Schmitt-Trigger - Temperaturabhängiges Schalten
Import
Die folgende Definition kann als Testraum in die eigene FHEM-Installation ohne Seiteneffekte importiert werden, indem man auf das Pluszeichen oben links im Webinterface klickt. Falls dieses unsichtbar sein sollte, kann es z.B über den Style f18 sichtbar gemacht werden.
Import nach FHEM Schritt 1
Import nach FHEM Schritt 2
defmod Pulse MSwitch tempdummy # MSwitch_Self pulsedevice
attr Pulse MSwitch_Comments 1
attr Pulse MSwitch_Debug 1
attr Pulse MSwitch_Delete_Delays 1
attr Pulse MSwitch_Event_Id_Distributor temperature:.*=>cmd1 ID 2
attr Pulse MSwitch_Eventhistory 0
attr Pulse MSwitch_Expert 1
attr Pulse MSwitch_Extensions 1
attr Pulse MSwitch_Help 1
attr Pulse MSwitch_Ignore_Types "TYPE=.*"
attr Pulse MSwitch_Include_Devicecmds 1
attr Pulse MSwitch_Include_MSwitchcmds 0
attr Pulse MSwitch_Include_Webcmds 0
attr Pulse MSwitch_Inforoom MSwitch
attr Pulse MSwitch_Lock_Quickedit 1
attr Pulse MSwitch_Mode Full
attr Pulse MSwitch_Safemode 1
attr Pulse readingList onpulse offpulse schwelle_on schwelle_off
attr Pulse room 07_Pulse
attr Pulse setList onpulse:00:00:01,00:00:02,00:00:03,00:00:04,00:00:05 offpulse:00:00:01,00:00:02,00:00:03,00:00:04,00:00:05 schwelle_off:slider,1,1,50 schwelle_on:slider,1,1,50
attr Pulse webCmd on:off:onpulse:offpulse:schwelle_off:schwelle_on
attr Pulse webCmdLabel ::ontime:offtime:off bei:on bei
defmod pulsedevice MSwitch # no_device
attr pulsedevice MSwitch_Debug 0
attr pulsedevice MSwitch_Eventhistory 0
attr pulsedevice MSwitch_Help 0
attr pulsedevice MSwitch_Ignore_Types notify allowed at watchdog doif fhem2fhem telnet FileLog readingsGroup FHEMWEB autocreate eventtypes readingsproxy svg cul
attr pulsedevice MSwitch_Inforoom MSwitch
attr pulsedevice MSwitch_Mode Dummy
attr pulsedevice room 07_Pulse
attr pulsedevice setList on off
defmod tempdummy MSwitch # nodevices
attr tempdummy MSwitch_Debug 0
attr tempdummy MSwitch_Eventhistory 0
attr tempdummy MSwitch_Help 0
attr tempdummy MSwitch_Ignore_Types notify allowed at watchdog doif fhem2fhem telnet FileLog readingsGroup FHEMWEB autocreate eventtypes readingsproxy svg cul
attr tempdummy MSwitch_Inforoom MSwitch
attr tempdummy MSwitch_Mode Dummy
attr tempdummy readingList temperature
attr tempdummy room 07_Pulse
attr tempdummy setList temperature:slider,1,1,40
attr tempdummy webCmd temperature
setstate Pulse off
setstate Pulse 2019-11-09 13:27:51 .Device_Affected MSwitch_Self-AbsCmd1,MSwitch_Self-AbsCmd2,MSwitch_Self-AbsCmd3,MSwitch_Self-AbsCmd4,MSwitch_Self-AbsCmd5,pulsedevice-AbsCmd1,pulsedevice-AbsCmd2
setstate Pulse 2019-11-09 13:47:55 .Device_Affected_Details MSwitch_Self-AbsCmd1#[NF]exec_cmd_1#[NF]no_action#[NF]ID#[sp]1#[NF]#[NF]delay1#[NF]delay1#[NF][$SELF#[dp]onpulse]#[NF]00#[dp]00#[dp]00#[NF]#[NF]#[NF]0#[NF]0#[NF]5#[NF]0#[NF]führt#[sp]den#[sp]befehl#[sp]mit#[sp]der#[sp]ID#[sp]1#[sp]verzögert#[sp]aus#[ko]#[sp]verzögerungszeit#[sp]aus#[sp]reading#[sp]onppulse#[sp]#[NF]0#[NF]0#[NF]3#[ND]MSwitch_Self-AbsCmd2#[NF]exec_cmd_1#[NF]no_action#[NF]#[NF]#[NF]delay1#[NF]delay1#[NF][$SELF#[dp]offpulse]#[NF]00#[dp]00#[dp]00#[NF]#[NF]#[NF]0#[NF]0#[NF]6#[NF]1#[NF]wird#[sp]um#[sp]onpulse#[sp]verzögert#[sp]ausgeführt.#[sp]und#[sp]startet#[sp]cmd1#[sp]erneut#[ko]#[sp]um#[sp]offpulse#[sp]verzögert.#[sp]Hieraus#[sp]ergiebt#[sp]sich#[sp]ein#[sp]neustart#[sp]von#[sp]cmd1#[sp]nach#[sp]onpulse+offpulse#[NF]0#[NF]0#[NF]4#[ND]MSwitch_Self-AbsCmd3#[NF]on#[NF]no_action#[NF]#[NF]#[NF]delay1#[NF]delay1#[NF]00#[dp]00#[dp]00#[NF]00#[dp]00#[dp]00#[NF][EVTPART3]#[sp]>=#[sp][$SELF#[dp]schwelle_on]#[sp]AND#[sp][$SELF#[dp]state]#[sp]eq#[sp]"off"#[NF][EVTPART3]#[sp]<#[sp]10#[sp]AND#[sp][$SELF#[dp]state]#[sp]eq#[sp]"on"#[NF]0#[NF]0#[NF]1#[NF]2#[NF]#[NF]1#[NF]0#[NF]1#[ND]MSwitch_Self-AbsCmd4#[NF]no_action#[NF]del_delays#[NF]#[NF]#[NF]delay1#[NF]delay1#[NF]00#[dp]00#[dp]00#[NF]00#[dp]00#[dp]00#[NF]#[NF][EVTPART3]#[sp]<#[sp]10#[sp]AND#[sp][$SELF#[dp]state]#[sp]eq#[sp]"on"#[NF]0#[NF]0#[NF]2#[NF]0#[NF]#[NF]0#[NF]0#[NF]1#[ND]MSwitch_Self-AbsCmd5#[NF]off#[NF]no_action#[NF]#[NF]#[NF]delay1#[NF]delay1#[NF]00#[dp]00#[dp]00#[NF]00#[dp]00#[dp]00#[NF][EVTPART3]#[sp]<#[sp][$SELF#[dp]schwelle_off]#[sp]AND#[sp][$SELF#[dp]state]#[sp]eq#[sp]"on"#[NF]#[NF]0#[NF]0#[NF]1#[NF]2#[NF]#[NF]1#[NF]0#[NF]1#[ND]pulsedevice-AbsCmd1#[NF]on#[NF]off#[NF]#[NF]#[NF]delay1#[NF]delay1#[NF]00#[dp]00#[dp]00#[NF]00#[dp]00#[dp]00#[NF]#[NF]#[NF]0#[NF]0#[NF]3#[NF]0#[NF]schaltet#[sp]device#[sp]an#[sp]#[NF]0#[NF]0#[NF]1#[ND]pulsedevice-AbsCmd2#[NF]off#[NF]off#[NF]#[NF]#[NF]delay2#[NF]delay1#[NF][$SELF#[dp]onpulse]#[NF]00#[dp]00#[dp]00#[NF]#[NF]#[NF]0#[NF]0#[NF]4#[NF]0#[NF]schaltet#[sp]device#[sp]verzögert#[sp]aus#[ko]#[sp]verzögerungszeit#[sp]aus#[sp]reading#[sp]onppulse#[NF]0#[NF]0#[NF]2 setstate Pulse 2019-11-09 13:48:33 .Device_Events temperature:18#[tr]temperature:24#[tr]temperature:23#[tr]temperature:11#[tr]temperature:2#[tr]temperature:14#[tr]temperature:21#[tr]no_trigger#[tr]temperature:16#[tr]temperature:27#[tr]temperature:30#[tr]temperature:32#[tr]temperature:19#[tr]temperature:7#[tr]temperature:17#[tr]temperature:25#[tr]temperature:12#[tr]temperature:3#[tr]temperature:29#[tr]temperature:28#[tr]temperature:31#[tr]temperature:1#[tr]temperature:9#[tr]temperature:5#[tr]temperature:6#[tr]temperature:4#[tr]temperature:8#[tr]temperature:34#[tr]temperature:.*#[tr]temperature:15
setstate Pulse 2019-11-03 12:31:25 .First_init done
setstate Pulse 2019-11-09 12:42:33 .Trigger_cmd_off temperature:.*
setstate Pulse 2019-11-09 12:42:33 .Trigger_cmd_on temperature:.*
setstate Pulse 2019-11-09 13:04:08 .Trigger_condition
setstate Pulse 2019-11-09 12:42:33 .Trigger_off no_trigger
setstate Pulse 2019-11-09 12:42:33 .Trigger_on no_trigger
setstate Pulse 2019-11-09 13:04:08 .Trigger_time
setstate Pulse 2019-11-03 12:31:25 .V_Check V2.00
setstate Pulse 2019-11-09 12:45:42 .sortby priority
setstate Pulse 2019-11-09 13:48:33 EVENT temperature:14
setstate Pulse 2019-11-09 13:48:33 EVTFULL tempdummy:temperature:14
setstate Pulse 2019-11-09 13:48:33 EVTPART1 tempdummy
setstate Pulse 2019-11-09 13:48:33 EVTPART2 temperature
setstate Pulse 2019-11-09 13:48:33 EVTPART3 14
setstate Pulse 2019-11-09 13:04:08 Trigger_device tempdummy
setstate Pulse 2019-11-09 12:42:33 Trigger_log on
setstate Pulse 2019-11-09 13:48:33 last_activation_by manual
setstate Pulse 2019-11-09 13:48:33 last_cmd 1
setstate Pulse 2019-11-09 13:48:33 last_event temperature:14
setstate Pulse 2019-11-09 13:48:33 last_exec_cmd set pulsedevice off
setstate Pulse 2019-11-09 13:42:02 offpulse 00:00:01
setstate Pulse 2019-11-09 13:42:20 onpulse 00:00:01
setstate Pulse 2019-11-09 13:48:06 schwelle_off 15
setstate Pulse 2019-11-09 13:47:01 schwelle_on 17
setstate Pulse 2019-11-09 13:48:33 state off
setstate pulsedevice off
setstate pulsedevice 2019-11-03 12:32:30 .Device_Affected no_device
setstate pulsedevice 2019-11-03 12:32:30 .Device_Events no_trigger
setstate pulsedevice 2019-11-03 12:32:30 .First_init done
setstate pulsedevice 2019-11-03 12:32:30 .Trigger_cmd_off no_trigger
setstate pulsedevice 2019-11-03 12:32:30 .Trigger_cmd_on no_trigger
setstate pulsedevice 2019-11-03 12:32:30 .Trigger_off no_trigger
setstate pulsedevice 2019-11-03 12:32:30 .Trigger_on no_trigger
setstate pulsedevice 2019-11-03 12:32:30 .V_Check V2.00
setstate pulsedevice 2019-11-03 12:32:30 Trigger_log off
setstate pulsedevice 2019-11-09 13:48:33 state off
setstate tempdummy active
setstate tempdummy 2019-11-09 13:02:10 .Device_Affected no_device
setstate tempdummy 2019-11-09 13:02:10 .Device_Events no_trigger
setstate tempdummy 2019-11-09 13:02:10 .First_init done
setstate tempdummy 2019-11-09 13:02:10 .Trigger_cmd_off no_trigger
setstate tempdummy 2019-11-09 13:02:10 .Trigger_cmd_on no_trigger
setstate tempdummy 2019-11-09 13:02:10 .Trigger_off no_trigger
setstate tempdummy 2019-11-09 13:02:10 .Trigger_on no_trigger
setstate tempdummy 2019-11-09 13:02:10 .V_Check V2.00
setstate tempdummy 2019-11-09 13:02:10 Trigger_log off
setstate tempdummy 2019-11-09 13:02:10 state active
setstate tempdummy 2019-11-09 13:48:33 temperature 14
Inbetriebnahme
Der Testraum 07_Puls enthält drei konfigurierte MSwitch-Geräte, die die beabsichtigte Funktion zusammen bewirken. Pulse enthält die Logik, Pulsedevice dient der Statusausgabe des Generators und tempdummy die Simulation eines Temperatursensors. Beim Erreichen der konfigurierbaren Einschaltschwelle startet die Impulsfolge, beim Erreichen der Ausschaltschwelle stoppt sie.
Sensor Simulation
Funktionsbeschreibung
Der verwendete Rechteckgenerator ist in einem vorigen Beispiel erklärt. Konfiguration Schmitt-Trigger
Anpassung an eigene Anforderungen
Um den Verlust von Konfigurationsdaten zu vermeiden, lässt man das quickedit verriegelt und fügt eigene Zielgeräte per 'edit list' hinzu.
Die Bestätigung mit 'modify Devices' erzeugt pro neuem Gerät einen 'device action'-Rahmen, in den die Konfiguration von 'pulsedevice' übernommen werden kann. 'Modify action' übernimmt. Der zweite notwendige Action-Rahmen für das eigene Device wird per 'add action ..' erzeugt.
Das Attribut 'setlist' erlaubt die leichte Anpassung der auswählbaren Impuls- bzw. Pausenzeiten. Hier können auch Dezimalbrüche wie 0,5 angegeben werden.
Das Attribut 'MSwitch_Debug' wird zweckmäßigerweise auf 1 gesetzt, weil so sinnvolle Zusatzinfos bei der Inbetriebnahme zur Verfügung stehen.
Tempdummy kann durch einen physischen Sensor ersetzt werden.
