Raspi docker-compose.yml
Version vom 15. April 2023, 13:44 Uhr von Krueuw (Diskussion | Beiträge) (Raspi docker-compose.yml)
version: '3' services:    fhem:        image: fhem/fhem:latest        #restart: always        restart: unless-stopped        ports:            - "8083:8083"            - "7072:7072"        volumes:            - ./fhem/core/:/opt/fhem/        networks:            default:                ipv4_address: 192.168.31.1        devices:            - "/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AL01XC9Y-if00-port0:/dev/onewire3"            - "/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_DAE003E5-if00-port0:/dev/onewire2"            - "/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_DAE003E6-if00-port0:/dev/onewire1"            - "/dev/ttyAMA0:/dev/ttyAMA0"        environment:            FHEM_UID: 1000            FHEM_GID: 1000            TIMEOUT: 10            RESTART: 1            TELNETPORT: 7072            TZ: Europe/Berlin        depends_on:            - "mysql"            - "mqtt"    habridge:        restart: always        image: habridge/ha-bridge-raspberrypi3        volumes:            - ./habridge/data/:/ha-bridge/data            - /etc/localtime:/etc/localtime:ro            - /etc/timezone:/etc/timezone:ro        networks:            default:                ipv4_address: 192.168.31.2
  1.    homebridge:
  2.        restart: always
  3.        image: oznu/homebridge:raspberry-pi
  4.        volumes:
  5.            - ./homebridge:/homebridge
  6.        environment:
  7.            - TZ=Europe/Berlin
  8.            - PGID=1000
  9.            - PUID=1000
  10.            - HOMEBRIDGE_CONFIG_UI=1
  11.            - HOMEBRIDGE_CONFIG_UI_PORT=8081
  12.        #network_mode: host
  13.        networks:
  14.            default:
  15.                ipv4_address: 192.168.31.3
  16.        depends_on:
  17.            - "fhem"
   mysql:        restart: always        expose:            - "3306"            - "33060"        ports:            - "3306:3306"            - "33060:33060"        image: hypriot/rpi-mysql        volumes:            - ./mysql/init.sql:/docker-entrypoint-initdb.d/fhem-init.sql            - ./mysql/data:/var/lib/mysql        environment:            - MYSQL_ROOT_PASSWORD=xxx            - MYSQL_DATABASE=fhem            - MYSQL_USER=fhemuser            - MYSQL_PASSWORD=xxx        networks:            default:                ipv4_address: 192.168.31.4    mqtt:        restart: always        expose:            - "1883"            - "9001"        ports:            - "1883:1883"            - "9001:9001"        image: pascaldevink/rpi-mosquitto        networks:             default:                 ipv4_address: 192.168.31.5        volumes:            - ./mqtt/config/:/mqtt/config/            - ./mqtt/log/:/mqtt/log/            - ./mqtt/data/:/mqtt/data/    nodered:        restart: always        expose:            - "1880"        ports:            - "1880:1880"        image: elzekool/rpi-nodered        volumes:            - ./nodered/data/:/root/.node-red/        networks:             default:                 ipv4_address: 192.168.31.6        depends_on:            - "mqtt" networks:    default:        external:            name: mymacvlannetwork
