Qnap: clean install
Version vom 11. Mai 2013, 17:01 Uhr von Markusbloch (Diskussion | Beiträge) (→Firmware upgrade)
Cleanup Qnap
This is an simple sequence for starting all over with an qnap TS-219 after having played with an TS-219 for some time. In this time we have problably damaged many parts and settings and it is better to have an nice blank system again
  • Reset to factory settings
  • Create Basic configuration.
  • Clean up the HD
  • Install mail
  • Install perl
Note
  • There is also a [http://forum.qnap.com/viewtopic.php?f=182&t=61052 step-by-step-description] for a TS109
Firmware upgrade
Download the latest firmware from the qnap distribution
http://www.qnap.com/download.asp
1: Select: storage (qnap1)
2: Select: modelname
3: Select the tab >> Firmware
4: Save to file on your local PC
5: Unzip the compressed fileto an winzip file
Reset to default factory constants
log into the qnap
select reset to default factory settings
select Firmware update (QNAP3)
select browse-key to select your downloaded firmware version
select start
Update your Basic server setting
Change name to FaserTaiwan
change admin passw: xxxxxxxx
create xxxx passw: xxxxxxxx
enable web Server
enable NSF
enable Mail
SMTP Server: smtp.gmail.com
Port Number: 587 sender: ACE External services user Name: your.services@gmail.com passw: xxxxxxxxx
Install Optware
Select Get QPKG (QNAP4) version 0.99.163
save the file to your local pc
unzip the file (qnap5)
select tab Installation
select browse
press install
The pinguin should be visable (qnap6)
Click on the IPKG image and select Enable (qnap8)
Restart the qnap
Enable perl scripting
to enable p-l files we have to change the apache configuration
/mnt/HDA_ROOT/.config/apache/apache.conf This will force the .pl files to be executed as an cgi
If you run an .pl file, and you get the save dialog... look here
get Filezilla to log into your qnap
add this to the apache configuration
<Directory "/share/Qweb/cgi-bin">
	AllowOverride None
	Options ExecCGI
	AddHandler cgi-script .cgi .pl
	Order allow,deny
	Allow from all
</Directory>
restart apache
[~] # /etc/init.d/Qthttpd.sh restart
Check ipkg
look for your ipkg version
[~] # ipkg --version
the system will reply with the present ipkg version
ipkg version 0.99.163
Check for ipkg Updates
update ipkg
[~] # ipkg update
The system will respond with something like
Downloading http://ipkg.nslu2-linux.org/feeds/optware/tsx19/cross/unstable/Packages
Updated list of available packages in /opt/lib/ipkg/lists/tsx19
Downloading http://ipkg.nslu2-linux.org/feeds/optware/cs08q1armel/cross/unstable/Packages.gz
Inflating http://ipkg.nslu2-linux.org/feeds/optware/cs08q1armel/cross/unstable/Packages.gz
Updated list of available packages in /opt/lib/ipkg/lists/cs08q1armel
Successfully terminated.
Perl 5.10.0 install
make and check .cpan directory in /opt/
[~] # find / -name '.cpan' The system will respond like
/share/MD0_DATA/.qpkg/Optware/.cpan
link the directory
[~] # ln -s /opt/.cpan /root/.cpan
List the available modules
[~] # ipkg list |grep perl
Check the installed ipgk modules
[~] # ipkg list_installed
install perl
[~] # ipkg install perl automake autoconf libtool m4 binutils coreutils gcc
the install ends like
Configuring m4
Configuring make
Configuring perl
Perl 5.10.0 modules install
The following Perl modules have to be loaded
[~] # ipkg install libgd
The Graphical module
[~] # ipkg install perl-gd
[~] # ipkg install perl-yaml-syck The Serial communication module
[~] # ipkg install perl-device-serialport
add CPAN modules
[~] # perl -MCPAN -e '$ENV{FTP_PASSIVE} = 1; install GD::Text'
[~] # perl -MCPAN -e '$ENV{FTP_PASSIVE} = 1; install GD::Graph'
GNU plot install
Install one of my favorite plot functions for 3d
[~] # ipkg install gnuplot
Test perl file
Map your server to your pc as an new drive
create an cgi-bin in Qweb
copy gd_test1.pl to here
try http://asmlonline.com/cgi-bin/samples/gd_test1.pl
#!/opt/bin/perl -w
# Change above line to point to your perl binary if youb insist to have it elsware
# name: test1.pl
use CGI::Carp qw/fatalsToBrowser/;
use CGI ':standard';
use GD::Graph::bars;
use strict;
# Both the arrays should same number of entries.
my @data = (["Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug","Sep", "Oct", "Nov", "Dec"],
      [23, 5, 2, 20, 11, 33, 7, 31, 77, 18, 65, 52]);
my $mygraph = GD::Graph::bars->new(500, 300);
$mygraph->set(
   x_label   => 'Month',
   y_label   => 'Number of Hits',
   title    => 'Number of Hits in Each Month in 2002',
 or warn $mygraph->error;
my $myimage = $mygraph->plot(\@data) or die $mygraph->error;
print "Content-type: image/png\n\n";
print $myimage->png;
Dont forget to make the test file as executable
chmod 755 test1.pl
Test email function
test additional if we can email an local file
locate the file eg in Qweb/cgi-bin/samples
Create an file testmail.txt
# cat /share/MD0_DATA/Qweb/cgi-bin/samples/testmail.txt | sendmail -t
the data for the mail has to be copied in an file
Subject: Anytext you want to have as mailsubject
To: your-email@live.nl
1 !!! ONE EMPTY LINE AT THE BOTTOM - else the body will not be transmitted
2 Any text you want to transmit in the body of the mail.
3
4 !!! ONE EMPTY LINE AT THE BOTTOM - else the body will not be transmitted
5 Any text you want to transmit in the body of the mail.
6
7 !!! ONE EMPTY LINE AT THE BOTTOM - else the body will not be transmitted
8 Any text you want to transmit in the body of the mail.
9
1
2
3 !!! ONE EMPTY LINE AT THE BOTTOM - else the body will not be transmitted
4 any text you want to transmit in the body of the mail.
5 !!! ONE EMPTY LINE AT THE BOTTOM - else the body will not be transmitted
6 Any text you want to transmit in the body of the mail.
7 !!! Footer.... need to be here and will not be send !!!!!
8
Install of the 2302 Prolific Technology driver on a QNAP 219
Start Putty
input here the putty stuff
Check kernel
[~] # Type: uname -a
Check the actual kernel version of the Qnap in our example the following line is displayed
[~] Responce:Linux Faservtaiwan 2.6.22.18 #1 Thu Apr 30 21:30:06 CST 2009 armv5tejl unknown
The Qnap name is:Faservtaiwan
The actual Kernel version is : 2.6.22.18
Double check the USB interfaces on the QNAP
[~] # Type: lsusb
Check if you see the hardware if it is connected at the front
The system will reply with EG:
[~] Responce:Bus 001 Device 003: ID 067b: 2303 Prolific Technology, Inc.. Pl2303 Serial Port
[~] Responce:Device 002: ID 058f: 6254 Alcor Micro Corp.
[~] Responce:Device 001: ID 0000:0000
One of the issues of the 2303 driver, is that LINUX unfortunally does not like to recognize
the device at once, and needs some extra help.
If you dont see the top line with 2303 Prolific , please remove the USB connector from the QNAP
and replug it after 5 seconds. This will do the job
to do
Install Optware in Server web page Tab by selecting QPKG-Plugins >> Optware.ipkg
[~] # Type: dmesg | grep tty [~] # Type: dmesg | grep usb
Check the actual driver status
[~] # Type: cat /proc/bus/usb/devices
The responce of the sysem will be something like this
	T: Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 7 Spd=12 MxCh= 0
	D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
	P: Vendor=067b ProdID=2303 Rev= 3.00
	S: Manufacturer=Prolific Technology Inc.
	S: Product=USB-Serial Controller
	C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=100mA
	I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=none
	E: Ad=81(I) Atr=03(Int.) MxPS= 10 Ivl=1ms
	E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
	E: Ad=83(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
The Driver=none indicates that there is no driver attached
#!/bin/sh
ln -s /opt/lib/modules/2.6.12.6-arm1/kernel /lib/modules
insmod /lib/modules/kernel/drivers/usb/serial/usbserial.ko vendor=0x03eb product=0x204b
insmod /lib/modules/kernel/drivers/usb/serial/ftdi_sio.ko
insmod /lib/modules/kernel/drivers/usb/serial/pl2303.ko
[~] # Type: ipkg update
[~] # Type: ipkg list | grep usb
[~] # Type: ipkg install kernel-module-usbserial
[~] # Type: cd /opt/lib/modules/2.6.22.18/kernel/drivers/usb/serial
[~] # Type: ll
[~] # type: insmod usbserial.ko
[~] # Type: ipkg list | grep pl23
[~] # Type: ipkg install kernel-module-pl2303
[~] # Type: ll
[~] # type: insmod pl2303.ko
Check the actual driver is attached
	I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=pl2303
	E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms.,
The Driver=pl2303 indicates that there is an driver attached
[~] # Type: lsmod
[~] # Type: dmesg | grep pl2303
Check the driver
[~] # Type: ls -al /dev/usb/ttyUSB*
Reboot und Test
Much Fun
Jan 05.02.2010
www.asmlonline.com >> asmlonline@hotmail.com
