MQTT2-Module - Praxisbeispiele
Beispiel[5]:
auto-Konfigurations-features
Schritt für Schritt
zigbee2mqtt
Tasmota
MQTT2_DEVICE
Manuelle Anpassungen - Dimmer
off cmnd/dimmer/POWER off\
Dimmer cmnd/dimmer/Dimmer
attrTemplate
on-for-timer
delay
pulseTime
zigbee2tasmota
ESPurna
Shelly
Vorbemerkung
Shelly1
Shellybulb
Internals: CFGFN CID shellybulb_3CC533 DEF shellybulb_3CC533 DEVICETOPIC MQTT2_shellybulb_3CC533 IODev MQTT2_FHEM_Server NAME MQTT2_shellybulb_3CC533 NR 246 STATE ??? TYPE MQTT2_DEVICE READINGS: 2018-12-12 19:28:08 status_blue 0 2018-12-12 19:28:08 status_brightness 61 2018-12-12 19:28:08 status_effect 0 2018-12-12 19:28:08 status_gain 26 2018-12-12 19:28:08 status_green 0 2018-12-12 19:28:08 status_ison true 2018-12-12 19:28:08 status_mode color 2018-12-12 19:28:08 status_red 255 2018-12-12 19:28:08 status_temp 3250 2018-12-12 19:28:08 status_white 0 Attributes: IODev MQTT2_FHEM_Server readingList shellybulb_3CC533:shellies/shellybulb-3CC533/color/0/status:.* { json2nameValue($EVENT, 'status_') } room MQTT2_DEVICE
Shelly Plug S
HTTP-Commands
Shelly Gen2
Shelly Plus 1
Internals: CFGFN CID shellyplus1_441793a34044 DEF shellyplus1_441793a34044 DEVICETOPIC MQTT2_shellyplus1_441793a34044 FUUID 622297af-f33f-0d8f-ad95-4ffbc9f7f8b82699 IODev m2s LASTInputDev m2s MSGCNT 5 NAME MQTT2_shellyplus1_441793a34044 NR 9092 STATE ??? TYPE MQTT2_DEVICE m2s_CONN m2s_192.168.177.167_65059 m2s_MSGCNT 5 m2s_TIME 2022-03-04 23:50:31 READINGS: 2022-03-04 23:50:23 IODev m2s 2022-03-04 23:50:31 available_updates_beta_version 0.10.0-beta6 2022-03-04 23:50:31 cfg_rev 1 2022-03-04 23:50:23 connected true 2022-03-04 23:50:31 dst shellyplus1-441793a34044/events 2022-03-04 23:50:31 fs_free 237568 2022-03-04 23:50:31 fs_size 458752 2022-03-04 23:50:31 mac 441793A34044 2022-03-04 23:50:31 method NotifyStatus 2022-03-04 23:50:23 online true 2022-03-04 23:50:23 params_mqtt_connected true 2022-03-04 23:50:23 params_switch_0_id 0 2022-03-04 23:50:23 params_switch_0_temperature_tC 40.78 2022-03-04 23:50:23 params_switch_0_temperature_tF 105.41 2022-03-04 23:50:31 params_sys_available_updates_beta_version 0.10.0-beta6 2022-03-04 23:50:31 params_ts 1646434232.34 2022-03-04 23:50:23 params_wifi_rssi -57 2022-03-04 23:50:23 params_wifi_ssid WLAN-Alex 2022-03-04 23:50:23 params_wifi_sta_ip 192.168.177.167 2022-03-04 23:50:23 params_wifi_status got ip 2022-03-04 23:50:31 ram_free 180792 2022-03-04 23:50:31 ram_size 249508 2022-03-04 23:50:31 restart_required false 2022-03-04 23:50:31 src shellyplus1-441793a34044 2022-03-04 23:50:31 time 23:50 2022-03-04 23:50:31 unixtime 1646434232 2022-03-04 23:50:31 uptime 9
Attributes:
readingList shellyplus1_441793a34044:shellyplus1-441793a34044/online:.* online
shellyplus1_441793a34044:shellyplus1-441793a34044/status/mqtt:.* { json2nameValue($EVENT) } shellyplus1_441793a34044:shellyplus1-441793a34044/events/rpc:.* { json2nameValue($EVENT) } shellyplus1_441793a34044:shellyplus1-441793a34044/status/sys:.* { json2nameValue($EVENT) }
room MQTT2_DEVICE
Tipps
Das aktuelle Template wurde um die Funktion erweitert, den Button Mode um zu schalten, in den meisten Fällen legt man sich auf eine Schaltmethode fest, welche zum Hardware Setup passt.
Der Befehlt lässt sich mit dem webCmd in_mode auch schnell zugänglich in die Übersicht vom Shelly setzen, so erhält man neben dem Status ein Dropdown mit flip detached und toggle zum schnellen umschalten. Mit webCmdLabel kann man noch einen Namen für das Dropdown setzen.
OpenMQTTGateway
8-Port-Ethernet Board
Milight-Bridge
Vorbemerkung
Der esp8266_milight_hub ist ein open source- Projekt, mit dem auf Basis von openmili eine Vielzahl von MiLight-Geräten gesteuert werden können. Der MiLight-Hub erstetzt dabei eine beliebige Zahl von Milight-Bridges und ist auch zu verschiedenen Versionen des MiLight-Protokols kompatibel. Neben MQTT kann dieser auch mit HTTPMOD oder Wifilight (bzw. den MiLight-Modulen) gesteuert werden. Die Hardware entspricht dabei im Wesentlichen einem MySensors-Wifi-Gateway[6]. Hier wird vorausgesetzt, dass eine funktionierende Bridge vorhanden ist. Der Vorteil der MQTT-Lösung liegt darin, dass man bei kompatiblen Fernbedienungen auch direkt Informationen über Schaltvorgänge erhält, die mit der Fernbedienung ausgelöst werden.
Einstellungen am MiLight-Hub
FHEM-Devices
Bridge
defmod MQTT2_milight_hub_1370325 MQTT2_DEVICE milight_hub_1370325 attr MQTT2_milight_hub_1370325 IODev MQTT2_FHEM_Server attr MQTT2_milight_hub_1370325 readingList milight_hub_1370325:milight/updates/0xBE59/rgbw/1:.* { json2nameValue($EVENT, '1_', $JSONMAP) } attr MQTT2_milight_hub_1370325 room MQTT2_DEVICE
Einzelne Leuchtmittel
defmod MQTT2_milight_0xBE59_1 MQTT2_DEVICE milight_0xBE59_1 attr MQTT2_milight_0xBE59_1 IODev MQTT2_FHEM_Server attr MQTT2_milight_0xBE59_1 readingList milight/states/0xBE59/rgbw/1:.* { json2nameValue($EVENT, '1_', $JSONMAP) } attr MQTT2_milight_0xBE59_1 room MQTT2_DEVICE
defmod Licht_Wz_all MQTT2_DEVICE attr Licht_Wz_all IODev MQTT2_Broker attr Licht_Wz_all eventMap /set_white:Weiss/night_mode:Nacht/white_mode:white/on:on/off:off/ON:on/OFF:off/next_mode:Mode/mode_speed_up:Up/mode_speed_down:Down/ attr Licht_Wz_all group Licht attr Licht_Wz_all icon light_control attr Licht_Wz_all readingList milight/0x5D02/rgb_cct/0:.* { json2nameValue($EVENT) }\ milight/updates/0x5D02/rgb_cct/0:.* { json2nameValue($EVENT) }\ milight/states/0x5D02/rgb_cct/0:.* { json2nameValue($EVENT) }\ attr Licht_Wz_all room Wohnzimmer attr Licht_Wz_all setList on milight/0x5D02/rgb_cct/0 {"status":"ON"}\ off milight/0x5D02/rgb_cct/0 {"status":"OFF"}\ level milight/0x5D02/rgb_cct/0 {"$EVTPART0":"$EVTPART1"}\ hue:colorpicker,HUE,0,1,359 milight/0x5D02/rgb_cct/0 {"$EVTPART0":"$EVTPART1"}\ command:uzsuSelectRadio,Weiss,Nacht,Mode,Up,Down milight/0x5D02/rgb_cct/0 {"$EVTPART0":"$EVTPART1"}\ brightness:colorpicker,BRI,0,1,255 milight/0x5D02/rgb_cct/0 {"$EVTPART0":"$EVTPART1"}\ next_mode milight/0x5D02/rgb_cct/0 {"$EVTPART0":"$EVTPART1"}\ mode_speed_up milight/0x5D02/rgb_cct/0 {"$EVTPART0":"$EVTPART1"}\ mode_speed_down milight/0x5D02/rgb_cct/0 {"$EVTPART0":"$EVTPART1"}\ saturation:colorpicker,BRI,0,1,100 milight/0x5D02/rgb_cct/0 {"$EVTPART0":"$EVTPART1"}\ color_temp:colorpicker,CT,153,1,370 milight/0x5D02/rgb_cct/0 {"$EVTPART0":"$EVTPART1"}\ device_id milight/0x5D02/rgb_cct/0 {"$EVTPART0":"$EVTPART1"}\ effect milight/0x5D02/rgb_cct/0 {"$EVTPART0":"$EVTPART1"}\ mode milight/0x5D02/rgb_cct/0 {"$EVTPART0":"$EVTPART1"}\ commands milight/0x5D02/rgb_cct/0 {"$EVTPART0":"$EVTPART1"} attr Licht_Wz_all sortby 1 attr Licht_Wz_all webCmd command:brightness:saturation:color_temp:hue attr Licht_Wz_all webCmdLabel command\ :brightness:saturation\ :color_temp:hue
attr Licht_Wz_all readingList milight/states/0x1234/rgbw/2:.* {json2nameValue($EVENT) }\ milight/updates/0x1234/rgbw/2:.* { json2nameValue($EVENT) }\ milight/states/0x1234/rgbw/0:.* { json2nameValue($EVENT) }\ milight/updates/0x1234/rgbw/0:.* { json2nameValue($EVENT) }\ milight/states/0xABCD/rgbw/0:.* { json2nameValue($EVENT) }\ milight/updates/0xABCD/rgbw/0:.* { json2nameValue($EVENT) }\ milight/states/0xABCD/rgbw/4:.* { json2nameValue($EVENT) }\ milight/updates/0xABCD/rgbw/4:.* { json2nameValue($EVENT) }
defmod MiLight_RC1_0 MQTT2_DEVICE milight_0xABCD_0 attr MiLight_RC1_0 readingList milight/states/0xABCD/fut089/[0-8]:.* {} milight/updates/0xABCD/fut089/0:.* { FHEM::attrT_MiLight_Utils::MPDcontrol('myMPD',$EVENT, 'Yamaha_Main') }\ milight/updates/0x5D47/fut089/1:.* { FHEM::attrT_MiLight_Utils::FUT_to_RGBW('Licht_Stehlampe_links',$EVENT) }\ milight/updates/0x5D47/fut089/2:.* { FHEM::attrT_MiLight_Utils::FUT_to_RGBW('Licht_Stehlampe_rechts',$EVENT) }\ milight/updates/0x5D47/fut089/3:.* { FHEM::attrT_MiLight_Utils::four_Lights_matrix($EVENT, 'Licht_WoZi_Vorn_Aussen', 'Licht_WoZi_Vorn_Mitte', 'Licht_WoZi_Hinten_Aussen', 'Licht_WoZi_Hinten_Mitte') }\ milight/updates/0x5D47/fut089/4:.* { FHEM::attrT_MiLight_Utils::shuttercontrol('Jalousie_WZ',$EVENT) }\ milight/updates/0x5D47/fut089/5:.* { FHEM::attrT_MiLight_Utils::shuttercontrol('Rollladen_WZ_SSO',$EVENT) }\ milight/updates/0x5D47/fut089/6:.* { FHEM::attrT_MiLight_Utils::shuttercontrol('Rollladen_WZ_SSW',$EVENT) }\ milight/updates/0x5D47/fut089/7:.* {}\ milight/updates/0x5D47/fut089/8:.* {} attr MiLight_RC_WZ stateFormat CommandSet
eBus
"ebus-Bridge"
Sonos2Mqtt
Setup im System
Erreicht der nodejs Server sonos2mqtt den MQTT Server nicht über - default: localhost, Port 1883, keine Anmeldung" - muss der Parameter --mqtt gesetzt werden!
--mqtt mqtt://myuser:the_secret_password@192.168.0.3:1800
# alles gesetzt--mqtt mqtt://192.168.0.3:1800
# IP Adresse und Port gesetzt, keine Anmeldung am MQTT Server--mqtt mqtt://192.168.0.3
# IP Adresse gesetzt, Port ist Standard 1883
Lokales Setup
Voraussetzung: nodejs und pm2 ist installiert und für alle Benutzer verfügbar.
Setup in FHEM
Voraussetzung:
- autocreate im System ist aktiv.
- Der verwendete MQTT2_SERVER steht auf autocreate simple (default/Standard).
- Templates aktuell - FHEM uptodate oder bei Bedarf in der FHEM Kommandozeile aktualisieren:
Bei der Anwendung des Templates für die Bridge wird das Attribut devicetopic ausgelesen oder auf default sonos gesetzt!
Wird ein anderer Devicetopic verwendet, muss der bei der Anlage der Bridge gesetzt werden!
Diese Zeilen einzeln in der FHEM Kommandozeile oder als Block in der Raw Definition.
- setzt das Template sonos2mqtt_bridge auf das Device,
- lädt die Datei 99_sonos2mqttUtils.pm aus dem contrib Ordner nach,
- definiert ein notify, dies erledigt im weiteren Betrieb die automatische Konfiguration der automatisch erzeugten MQTT2_DEVICEs.
- mit dem Template sonos2mqtt_speaker (das Template kann auch manuell auf vorhandene Player angewendet werden, die automatische Erzeugung der Player wird aber empfohlen)
- Ermittelt Detailinformation des jeweiligen Players (vor allem IP Adresse und Modelnumber)
- Lädt die Sonosgeräte Icons von den UPNP Devices herunter
- erweitert das setList input Kommando um den TV Eingang (HDMI, spdif) bzw. Line_IN Eingang falls vorhanden (Modelnumber)
- Die Player werden automatisch einzeln erzeugt wenn sie mqtt Nachrichten senden (Play/Stop) oder (alle sofort) wenn der sonos2mqtt Server gestartet wird.
Wozu dient die Bridge?
- Auffangen von nicht benötigten MQTT Nachrichten.
- Erzeugung/Weiterleitung von Nachrichten für die einzelnen Player - damit auch die Erzeugung von separaten Playern nach dem Schema MQTT2_RINCON12345678901234567.
- Statusanzeige sonos2mqtt als Reading connected (0 offline, 1 connected, 2 Player connected).
Sie kann zusätzlich als zentrales Device verwendet werden, um die Sonos Umgebung abzubilden, z.B. Readings für Favoriten u.ä.
Start sonos2mqtt lokal
"pm2 start sonos2mqtt"
Autostart von sonos2mqtt mit FHEM
Der Code startet sowohl das sonso2mqtt Modul sofort und implementiert ein notify für den zukünftigen automatischen Start beim Start von FHEM.
trigger n_pm2_sonos start
Autostart von sonos2mqtt im System mit pm2 (Alternative)
Der obige Code startet das sonos2mqtt nodejs Modul mit pm2 beim Start von FHEM. Sollte das nicht funktionieren oder nicht ins gesamte Konzept passen (weil z.B. mehrere nodejs Module geladen werden) kann der automatische Start direkt im System erfolgen. Zunächst dafür das oben eventuell schon definierte notify löschen!
delete n_pm2_sonos
pm2 startup
pm2 save
Verwendung des Docker Containers
environment:
Sonos2mqtt mit mehr Komfort
Owntracks GPS Tracking in FHEM
owntracks auf dem Smartphone konfigurieren
- Modus -> MQTT
- Hostname ->
- Hostnamen: host.cloud.com
- Port: 8883
- ClientID: ID vom Provider
- WebSockets (nicht nutzen)
- Identifikation ->
- Benutzername: user-name
- Passwort: user-password
- GeräteID: mi6 (erscheint in FHEM im Device Namen verwendet)
- TrackerID: hk (nur zweistellig, erscheint als ID in der owntracks Karte)
- Sicherheit -> TLS aktivieren
Definition in FHEM
Der MQTT2_CLIENT wird so eingerichtet, man braucht eine andere ClientID als auf dem Smartphone! Stimmt alles sollte das Gerät sofort open anzeigen.
attr mqtt2Cloud SSL 1
attr mqtt2Cloud room MQTT2_IO
Für die automatische Erzeugung der Trackergeräte in FHEM richtig man zuerst ein Bridge Device ein:
Dies wird entweder mit dem Template allgemein konfiguriert
oder manuell nur für owntracks eingerichtet
MQTT2 Geräte für owntracks werden jetzt automatisch mit dem Namen MQTT2_owntracks_<GeräteID> erzeugt. Diese werden einfach mit dem Template owntracks_device fertig konfiguriert. Bei einem IOS Gerät kann man danach noch das Template owntracks_device_IOS als Erweiterung anwenden.
Anwesenheitserkennung
Die Anwesenheit kann im owntracks Device direkt für die selbst definierten Plätze abgelesen werden: entweder steht im reading place der jeweilige Ort oder away. Um hier noch eine gewisse Einheitlichkeit in der Verwendung zu bekommen kann man ein PRESENCE Device verwenden:
Im Move Modus erfolgt die Erkennung sehr schnell und damit einige Sekunden eher als eine BT Erkennung im Haus - der Akkuverbrauch steigt enorm. Im Significant Modus kann es schon mal ein paar Minuten dauern - ein relevanter Akku Verbrauch ist nicht erkennbar.
Allgemeine Hinweise
Nutzt man das rawEvents-Attribut am MQTT2-IO[10], kann man den Datenverkehr des Servers am Event-Monitor mitschneiden. Dies ist insbesondere für unbekannte Geräte nützlich, deren Topic- und Payload-Struktur noch nicht bekannt ist.
Um den kompletten MQTT Datenaustausch mitzuschneiden, kann man mit attr mqtt2_server verbose 5
auch alles ins FHEM-Log schreiben lassen.
autocreate funktioniert anscheinend nicht?
- (nur bei MQTT2_SERVER:) Der Client muss eine ClientID angeben, diese darf nicht den defaults von mosquito_sub entsprechen.
- Ein allgemeines autocreate-Device (TYPE=autocreate) muss vorhanden und aktiv sein.
- autocreate am IO muss eingeschaltet sein, was für MQTT2_SERVER bedeutet, dass es nicht auf "0" stehen darf (hier ist dann simple die aktive Voreinstellung), für MQTT2_CLIENT sollte ebenfalls simple verwendet werden; dies muss hier allerdings explizit gesetzt werden.
attrTemplate
bridgeRegexp
Üblicherweise werden alle Informationen, die aus einer Quelle stammen auch einem MQTT2_DEVICE zugeordnet, wobei im Falle des dort nicht aktivierten autocreate-Attributs entsprechende readingList-Einträge erzeugt werden. In dem nebenstehenden Schaubild wären dies die Geräte A bis D. Das Attribut bridgeRegexp kann dazu genutzt werden, um neue, bisher unbekannte Topic-Strukturen im Rahmen des autocreate-Vorgangs anders zu strukturieren. Diese werden dabei im Ergebnis einem anderen Device (das ggf. erst erstellt wird) zugeschlagen, sollte eine zu der topic-Struktur passende regex in diesem Attribut gesetzt sein. Für dessen CID und die Bildung des Names wird die im 2. Teil jedes Eintrags als newClientId hinterlegte Angabe verwendet. In nebenstehendem Schaubild ist dies exemplarisch für die Gerätegruppe D mit dem bridge-Device D und dessen Satelliten D1 bis D4 dargestellt. Dementsprechend sind in den hier aufgeführten Beispielen bridgeRegexp-Attribute immer dort zu finden, wo ein Gerät oder Dienst dazu dient, mit weiteren, ggf. auf andere Weise kommunizierende Geräte oder Baugruppen zu kommunizieren, wie z.B. für über hier dargestellten zigbee2mqtt oder zigbee2tasmota. Ein Sonderfall hierbei ist das template MQTT2_CLIENT_general_bridge zur Verwendung mit dem MQTT2_CLIENT, denn aus dessen Sicht stammen alle Informationen aus derselben Quelle, nämlich z.B. dem mosquitto-Server und würden sonst alle einem einem MQTT2_DEVICE zugewiesen.
Ständig neue Devices?
Vergabe einer ClientID
Beispielsweise wäre attr Milight_Bridge readingList milight_hub_1370325:milight/LWT:.* {json2nameValue($EVENT) }
zu ändern in attr Milight_Bridge readingList milight/LWT:.* {json2nameValue($EVENT) }
Die JSON-Daten sollen ausnahmsweise nicht ausgepackt werden
attr MQTT_OwnTracks readingList owntracks/clouduser/mi6:.* { json2nameValue($EVENT) }\ owntracks/clouduser/mi6/waypoints:.* { json2nameValue($EVENT) }\ owntracks/clouduser/mi6/event:.* { json2nameValue($EVENT) }
wird dann:
attr MQTT_OwnTracks readingList owntracks/clouduser/mi6:.* json_mi6\ owntracks/clouduser/mi6/waypoints:.* json_waypoints\ owntracks/clouduser/mi6/event:.* json_event
Die JSON-Daten vor dem auspacken manipulieren
attr DEVICE readingList <your topic>:.* { my $rets = json2nameValue($EVENT,'',$JSONMAP);; my %cleaned = map { $_,$rets->{$_} } grep { 'bad' ne $rets->{$_} } keys %{$rets};; return \%cleaned }
Oder auch einen Wert umzubenennen wenn die JSON-Payload nur ein Objekt beinhaltet:
attr DEVICE readingList <your topic>:.* {my %h=(0=>'SofortLaden',1=>'MinPV',2=>'NurPV',3=>'Stop',4=>'Standby');; return {ChargeMode=>$h{$EVENT}}}
Unnötige Konfigurationsinformationen verwerfen
Weiterführende Themen
näher erläutert.
- Thread zum Tasmota-Device
- Neue templates einreichen
- Der MQTT-Workshop für MQTT2-Module
- ↑ Auch MQTT_DEVICE unterstützt SetExtensions, allerdings muss dies dort per Attribut eingeschaltet werden
- ↑ MQTT2_SERVER verwendet als default-Einstellung für autocreate simple, ohne dass ein entsprechendes Attribut gesetzt werden müsste. Die Einstellung complex empfiehlt sich in der Regel nicht; diese ist jedoch dann zu empfehlen, wenn das Device entweder verschachtelte JSON-Array-Strukturen liefert oder bestimmte Readings nicht gefüllt werden sollen.
- ↑ Diese sind:
milight/states/:hex_device_id/:device_type/:group_id für "state topic pattern". Der Autor hat derzeit folgende Infotypen zum Senden markiert: "status, brightness, hue, color, mode, color_temp, bulb_mode, computed_color, hex_color" (enthält eventuell zu viele Angaben. Bei einem Eventhandler muss man uU. darauf achten, dass kurz hintereinander zweimal dasselbe Event kommen kann (für ON/OFF)). - ↑ Dies betrifft vorrangig die Statusmeldungen
- ↑ z.B.
attr MQTT2_FHEM_Server rawEvents .*
, der regex-Filter kann wie üblich angepasst werden
