FTUI Snippets
Version vom 12. August 2016, 10:30 Uhr von 50watt (Diskussion | Beiträge) (→Rollladen Circle Menu: Wiki-Links zu FSB61 und Circle Menu hinzugefügt)
Spezialfälle für Switch Widget
Vier Buttons für HomeStatus
<li data-row="1" data-col="9" data-sizex="2" data-sizey="3">
    <header>HOMESTATUS</header>
    <div>
          data-get-on="Wert1" data-get-off="!on"
          data-set-off="" class="green"
          data-icon="fa-home" data-background-icon="fa-square" ></div>
        <div data-type="label" class="inline w1x">Home</div>
    <div>
          data-get-on="Wert2" data-get-off="!on"
          data-set-off="" class="blue"
          data-icon="fa-bed" data-background-icon="fa-square" ></div>
        <div data-type="label" class="inline w1x">Night</div>
    <div>
          data-get-on="Wert3" data-get-off="!on"
          data-set-off="" class="orange"
          data-icon="fa-car" data-background-icon="fa-square" ></div>
        <div data-type="label" class="inline w1x">Away</div>
    <div>
          data-get-on="Wert4" data-get-off="!on"
          data-set-off="" class="red"
          data-icon="fa-suitcase" data-background-icon="fa-square" ></div>
        <div data-type="label" class="inline w1x">Holiday</div>
</li>
Switch funktioniert wie ein Push Widget, aber zeigt auch Status an, wie ein Symbol Widget
     data-get-on="auf"
     data-get-off="!on"
     data-set-on="auf"
     data-set-off=""
     data-on-background-color="#ad3333"
     data-off-background-color="#32a054"
     data-icon="fa-arrow-up">
     data-get-on="zu"
     data-get-off="!on"
     data-set-on="zu"
     data-set-off=""
     data-icon="fa-arrow-down">
Variante 2 (Mehrfach Auslösen möglich)
  data-states='["zu","mittel","auf"]'
  data-background-colors='["green", "gray", "red"]'
  data-fhem-cmd="set dummy1 auf"
  data-background-colors='["red", "gray", "green"]'
  data-fhem-cmd="set dummy1 zu"
Beschriftungen von Buttons
Doublebox-v Beschriftung rechts
<div>
    <div class="doublebox-v inline">
             data-set-on="up">
                data-set-on="down">
    <div class="inline">
        <div class="bottom-space-2x">up</div>
        <div class="top-space">down</div>
Triplebox-v Beschriftung rechts
<div class="cell">
    <div class="triplebox-v inline">
             data-set-on="up">
                data-icon="fa-minus" data-background-icon="fa-square-o"
                data-set-on="stop">
                data-set-on="down">
        <div class="bottom-space-2x">stop</div>
Dieses Beispiel bringt ein Circle Menü, dass
  • den Status des Rollladens als Icon anzeigt
    • bestätigt offen (grün, offener Rollladen)
    • bestätigt geschlossen (grün, geschlossener Rolladen)
    • der Rolladen steht zwischen offen und geschlossen
      • graues Rollladensymbol abhängig von der Rollladenposition (0-100)
    • Rollladen bewegt sich nach oben (gelb, Rolladen mit Pfeil nach oben)
    • Rollladen bewegt sich nach oben (gelb, Rolladen mit Pfeil nach unten)
  • Buttons für die Bedienung des Rollladens anbietet
    • Icon Pfeil nach unten zum Schließen des Rollladens
    • Icon Pfeil nach oben zum Öffnen des Rollladens
    • Quadratischer Icon zum Stoppen des Rollladens
  • Switch zum Ein-/Ausschalten der Rollladenautomatik
EnOcean Devices für Rollläden (z.B. Eltako FSB61) können in Fhem folgende Stati annehmen:
  • up
  • down
  • open_ack
  • closed
  • stop
und werden mit folgenden "set" Befehlen gesteuert:
  • closes
  • stop
  • opens
Zusätzlich gibt es noch das Reading "position", dass mit einer Zahl zwischen 0 und 100 angibt, wie weit der Rolladen geschlossen ist.
Um möglichst viel Information im Rollladen Circle Menü anzuzeigen, werden die beiden Werte (Status und Reading "position") mit dem Attribut userReadings im Fhem Rollladen-Device (in diesem Beispiel: "st6.kueche.rollladen") zu einem neuen Reading "statePosition" zusammengefasst:
attr st6.kueche.rollladen userReadings statePosition {
	if(ReadingsVal($name,"state","0") eq "up"
		or ReadingsVal($name,"state","0") eq "down"
		or ReadingsVal($name,"state","0") eq "closed"
		or ReadingsVal($name,"state","0") eq "open_ack")
		{ReadingsVal($name,"state",0)}
	else {ReadingsVal($name,"position",0)};;}
Hier der Code für TabletUI, der kommt z.B. in die index.html
		<div class="container">
				<ul class="menu">
					<li><div data-type="symbol"
							data-device="st6.kueche.rollladen"
							data-get="statePosition"
							data-states='["up","down","open_ack","closed","[0-9]","1[0-9]","2[0-9]","3[0-9]","4[0-9]","5[0-9]","6[0-9]","7[0-9]","8[0-9]","9[0-9]","100"]'
							data-icons='["oa-fts_shutter_up","oa-fts_shutter_down","oa-fts_window_2w","oa-fts_shutter_100","oa-fts_shutter","oa-fts_shutter_10","oa-fts_shutter_20","oa-fts_shutter_30","oa-fts_shutter_40","oa-fts_shutter_50","oa-fts_shutter_60","oa-fts_shutter_70","oa-fts_shutter_80","oa-fts_shutter_90","oa-fts_shutter_100"]'
							data-colors='["yellow","yellow","green","green","#505050","#505050","#505050","#505050","#505050","#505050","#505050","#505050","#505050","#505050","#505050"]'
						></div></li>
					<li><div data-type="switch"
								data-device="sw_rollladenAutomatik"
								data-icon="oa-fts_shutter_automatic"></div>
					<li><div data-type="push"
								data-set-on="closes"
								data-icon="fa-angle-down"></div></li>
								data-set-on="stop"
								data-icon="oa-audio_stop"></div></li>
								data-set-on="opens"
								data-icon="fa-angle-up"></div></li>
				</ul>
			<div data-type="label">Rollladen</div>
