [
"avg"
"type": "aggregate"
"params": [
"value"
"type": "alias"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'WR_1'"
"name": "",
"params": [
"READING",
"'SW_Total_DC_P_Max'"
"format": "table",
"group": [
"params": [
"$__interval",
"previous"
"type": "time"
"rawQuery": true,
"refId": "Heizung",
"select": [
"params": [
"value"
"type": "column"
"params": [
"avg"
"type": "aggregate"
"params": [
"value"
"type": "alias"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'StromZaehler_Heizung'"
"name": "",
"params": [
"READING",
"format": "table",
"group": [
"params": [
"$__interval",
"previous"
"type": "time"
"rawQuery": true,
"refId": "Pool",
"select": [
"params": [
"value"
"type": "column"
"params": [
"avg"
"type": "aggregate"
"params": [
"value"
"type": "alias"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'shelly02'"
"name": "",
"params": [
"READING",
"'Power_0'"
"format": "table",
"group": [
"params": [
"$__interval",
"previous"
"type": "time"
"rawQuery": true,
"refId": "Waschmaschine",
"select": [
"params": [
"value"
"type": "column"
"params": [
"avg"
"type": "aggregate"
"params": [
"value"
"type": "alias"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'shelly03'"
"name": "",
"params": [
"READING",
"'power'"
"format": "table",
"group": [
"params": [
"$__interval",
"previous"
"type": "time"
"rawQuery": true,
"refId": "Brunnen",
"select": [
"params": [
"value"
"type": "column"
"params": [
"avg"
"type": "aggregate"
"params": [
"value"
"type": "alias"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'shelly05'"
"name": "",
"params": [
"READING",
"'power_0'"
"format": "table",
"group": [
"params": [
"$__interval",
"previous"
"type": "time"
"rawQuery": true,
"refId": "Shaun",
"select": [
"params": [
"value"
"type": "column"
"params": [
"avg"
"type": "aggregate"
"params": [
"value"
"type": "alias"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'shelly05'"
"name": "",
"params": [
"READING",
"'power_1'"
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "Hauptverbraucher",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"decimals": 0,
"format": "short",
"label": "Watt",
"logBase": 1,
"max": "14000",
"min": "0",
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"yaxis": {
"align": false,
"alignLevel": null
"aliasColors": {
"Solar_South": "light-red",
"Solar_West": "light-purple",
"bars": false,
"dashLength": 10,
"dashes": false,
"datasource": null,
"decimals": null,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 0,
"fillGradient": 0,
"gridPos": {
"h": 13,
"w": 23,
"x": 0,
"y": 24
"id": 4,
"legend": {
"avg": false,
"current": true,
"max": false,
"min": false,
"rightSide": true,
"show": true,
"sideWidth": 250,
"sort": null,
"sortDesc": null,
"total": false,
"values": true
"lines": true,
"linewidth": 1,
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"linewidth": 2
"alias": "Power_DC_Sum",
"fill": 2
"spaceLength": 10,
"stack": false,
"targets": [
"format": "table",
"group": [],
"rawQuery": true,
"select": [
"params": [
"value"
"type": "column"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'WR_1'"
"name": "",
"params": [
"READING",
"'Solar_Calculation_fc0'"
"format": "table",
"group": [],
"rawQuery": true,
"select": [
"params": [
"value"
"type": "column"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'WR_1'"
"name": "",
"params": [
"READING",
"'Solar_Calculation_fc1'"
"format": "table",
"group": [
"params": [
"$__interval",
"previous"
"type": "time"
"rawQuery": true,
"refId": "Power_DC_Sum",
"select": [
"params": [
"value"
"type": "column"
"params": [
"avg"
"type": "aggregate"
"params": [
"value"
"type": "alias"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'WR_1'"
"name": "",
"params": [
"READING",
"'Power_DC_Sum'"
"format": "table",
"group": [
"params": [
"$__interval",
"previous"
"type": "time"
"rawQuery": true,
"refId": "Solar_Calculation",
"select": [
"params": [
"value"
"type": "column"
"params": [
"avg"
"type": "aggregate"
"params": [
"value"
"type": "alias"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'WR_1'"
"name": "",
"params": [
"READING",
"'Solar_Calculation'"
"format": "table",
"group": [
"params": [
"$__interval",
"previous"
"type": "time"
"rawQuery": true,
"refId": "WR_1_Ost",
"select": [
"params": [
"value"
"type": "column"
"params": [
"avg"
"type": "aggregate"
"params": [
"value"
"type": "alias"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'WR_1'"
"name": "",
"params": [
"READING",
"'WR_1_Ost'"
"format": "table",
"group": [
"params": [
"$__interval",
"previous"
"type": "time"
"rawQuery": true,
"refId": "WR_1_West",
"select": [
"params": [
"value"
"type": "column"
"params": [
"avg"
"type": "aggregate"
"params": [
"value"
"type": "alias"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'WR_1'"
"name": "",
"params": [
"READING",
"'WR_1_West'"
"format": "table",
"group": [
"params": [
"$__interval",
"previous"
"type": "time"
"rawQuery": true,
"refId": "WR_2_Sued",
"select": [
"params": [
"value"
"type": "column"
"params": [
"avg"
"type": "aggregate"
"params": [
"value"
"type": "alias"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'WR_1'"
"name": "",
"params": [
"READING",
"'WR_2_Sued'"
"format": "table",
"group": [
"params": [
"$__interval",
"previous"
"type": "time"
"rawQuery": true,
"refId": "WR_2_West",
"select": [
"params": [
"value"
"type": "column"
"params": [
"avg"
"type": "aggregate"
"params": [
"value"
"type": "alias"
"table": "history",
"where": [
"params": [],
"type": "macro"
"name": "",
"params": [
"DEVICE",
"'WR_1'"
"name": "",
"params": [
"READING",
"'WR_2_West'"
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "Forecast/Prognose",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"decimals": 0,
"format": "short",
"label": "Watt",
"logBase": 1,
"max": "16000",
"min": "0",
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"yaxis": {
"align": false,
"alignLevel": null
"refresh": "5m",
"schemaVersion": 27,
"style": "dark",
"tags": [],
"templating": {
"list": []
"time": {
"from": "now-1d/d",
"to": "now-1d/d"
"timepicker": {
"hidden": false,
"refresh_intervals": [
"5s",
"10s",
"30s",
"1m",
"5m",
"15m",
"30m",
"1h",
"2h",
"1d"
"timezone": "utc",
"title": "PV_Anlage_1",
"uid": "W-Y51Dmgk",
"version": 105
Diagramme mit SVG
SVG_LogDB_Photovoltaik_2
# Created by FHEM/98_SVG.pm, 2020-03-16 10:23:52 set terminal png transparent size <SIZE> crop set output '<OUT>.png' set xdata time set timefmt "%Y-%m-%d_%H:%M:%S" set xlabel " " set title 'Hauptverbraucher' set ytics set y2tics set grid set ylabel "Leistung" set y2label "" #LogDB WR_1:SW_Total_DC_P:::$val=abs($val) #LogDB WR_1:SW_Total_PV_P_reserve:: #LogDB StromZaehler_Heizung:SMAEM1901401955_Saldo_Wirkleistung:::$val=abs($val) #LogDB shelly02:Power_0:: #LogDB shelly03:Power:: plot "<IN>" using 1:2 axes x1y2 title 'SW_Total_DC' ls l1 lw 1 with lines,\ "<IN>" using 1:2 axes x1y2 title 'SW_Total_PV_reserve' ls l2 lw 1 with lines,\ "<IN>" using 1:2 axes x1y2 title 'Heizung' ls l0 lw 1 with lines,\ "<IN>" using 1:2 axes x1y2 title 'Pool' ls l8 lw 1 with lines,\ "<IN>" using 1:2 axes x1y2 title 'Waschmaschine' ls l3 lw 1 with lines
RAW Definition Leistungsbezug
SVG_LogDB_Photovoltaik_3
# Created by FHEM/98_SVG.pm, 2020-07-22 13:51:57 set terminal png transparent size <SIZE> crop set output '<OUT>.png' set xdata time set timefmt "%Y-%m-%d_%H:%M:%S" set xlabel " " set title 'Leistungsbezug' set ytics set y2tics set grid set ylabel "Leistung" set y2label "" set yrange [0:9500] set y2range [0:9500] #LogDB WR_1:SW_Total_DC_P:::$val=abs($val) #LogDB WR_1:SW_Home_own_consumption_from_PV:: #LogDB WR_1:SW_Home_own_consumption_from_Battery:: #LogDB WR_1:SW_Home_own_consumption_from_grid:: #LogDB WR_1:SW_Actual_battery_charge_usable_P:: #LogDB WR_1:SW_Total_DC_P_Max:: #LogDB WR_1:Battery_temperature:::$val=$val*100 #LogDB Heizung:heatSourceIN:::$val=$val*100 plot "<IN>" using 1:2 axes x1y2 title 'Total_DC_Power' ls l1fill lw 1 with lines,\ "<IN>" using 1:2 axes x1y2 title 'own_PV' ls l2fill lw 1 with lines,\ "<IN>" using 1:2 axes x1y2 title 'Bat_use' ls l0fill lw 1 with lines,\ "<IN>" using 1:2 axes x1y2 title 'Grid_use' ls l5 lw 1 with lines,\ "<IN>" using 1:2 axes x1y2 title 'Bat_usable' ls l4 lw 1 with lines,\ "<IN>" using 1:2 axes x1y2 title 'Total_DC_Max' ls l6 lw 2 with lines,\ "<IN>" using 1:2 axes x1y2 title 'Bat_Temp_Trend' ls l0 lw 2 with lines,\ "<IN>" using 1:2 axes x1y2 title 'Out_Temp_Trend' ls l2 lw 2 with lines
RAW Definition PV_Bilanz
SVG_LogDB_PV_Bilanz
# Created by FHEM/98_SVG.pm, 2020-08-02 09:55:06 set terminal png transparent size <SIZE> crop set output '<OUT>.png' set xdata time set timefmt "%Y-%m-%d_%H:%M:%S" set xlabel " " set title 'PV_Bilanz' set ytics set y2tics set grid ytics set ylabel "KWh" set y2label "KWh" #LogDB WR_1_API:max_month_SW_Statistic_EnergyHomePvSum_Month:::$val=$val/1000 #LogDB WR_1_API:diff_week_SW_Statistic_EnergyHomePvSum_Week:::$val=$val/1000 #LogDB WR_1_API:diff_week_SW_Statistic_Yield_Week:::$val=$val/1000 plot "<IN>" using 1:2 axes x1y2 title 'SW_Statistic_EnergyHomePvSum_Month' ls l2fill lw 2 with points,\ "<IN>" using 1:2 axes x1y2 title 'SW_Statistic_EnergyHomePvSum_Week' ls l2fill lw 1 with fsteps,\ "<IN>" using 1:2 axes x1y2 title 'SW_Statistic_Yield_Week' ls l1fill lw 1 with lines
SVG_LogDB_PV_Netz
# Created by FHEM/98_SVG.pm, 2020-10-21 13:43:37 set terminal png transparent size <SIZE> crop set output '<OUT>.png' set xdata time set timefmt "%Y-%m-%d_%H:%M:%S" set xlabel " " set title 'PV_Netz' set ytics set y2tics set grid ytics set ylabel "KWh" set y2label "KWh" #LogDB WR_1_API:SW_Statistic_EnergyFeedInGrid_Day:: #LogDB WR_1_API:SW_Statistic_EnergyHomeGrid_Day:::$val=$val*-1 plot "<IN>" using 1:2 axes x1y2 title 'Statistic_EnergyFeedInGrid_Day' ls l1fill lw 1 with lines,\ "<IN>" using 1:2 axes x1y2 title 'Statistic_EnergyHomeGrid_Day' ls l0fill lw 1 with lines
SVG_LogDB_Photovoltaik_4
# Created by FHEM/98_SVG.pm, 2020-08-17 08:58:42 set terminal png transparent size <SIZE> crop set output '<OUT>.png' set xdata time set timefmt "%Y-%m-%d_%H:%M:%S" set xlabel " " set title 'Forecast / Calculation' set ytics set y2tics set grid set ylabel "Leistung" set y2label "Leistung" set yrange [0:10000] set y2range [0:10000] #LogDB Astro:SunAlt:::$val=($val>0?$val*50+7000:7000) #LogDB wetter_<Wohnort>_II:solarRadiation:::$val=($val>0?$val*3+7000:7000) #LogDB PV_1:Solar_SolarRadiation:::$val=($val>0?$val*3+7000:7000) #LogDB Astro:SunAlt:::$val=7000 #LogDB WR_1:Solar_Calculation_fc1:: #LogDB WR_1:SW_Total_DC_P_sumOfAllPVInputs:: #LogDB WR_1:Solar_Calculation:: #LogDB WR_1:Solar_East:: #LogDB WR_1:Solar_South:: #LogDB WR_1:Solar_West:: plot "<IN>" using 1:2 axes x1y2 title 'Sonnenhöhe' ls l7 lw 1 with lines,\ "<IN>" using 1:2 axes x1y2 title 'SolarRadiation' ls l8 lw 2 with lines,\ "<IN>" using 1:2 axes x1y2 title 'SolarRadiationPrognose' ls l8 lw 1 with lines,\ "<IN>" using 1:2 axes x1y2 title '70%' ls l0 lw 1 with lines,\ "<IN>" using 1:2 axes x1y2 title 'Calculation_fc1' ls l0 lw 2 with lines,\ "<IN>" using 1:2 axes x1y2 title 'Total_DC_Power_(sumOfAllPVInputs)' ls l1fill lw 1 with lines,\ "<IN>" using 1:2 axes x1y2 title 'Calculation' ls l5 lw 1 with lines,\ "<IN>" using 1:2 axes x1y2 title 'East' ls l2 lw 0.5 with lines,\ "<IN>" using 1:2 axes x1y2 title 'South' ls l3 lw 0.5 with lines,\ "<IN>" using 1:2 axes x1y2 title 'West' ls l4 lw 0.5 with lines
PV Eigenverbrauch-Steuerung
Beispiel Luft Wärme Pumpe
defmod LWP dummy
attr LWP DbLogExclude .*
attr LWP DbLogInclude state
attr LWP sortby 10
attr LWP stateFormat state
attr LWP verbose 0
attr LWP webCmd LWP_Button
setstate LWP off
({if (AttrVal("$SELF","verbose",0) >=3)\
{Log 3, " LWP_PV cmd_1 PV : LWP off"}}\
{fhem("set LWP off")}\
DOELSEIF\
( ([WR_1:SW_Total_PV_P_reserve]+[StromZaehler_Heizung:SMAEM1901401955_Bezug_Wirkleistung]) > [LWP:PowerLimitOff] and\
[LWP:state] ne "off" and\
[LWP:LWP_Button] ne "on" )\
{Log 3, " LWP_PV cmd_2 PV : LWP off"}}\
## 3 Stop, wenn es nur ein kurzer peak ist. Dieser Do Zweig setzt den wait timer vom Einschaltkommando cmd_4 wieder außer kraft,\
DOELSEIF\
([WR_1:SW_Total_PV_P_reserve] < [LWP:PowerLimitOff] and\
[LWP:state] eq "off" )\
{Log 3, "LWP_PV cmd_3 PV : Stop wait timer LWP"}})\
DOELSEIF\
([WR_1:Solar_Calculation_fc0_day] < [WR_1_Speicher_1_ExternControl:SpeicherMinSOC_fc1_Limit] and ## Im Herbst/Winter ist wenig zu erwarten\
[WR_1:SW_Total_PV_P_reserve] >= [LWP:PowerLimitOn] and\
[LWP:state] eq "off" and\
{Log 3, "LWP_PV cmd_4 PV : LWP on"}}\
{fhem("set LWP on")}\
{fhem("setreading LWP_PV cmd_LWP_Priority used_today")}\
DOELSEIF\
([LWP:LWP_Button] eq "on" )\
{Log 3, "LWP_PV cmd_5 PV : LWP on for manuel PV-Modus"}}\
DOELSEIF\
[$SELF:cmd_nr] eq "5" )\
{Log 3, "LWP_PV cmd_6 PV : LWP off after manuel PV-Modus"}}\
DOELSEIF\
{Log 3, "LWP_PV cmd_7 PV : Stop wait timer LWP"}})\
## 8 LWP Ende\
DOELSEIF\
[LWP_Counter:pulseTimePerDay] >= [LWP:RunTimeMin] and\
([$SELF:cmd_nr] eq "4" or [$SELF:cmd_nr] eq "5" or [$SELF:cmd_nr] eq "3" or [$SELF:cmd_nr] eq "9" or [$SELF:cmd_nr] eq "10" or [$SELF:cmd_nr] eq "7") )\
{Log 3, "LWP_PV cmd_8 PV : LWP run finished"}}\
DOELSEIF\
([WR_1:Solar_Calculation_fc0_day] < [WR_1_Speicher_1_ExternControl:SpeicherMaxSOC_fc1_Limit] and ## Im Herbst/Winter ist wenig zu erwarten\
[[LWP:TimeEnd]] and\
[Heizung:hotWaterTemperature] <= 48 and\
{Log 3, "LWP_PV cmd_9 PV : LWP on for water heating"}}\
{fhem("set Heizung hotWaterTemperatureTarget ". (ReadingsVal("Heizung","hotWaterTemperature",48)+4))}\
{Log 3, "LWP_PV cmd_9 PV : LWP hotWaterTemperatureTarget ".ReadingsVal("Heizung","hotWaterTemperatureTarget",0)}}\
## 10 Hohe Priorität im Winter für die LWP\
DOELSEIF\
[WR_1:SW_Total_PV_P_reserve] >= 2000 and\
[shelly02:power_0] > 800 and\
[WR_1:Act_state_of_charge] > 60 and\
[$SELF:cmd_nr] ne "10" and\
[$SELF:cmd_LWP_Priority] eq "free" )\
{Log 3, "LWP_PV cmd_10 PV : LWP Priorität"}}\
{fhem("set LWP_PV cmd_4")}\
DOELSEIF\
([23:55])\
{fhem("setreading LWP_PV cmd_LWP_Priority free")}\
DOELSEIF\
([18:33]) ## Abschalten der Heizung, damit der Puffer für morgens Heizreserve hat\
{fhem("set Heizung opModeHeating Off")}\
DOELSEIF\
([02:03]) ## Einschalten der Heizung, damit aus dem Puffer nachgeheizt wird\
{fhem("set Heizung opModeHeating Auto")}\
attr LWP_PV DbLogExclude .*
attr LWP_PV alias LWP_PV
attr LWP_PV cmdState Maximalzeit pro Tag überschritten|Eigenverbrauch aus|Stop wait timer|Eigenverbrauch ein|LWP ein für manuellen PV-Modus|LWP aus nach manuellem PV-Modus|Stop wait timer für aus|LWP aus nach PV-Modus|LWP Brauchwasser nachheizen|LWP Priorität|PV-Modus frei|Heizung abgeschaltet|Heizung Eingeschaltet
attr LWP_PV comment Version 2020.10.19 18:28
attr LWP_PV do always
attr LWP_PV sortby 411
attr LWP_PV uiTable {\
sub FUNC_Status {\
return $ret;;\
"$SELF"|::ReadingsTimestamp("Heizung","counterHeatQTotal","")."<dd>Status / LWP Status / Brauchwasser</dd>" |""|[Heizung:opStateHeatPump1].[Heizung:opStateHeatPump2]|[Heizung:opStateHeatPump3]|[Heizung:hotWaterTemperature]." °C"\
|""|"EVU_StromZaehler"|""|"Gesamt"|sprintf("%06d kWh",[EVU_StromZaehler:Strom_Status-02])\
|""|"StromZaehler_Heizung"|""|"LWP/KWL"|sprintf("%06d kWh",[StromZaehler_Heizung:SMAEM1901401955_Bezug_Wirkleistung_Zaehler])\
|""|"Heizung"|""|"Heizung"|sprintf("%06d kWh",[Heizung:counterHeatQHeating])\
|""|"Heizung"|""|"Warmwasser"|sprintf("%06d kWh",[Heizung:counterHeatQHotWater])\
|""|"Heizung"|""|"Photovoltaik"|sprintf("%06d kWh",[Heizung:counterHeatQPool])\
|""|"Heizung"|""|"Gesamt"|sprintf("%06d kWh",[Heizung:counterHeatQTotal])\
attr LWP_PV verbose 3
attr shelly01 DbLogExclude .*
attr shelly01 alias LWP
attr shelly01 mode relay
attr shelly01 model shelly1pm
attr shelly01 sortby 412
<TABLE>\
<TR>\
WebLink: %s\
</TD>\
Heizung Gesamt 0: %08.2f KWh<br>\
</TD>\
Relais 0: %s %06.1f Watt<br>\
</TD>\
</TR>\
</TABLE>\
ReadingsVal("StromZaehler_Heizung","SMAEM1901401955_Bezug_Wirkleistung_Zaehler",0),\
ReadingsVal("StromZaehler_Heizung","SMAEM1901401955_Bezug_Wirkleistung",0)\
attr shelly01 webCmd |
attr LWP_Counter interval 5
attr LWP_Counter sortby 413
attr LWP_Counter verbose 0
TimeEnd => 'TimeEnd:time'}
attr rg_LWP_Status sortby 01
Beispiel Pool
defmod Pool dummy
attr Pool DbLogExclude .*
attr Pool DbLogInclude state
attr Pool alias Pool_Softube
attr Pool icon scene_swimming
attr Pool sortby 11
attr Pool stateFormat state
attr Pool verbose 0
attr Pool webCmd Pool_Button
setstate Pool off
{fhem("set Pool off")} )\
DOELSEIF\
[Pool:state] eq "on" and \
{fhem("set Pool off")}\
DOELSEIF\
[$SELF:wait_timer] ne "" and\
[Pool:state] eq "off" )\
DOELSEIF\
[Pool:state] eq "off" and\
) or\
{fhem("set Pool on")} )\
DOELSEIF\
DOELSEIF\
DOELSEIF\
([shelly02:power_0] > 10 and\
[Pool:state] eq "on" )\
## 8 Pool Ende\
DOELSEIF\
([shelly02:power_0] < 10 and\
DOELSEIF\
([[Pool:TimeEnd]] and\
DOELSEIF\
[22:00-05:00]\
DOELSEIF\
[$SELF:cmd_nr] eq "10"\
DOELSEIF\
else \
attr Pool_PV DbLogExclude .*
attr Pool_PV alias Pool_PV
attr Pool_PV disable 0
attr Pool_PV do always
attr Pool_PV sortby 11
attr Pool_PV verbose 0
attr shelly02 DbLogExclude .*
attr shelly02 mode relay
attr shelly02 model shelly2.5
attr shelly02 sortby 12
<TABLE>\
<TR>\
Status: %s<br>\
WebLink: %s\
</TD>\
</TD>\
Relais 1: %s %06.1f Watt<br>\
</TD>\
</TR>\
</TABLE>\
attr shelly02 verbose 0
attr shelly02 webCmd |
attr Pool_Counter interval 5
attr Pool_Counter sortby 13
attr Pool_Counter verbose 0
attr rg_Pool_Status sortby 02
defmod Waschmaschine dummy
attr Waschmaschine sortby 12
attr Waschmaschine verbose 0
setstate Waschmaschine off
DOELSEIF\
DOELSEIF\
DOELSEIF\
DOELSEIF\
DOELSEIF\
DOELSEIF\
([shelly03:power] > 0 and\
[$SELF:cmd_nr] ne "7")\
DOELSEIF\
([shelly03:power] == 0 and\
[$SELF:cmd_nr] eq "7" )\
DOELSEIF\
attr shelly03 DbLogExclude .*
attr shelly03 interval 60
attr shelly03 mode relay
attr shelly03 model shelly1pm
attr shelly03 sortby 22
<TABLE>\
<TR>\
WebLink: %s\
</TD>\
</TD>\
</TD>\
</TR>\
</TABLE>\
ReadingsVal($name,"power",0)\
attr shelly03 webCmd |
defmod Brunnen dummy
attr Brunnen DbLogExclude .*
attr Brunnen alias Brunnen
attr Brunnen icon well
attr Brunnen sortby 13
attr Brunnen verbose 0
setstate Brunnen off
{fhem("set Brunnen off")}\
DOELSEIF\
[Brunnen:state] eq "on" and\
DOELSEIF\
[Brunnen:state] eq "off" )\
DOELSEIF\
[Brunnen:state] eq "off" and\
## {fhem("set Brunnen on")}\
DOELSEIF\
DOELSEIF\
DOELSEIF\
DOELSEIF\
([shelly05:power_0] == 0 )\
DOELSEIF\
attr Brunnen_PV do always
attr Brunnen_PV icon well
attr Brunnen_PV sortby 31
attr Brunnen_PV verbose 0
attr shelly05 DbLogExclude .*
attr shelly05 interval 60
attr shelly05 mode relay
attr shelly05 model shelly2.5
attr shelly05 sortby 32
<TABLE>\
<TR>\
Status: %s<br>\
WebLink: %s\
</TD>\
Shaun Gesamt 1: %08.2f KWh\
</TD>\
</TD>\
</TR>\
</TABLE>\
attr shelly05 webCmd |
Beispiel Akku laden
defmod Shaun dummy
attr Shaun DbLogExclude .*
attr Shaun DbLogInclude state
attr Shaun alias Shaun
attr Shaun sortby 14
attr Shaun stateFormat state
attr Shaun verbose 0
setstate Shaun off
{fhem("set Shaun off")}\
DOELSEIF\
[Shaun:state] eq "on" and\
DOELSEIF\
[Shaun:state] eq "off" )\
DOELSEIF\
[Shaun:state] eq "off" and\
{fhem("set Shaun on")}\
DOELSEIF\
DOELSEIF\
DOELSEIF\
([shelly05:power_1] > 15 and\
DOELSEIF\
([shelly05:power_1] <= 6 and\
DOELSEIF\
[$SELF:cmd_nr] ne "5" )\
attr Shaun_PV DbLogExclude .*
attr Shaun_PV alias Shaun_PV
attr Shaun_PV do always
attr Shaun_PV sortby 41
attr Shaun_PV verbose 0
<TABLE>\
<TR>\
Status: %s<br>\
WebLink: %s\
</TD>\
</TD>\
</TD>\
</TR>\
</TABLE>\
attr Shaun_Counter interval 5
attr Shaun_Counter sortby 43
attr Shaun_Counter verbose 0
Problemlösung
Projekte der FHEM-Community
