FHEM und FritzBox 7240
Instructions and recommendations for running Fhem on a FritzBox 7240.
CUL
- flash CUL_V3.hex (from Atmel page)
- attach CUL to Fritz!Box (with a USB Hub to have USB-Memory stick and CUL running at the same time)
Note: to check if CUL works, in FritzBox settings enable USB-Fernanschluss.
Now it gets recognized as CUL868. Remember to disable it again.
The CUL should be recognized as Es handelt sich um ein nicht unterstütztes USB-Gerät
. This is OK!
Fritz!Box 7240
- Update Fritz!Box to Firmware-Version >= 73.05.05
- download Fhem
- unzip and store at root of your USB-Memory stick in the folder "fhem" (this will be
/var/InternerSpeicher/<yourUsbStickName>/fhem/
on you Fritz!Box lateron. - in this folder, adapt the file "startfhem" if you use more than one storage device (e.g. USB memory stick and 1&1 Online Speicher") with hardcoded destination folder for your fhem path:
home=/var/InternerSpeicher/SanDisk-Cruzer-01/fhem
- Alternatively, disable "1&1 Online Speicher" and use USB memory stick only. This way you don't have to adapt startfhem.
- to use telnet, it needs to be enabled via phone by dialing #96*7*. To login, use the same password as for Fritz!Box webfrontend. Now you can edit all of your files using vi in telnet.
- Now define your "fhem.cfg" to match your configuration, e.g. starting with your housecode:
define myCUL CUL /dev/ttyACM0 1234
- finally start fhem in telnet:
/var/InternerSpeicher/SanDisk-Cruzer-01/fhem/startfhem
- or use autostart => see [#Autostart_fhem #Autostart fhem]
Open issues
Daily resets with big log files
After 1 week running perfectly I was seeing regular/daily resets. The problem in my setting is that I am using several FS20-STR. These devices send every 2-3 minutes off-for-timer or on-for-timers signals. These events get logged in the monthly log file. After this log was bigger then 1MB I have seen these resets. After I emptied/deleted the file the box is running stable again.
After looking into the details, it seems that the 7240 gets a memory problem when log files get bigger than ~800KB. I changed the logging from monthly files to weekly files (using ./log/fhem-%Y-%m-%V.log
). This way, files should no longer get that big. Since then, 7240 runs stable without any problems.
See also GoogleGroups:FHEM auf Fritzbox - Logfile - Info wenn wenig Speicher
