Weiteres Beispiel - SMA Wechselrichter
Version vom 12. November 2024, 15:59 Uhr von Ph1959de (Diskussion | Beiträge) (Forenlink auf Vorlage umgestellt, syntaxhighlight korrigiert)
Based on the discussion in the forum, here is another example that shows how the language can be changed in SMA inverters. To do this, the value of the double holding register 40013 is read or set. 777 corresponds to DE, 778 to EN.
   define SI ModbusAttr 3 10 192.168.188.38:502 TCP
   attr SI closeAfterResponse 0
   attr SI dev-h-defLen 2
   attr SI dev-h-defPoll 0
   attr SI dev-h-defRevRegs 0
   attr SI dev-h-defUnpack N
   attr SI dev-type-ENUM_JN-hint EN,DE
   attr SI dev-type-ENUM_JN-map 777:DE,778:EN
   attr SI dev-type-ENUM_JN-revRegs 0
   attr SI enableControlSet 1
   attr SI obj-h40013-reading Sprache
   attr SI obj-h40013-set 1
   attr SI obj-h40013-showGet 1
   attr SI room SYSTEM->modbus
