Raspi docker-compose.yml
YAML Definition zu dem auf der Seite S7 Beispielkonfiguration vorgestellten Multicast-Empfang mitDocker:
version: '3'
services:
fhem:
image: fhem/fhem:latest
#restart: always
restart: unless-stopped
ports:
- "8083:8083"
- "7072:7072"
volumes:
- ./fhem/core/:/opt/fhem/
networks:
default:
ipv4_address: 192.168.31.1
devices:
- "/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AL01XC9Y-if00-port0:/dev/onewire3"
- "/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_DAE003E5-if00-port0:/dev/onewire2"
- "/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_DAE003E6-if00-port0:/dev/onewire1"
- "/dev/ttyAMA0:/dev/ttyAMA0"
environment:
FHEM_UID: 1000
FHEM_GID: 1000
TIMEOUT: 10
RESTART: 1
TELNETPORT: 7072
TZ: Europe/Berlin
depends_on:
- "mysql"
- "mqtt"
habridge:
restart: always
image: habridge/ha-bridge-raspberrypi3
volumes:
- ./habridge/data/:/ha-bridge/data
- /etc/localtime:/etc/localtime:ro
- /etc/timezone:/etc/timezone:ro
networks:
default:
ipv4_address: 192.168.31.2
# homebridge:
# restart: always
# image: oznu/homebridge:raspberry-pi
# volumes:
# - ./homebridge:/homebridge
# environment:
# - TZ=Europe/Berlin
# - PGID=1000
# - PUID=1000
# - HOMEBRIDGE_CONFIG_UI=1
# - HOMEBRIDGE_CONFIG_UI_PORT=8081
# #network_mode: host
# networks:
# default:
# ipv4_address: 192.168.31.3
# depends_on:
# - "fhem"
mysql:
restart: always
expose:
- "3306"
- "33060"
ports:
- "3306:3306"
- "33060:33060"
image: hypriot/rpi-mysql
volumes:
- ./mysql/init.sql:/docker-entrypoint-initdb.d/fhem-init.sql
- ./mysql/data:/var/lib/mysql
environment:
- MYSQL_ROOT_PASSWORD=xxx
- MYSQL_DATABASE=fhem
- MYSQL_USER=fhemuser
- MYSQL_PASSWORD=xxx
networks:
default:
ipv4_address: 192.168.31.4
mqtt:
restart: always
expose:
- "1883"
- "9001"
ports:
- "1883:1883"
- "9001:9001"
image: pascaldevink/rpi-mosquitto
networks:
default:
ipv4_address: 192.168.31.5
volumes:
- ./mqtt/config/:/mqtt/config/
- ./mqtt/log/:/mqtt/log/
- ./mqtt/data/:/mqtt/data/
nodered:
restart: always
expose:
- "1880"
ports:
- "1880:1880"
image: elzekool/rpi-nodered
volumes:
- ./nodered/data/:/root/.node-red/
networks:
default:
ipv4_address: 192.168.31.6
depends_on:
- "mqtt"
networks:
default:
external:
